Old 12-08-2009, 03:15 PM   #11086
Company Representative
SweepRacingUSA's Avatar
Originally Posted by Chris Furman View Post
So... Which body is best for rubber? What are you guys running? Mazda6 or Speed6? LtcR?
spd6 for me.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 12-08-2009, 07:57 PM   #11087
MaxRain's Avatar
I like the Dodge Stratus.
Gordon "slow is fast"
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 12-09-2009, 09:30 AM   #11088
jrxs-r's Avatar
Most of the time PF LTC-R, and on carpet M6 or MS6... depending on how I am feeling... :P
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 12-10-2009, 11:48 AM   #11089
Trader Rating: 114 (100%+)
Anyone running RP30s anymore?
Chris Furman is offline   Reply With Quote
Old 12-10-2009, 12:26 PM   #11090
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
All day everyday!!!
Rod
ClemsonTigers
RKeasler is offline   Reply With Quote
Old 12-10-2009, 12:30 PM   #11091
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Mazda speed light weight... just ran the Losi for the first time last weekend. So good! Just added the 5th body post after reading the above posts.
cpaurl
rallyebmx is offline   Reply With Quote
Old 12-10-2009, 02:17 PM   #11092
chuslinde's Avatar
Hi, need some help for the set up in my type r.
Here will start to race asphalt rubber, untill now we run foams and have no experience with rubber for the first race i have in two weeks in this track
youtube.com/watch?v=v56ab3yWAlo (I can't post url??)
(i am the first car untill i made a mistake and broke the caster block, not the best day for me)
The track have medium to low grip and very bumpy in the fast curve at the end of the straight.
With foams the car with the standart set up is good and only feel a little of understeer when on power.
some starting point?
Thank you.
JRXS TYPE R
XFactory X-6
TAMIYA M03-L
---------------SPAIN IS DIFFERENT--------------
chuslinde is offline   Reply With Quote
Old 12-11-2009, 12:35 PM   #11093
Thank you.
wow you guys drifting heavey, I thought foam racing was point and shoot kinda deal, very interesting
http://team-spoon.bravehost.com/ does have plenty of set up sheet for you, pick your weapon
Old 12-11-2009, 12:41 PM   #11094
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Thank you.
I think you need to post a few more times, then your posted links will be active.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-11-2009, 02:14 PM   #11095
jkirkwood's Avatar
Thank you.
That track looks very slick with many cars appear to be pushing and/or drifting through corners. I've had my setup on very "green" grooved outdoor tracks to high bite indoor tracks. My setup is usually only 1 or 2 adjustments from being really good for me from my standard setup. Go to http://www.petitrc.com/reglages/losi...sLosiJRXS.html and look at a few setups and experiment. As long as the setup is proven somewhere it should be within a few adjustments of your track.
As for the bumpy section you can experiment with a little front kick-up. That will help the car absorb the bumps a bit and bigger pistons. If the bumps are only in one section of the track I would probably just deal with it and attack the rest of the track and deal with the bumps. If the entire track is bumpy I would find something to work in bumps.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 12-12-2009, 01:00 AM   #11096
chuslinde's Avatar
Hi, thank yuo for the answers
This track is fine but there usually some humidity and low temperature in the asphalt, and we run this year with control tire of 35 foams,
in the video the guy of white car is sliding a lot jeje but i canīt complain abut grip i'm very happy with the car.
I will try the set ups you posted.
Another question:
I run with front diff, is better for this kind of tracks with many hairpins or is better spool?
Thank you again.
JRXS TYPE R
XFactory X-6
TAMIYA M03-L
Old 12-12-2009, 01:21 AM   #11097
MaxRain's Avatar
Another question:
Thank you again.
A front diff is generally better for hairpins and 4 degrees caster. As traction rises, you can adjust exponential on your radio to help with oversteer.
I personally prefer to run a diff, and adjust it to get the desired response. I find that with a spool, you put more stress on your tire, creating more tire wear than needed.
Facebook: CARCAR
Old 12-12-2009, 07:15 AM   #11098
YmeBP's Avatar
Trader Rating: 32 (100%+)
I mix it up w/ the sorex and the rp's depends on the track surface and the temperature.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-12-2009, 09:56 AM   #11099
tim fry's Avatar
All
When mounting the anti roll bars what is the prefered position for the links to the arms as this is obviously adjustable. I have always gone to the very end of the roll bar but have seen them with up to 10mm of roll bar poking out the the end. This is clearly a tuning option to adjust stiffness of the roll bar but whats best or most used position?
tim fry is offline   Reply With Quote
Old 12-12-2009, 10:27 AM   #11100
I mount mine with the ball towards the shock tower and then put it flush with the end of the bar.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
