Old 12-28-2009, 10:40 PM   #11191
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Originally Posted by YmeBP View Post
Nope not yet, standing at the door waiting for the mailman though. We should have them very very soon!
OK let me know when they are in i want one. if you can hold one for me. thanks
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 12-29-2009, 05:22 AM   #11192
Originally Posted by Mugen10 View Post
Dragonfire, That is good to know about the wear of the car. I am very happy with the Jrxs R. I like to try different cars every year so as spring come near I will weigh all the brands out. The 416X looks good and is fast on asphalt but not sure if it is the car to go for carpet. I know you can buy the battery tray that makes it stiffer and maybe a chassis. That is alot to spend to make it carpet ready.
If you want an asphalt and carpet car th T3 should be a safe bet. The tamiya is designed purely for aspahlt rubber but is effective on other surfaces. Its just the lack of durability that turns me away from Tamiya kits, especially when the top kits cost so much.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-29-2009, 06:07 AM   #11193
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
For the most part I have been reading the car is not the best for carpet. It was the thin chassis that has been the big factor that keeps me away.
The Losi has done very well for me this year for carpet rubber. I have found a very sweet spot for the best lap times. Finding another car that can come close to the performance of the losi will be very difficult.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 12-29-2009, 06:56 AM   #11194
I have been pleasantly surprised by the performance of my losi and I imagine it would take quite a bit to make me even consider another chassis at the moment. It has been fast everywhere I take it. Of particular note was last racemeet. I took my car out for a clubbie with my brother in 17.5 with the new weight limit of 1425g. I had good feel and speed straight away and did one or two minor tweaks for a fast car. My brothers Cyclone however struggled to work with the new weight limit and he spent the entire day trying to get soemwhere near my speed even with the advantage of a faster ESC for that class. At the end of the day I was only slightly slower than the 10.5 guys and miles faster than any of the other 17.5 guys. I believe I would have Q'd 2nd or 3rd in the 10.5 A!
Powered by Falco
Old 12-29-2009, 11:54 PM   #11195
I have a couple of dumb questions for the resident JRXS-R experts
First, when building a slipper spool do you build it just like the diff including the copper washer on the one side and the thrust bearing as well, using the slipper spool pulley?
Second, when one sees a setup with "low roll center + 0.30" what does one use to shim the hinge pin blocks to 0.30? Is there a specific Losi part to do the shimming?
Thanks in advance from JRXS-R Noob!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 12-30-2009, 06:12 AM   #11196
Anyone know if there are 4 degree Aluminum C hubs available for this.
Goggles Paesan is offline   Reply With Quote
Old 12-30-2009, 06:38 AM   #11197
jkirkwood's Avatar
Cheers,
Mike
Yes build the spool as you described.
And yes "Low roll center + 0.30" is using the low roll center blocked shimmed up .30". You can use Losi #4 washers which are .30" think. I think the part number is LOSA6215 but you should confirm.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 12-30-2009, 11:49 AM   #11198
Company Representative
SweepRacingUSA's Avatar
No Mon. if your looking for one cause breaking of EA3 one then just get a Parma ultimate bumper and you should have no problem.
LOSA6215 is a correct number.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 12-30-2009, 01:24 PM   #11199
YmeBP's Avatar
Trader Rating: 32 (100%+)
I've heard the same about the T3. Apparently it's a pain on carpet.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-30-2009, 01:35 PM   #11200
jkirkwood's Avatar
I still think the Losi is the best for all conditions. There maybe a car that shines one one surface or another but the Losi just is there everywhere I go.
Old 12-30-2009, 04:23 PM   #11201
I got my type-R on end of 2008 and had a roller coasting results in early stage
after unlocked few secrets during 2009 season I'm more than confident with my car for a 2010 season both Carpet and the Blacktop
after 10 long years of absent in this hobby I'm truly enjoying racing back with this great machine.
if any one want to join the TC race I strongly recommend a type-R
Had great time with you guys this year on this forum, lets keep this forum on the first page all the time in 2010!
see you all in the A main
happy new year.
Old 12-30-2009, 05:44 PM   #11202
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by da_John_wee View Post
I got my type-R on end of 2008 and had roller coasting results in early stage
happy new year.
im about ready to get into another type-r again.this will be my 4th car and i loved every one of them.
the fellow im getting it from had said that greg sharpe has a set-up on here somewhere for rubber tire on carpet.would like to see if i can find that set-up somewhere.im looking forward to running this chassi again.although with the new weight limit.im just not sure where to go with set-up.cause i have never used lipo in the car.i was basically using haynes rubber tire for carpet on the 2 most recent cars that i have had,although i was using nimh with the car.so if you guys have any input on any updates that would be great.
thx,
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-30-2009, 10:01 PM   #11203
happy new year.
This has been my thoughts as well. Its a stupid fast car that seems to work anywhere! Its also got great support here in this forum with many fast/exp drivers on every surface.
Have a happy new year fellow Type R owners and many race wins for 2010!
Powered by Falco
Old 12-31-2009, 12:47 AM   #11204
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
My thoughts too.
Happy new year and thanks for the support Flying Fox had had from Type R racers all over the world.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 12-31-2009, 05:52 AM   #11205
Trader Rating: 114 (100%+)
Happy New Year to all!
Chris Furman is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
