Old 12-12-2009, 10:35 PM   #11101
YFB
Default mounting 0.30 sway bar
tried to mount the 0.30 sway bar but the grub screw doesn't go far enough into the ball to clamp the sway bar. ie. the sway bar isn't thick enough. works fine with 0.40 sway bar. is it just me or is this a manufacturing defect? any work around?
YFB is offline   Reply With Quote
Old 12-13-2009, 01:46 AM   #11102
crabboy's Avatar
Trader Rating: 58 (98%+)
i have just got a JRXS-R and some one told me her is a mod to do to the top deck to get the chassis to flex, with some 700 pages its hard to find pics, is someone able to post a link or pic, and if anyone has got any more tips that would be great.
The car will be used for rubber tyre racing on ashpalt.
Cheers
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-13-2009, 03:35 AM   #11103
Trader Rating: 114 (100%+)
Cheers
Rhys
Some drivers have removed the side braces all together... or not put any screws into them. Just leaving the front and rear connected.
Chris Furman is offline   Reply With Quote
Old 12-13-2009, 07:09 AM   #11104
MikeXray's Avatar
Trader Rating: 73 (100%+)
Cheers
Rhys
there are a few ways to do it, here is a link to one of the ways
Team Losi JRXS Type-R
I like the idea of keeping the side posts.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-13-2009, 08:24 AM   #11105
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Yeah, I've never been able to get the grub screw tight around the .030 bars either. BUT.... the .040 bar barely does anything anyway, so perhaps the .030 bar isn't very useful.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 12-13-2009, 08:58 AM   #11106
avs
avs's Avatar
in order to grip the .030 wire, i had to use a tap (a bottoming style) to clean up the bottom of the hole. i didn't have the correct tap, so i took the oldest one and ground the tip. this won't start a hole well, just start the thread carefully so you don't crossthread it.
Tony Shimko
avs is offline   Reply With Quote
Old 12-13-2009, 11:34 AM   #11107
Xpress's Avatar
If you don't have the proper tap to clean the hole up you can also take the set screw on the end of an .050 wrench and spin it against the top of a cut off wheel etc in a dremel to taper the end of the screw. This will allow you to clamp down on the .030 wire.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 12-13-2009, 03:37 PM   #11108
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Im new with my type r. Do most of you mount the esc on the left or right side of the car? Is it dependent on the weight of the esc as to which side?
cpaurl
rallyebmx is offline   Reply With Quote
Old 12-13-2009, 05:51 PM   #11109
MikeXray's Avatar
It depends on the ESC really, some mount on their side better and can be on the left, most are easier on the right.
Old 12-13-2009, 06:40 PM   #11110
jkirkwood's Avatar
Originally Posted by chuslinde View Post
Hi, thank yuo for the answers
This track is fine but there usually some humidity and low temperature in the asphalt, and we run this year with control tire of 35 foams,
in the video the guy of white car is sliding a lot jeje but i canīt complain abut grip i'm very happy with the car.
I will try the set ups you posted.
Another question:
I run with front diff, is better for this kind of tracks with many hairpins or is better spool?
Thank you again.
I tend to believe the spool is faster all the 99.9% of the time. From the video you posted I wouldn't even consider a diff. The spool feels funky to drive at first if you've been driving a diff for a while and maybe even cost you time but once you get use to how it wants to be driven then nothing else seems right anymore.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 12-14-2009, 02:04 PM   #11111
tim fry's Avatar
Brushless on the right brushed on the left
tim fry is offline   Reply With Quote
Old 12-14-2009, 07:29 PM   #11112
rallyebmx's Avatar
Whats the thinking behind this?
cpaurl
Old 12-14-2009, 07:38 PM   #11113
When this car was released the brushless speedos took up more space than Peter Griffin. Placing them on the right side moved the weight in as far as possible.
However, the servo is offset to the right side as well. My Futaba S9550 puts 14g on the right side of the chassis. Balance accordingly.
Old 12-14-2009, 08:32 PM   #11114
I'm new to the Type R (and TC for that matter) but I just installed an LRP SPX Stock Spec on the right side, Futaba FASST receiver on the left side with a Futaba 9550 servo and an ORCA 17.5 motor and my car was ALMOST perfectly balanced side-to-side. I might think about adding ~10g to the receiver side to balance it perfectly but that's all it will need.
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 12-15-2009, 12:31 PM   #11115
rallyebmx's Avatar
Cheers,
Mike
What method did you use to discover your balance?
I was trying to corner balance with 4 scales, but inconsistent surfaces are really throwing the #'s off. I have to get a big plate of glass or something
cpaurl
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
