Old 11-08-2009, 02:40 PM   #10936
-J-
-J-'s Avatar
Trader Rating: 16 (94%+)
Originally Posted by da_John_wee View Post
1350? I though 1420 was the latest?
Someone please correct me if I've lost my mind , but I believe the latest is 1350g.
TLR - Viper R/C - PowerPush - Spektrum - eXpress Motorsports - B-Fast R/C
-J- is offline   Reply With Quote
Old 11-08-2009, 03:17 PM   #10937
John Tag's Avatar
Trader Rating: 42 (100%+)
1420 is correct..1350 is some Euro Wt I think that just passed.
Set up depends on rug or Asphalt.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 11-08-2009, 03:19 PM   #10938
-J-
-J-'s Avatar
Oh ok. My mistake.
John, how much does your JRXS Type R weigh RTR?
Old 11-08-2009, 03:35 PM   #10939
John Tag's Avatar
1422- But tahs w/some added lead-I have 14 Grams on servo face,28 Grams Under top deck,and 21 Grams on r/s.
Outdoors:
15 springs f/r
56 Pistons(stock)
35R-F40 Oil
High Roll centers
1* rear toe block
.40 front bar
4* front Hubs
#2 front shock mount
Ball stub front Camber link-#3 on tower
Rear Camber 5/B
41T spool
Rear High Diff
112/44 w/17.5
5-1/2 MM ride Height
#2 rear shocks on tower
3mm droop over RH all around
1/2* Front Toe
.7mm rear Anti-Squat
Front wheel base Middle
Rear Wheel base 3/4 way foward
Easy to drive and get laps then ajust as needed later....
Old 11-08-2009, 03:49 PM   #10940
-J-
-J-'s Avatar
Outdoors:
15 springs f/r
56 Pistons(stock)
35R-F40 Oil
High Roll centers
1* rear toe block
.40 front bar
4* front Hubs
Rear Camber 5/B
41T spool
Rear High Diff
112/44 w/17.5
1/2* Front Toe
Thanks. My kit should be here tomorrow, and hopefully I can have it trackworthy by the middle of the week. Thanks again.
Old 11-08-2009, 09:38 PM   #10941
Originally Posted by L.Fairtrace View Post
I ran overdrive on my spool for 2 years. It works great. But what do I know....
When you ran front overdrive, how many runs on a set of tires for rubber + asphalt before you had to switch to maintain the same feel? or did you rotate fronts <-> backs? Same for rubber + carpet? Thanks.
rainblows is offline   Reply With Quote
Old 11-09-2009, 02:33 AM   #10942
phil goetty's Avatar
Efra sign for 1350g with lipo 2s or life 2s or 5 cells nimh.
Lucas and myself are reaching about 1370g with a balanced car (20g added on recever side), ligth body and plastic lipo trail.
weigth on that car is not problem.
We are working on a new steering concept keeping the original geometry allowing more flex in the front, lowering the Front CG and saving about 30g
phil goetty is offline   Reply With Quote
Old 11-09-2009, 09:26 AM   #10943
Company Representative
SweepRacingUSA's Avatar
Nice Phil, keep us updated!
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 11-09-2009, 09:38 AM   #10944
-J-
-J-'s Avatar
Interested as well...
On a side note, what pinions/spurs should I keep on hand?
Old 11-09-2009, 06:31 PM   #10945
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I have a type R comin any day now. I was planning on getting a Trinity/Epic IP5000 2S Lipo Battery. Is there any fitment issues with this? Is there a better choice as far as fitment goes whether i get the deans or low profile connectors? Thanks, Im relatively new to the on road scene
cpaurl
rallyebmx is offline   Reply With Quote
Old 11-09-2009, 07:15 PM   #10946
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I have the Epic 5000mah battery and the only mod that I did was I shaved off the battery dimples (or whatever you wanna call them) that are at the bottom of the case. Basically you make the battery flat. Don't worry since the battery tray will protect that side of the battery anyways. With the 5000 you also want to have the Flying Fox layshaft so that the pulleys won't rub on the case. The layshaft is a nice upgrade and ti's not expensive at all considering it has the spur gear adapter all in one piece for $29 + shipping. If you use the 3600 mah pack you don't have to shave anything and it drops right in. You still want to get the layshaft though.
BTW, for those of you who may think that the lesser MAH batteries don't run as strong. The guy who tq'd and won the Halloween Classic in 17.5 Foam Sedan ran the 3600 Epic pack on this Corally phi all weekend long.
Sigearhead is offline   Reply With Quote
Old 11-09-2009, 08:22 PM   #10947
rallyebmx's Avatar
Thanks! Do you prefer the Deans or low profile connecters with that battery in your typr r?
cpaurl
Old 11-09-2009, 09:06 PM   #10948
MaxRain's Avatar
For those who are interested, here is a video from the WCICS race in Edmonton Canada. A-main Stock
http://www.youtube.com/watch?v=O_rFNtZKieY
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 11-10-2009, 12:35 AM   #10949
Originally Posted by Dragonfire View Post
Sorry to say but the point of biggest weakness is still wide open. I have been running a little bit of spec racing recently and the diff lasts fine for a whole meet unless it is really dirty. You should rebuild your diff between meets anyway as it lasts a lot longer like that.
I noticed a few pics of the last few pages of various losi's with spec motors. I suggest all of you buy a DUO 1 or 2 and try it out. It is THE best spec motor there is. Skyrocket batteries has some Fantom motors I believe.
The point... simply the dirty. (always out-door)
If the trak is clean, no problems, but if the trak is dirty, and out-door befalls frequently especially during tests or first practic.................
You don't like apply cover anti dust, ok don't do it...... I prefer use it and rebuild my diff. only once at home at the end of the race
ciao ciao
Belty Dog is offline   Reply With Quote
Old 11-10-2009, 03:46 AM   #10950
JRXS_chris's Avatar
I just use 2 diffs in a rotation system. Once one is a little grindy the other goes in. Both get cleaned, rebuilt and run in at the same time to save me time and effort.
JRXS_chris is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
