How do you tune out the bumpsteer with this steering setup? The inner tie rod pivot height changes depending on how much throw you are using. Way back in the day I had an Xpress car that had similar steering. The car was better as soon I switched to a conventional bellcrank system.
You just dont do it..No need!!! Car works fine as is as we both know. There is sooo many tuning options to ajust any thing that is needed in handling as we both know.
I can tell you only a thing.
If you want try it. It's are only 20 minutes of work without cut or drill nothing. If you like ok, if you don't like however ok.
I like it, but it's only my opinion and probably for my drive style.
For bump-in/out you can vary only the height (+or-) of the ball stud of the spindle
ciao ciao
Sorry to say but the point of biggest weakness is still wide open. I have been running a little bit of spec racing recently and the diff lasts fine for a whole meet unless it is really dirty. You should rebuild your diff between meets anyway as it lasts a lot longer like that.
I noticed a few pics of the last few pages of various losi's with spec motors. I suggest all of you buy a DUO 1 or 2 and try it out. It is THE best spec motor there is. Skyrocket batteries has some Fantom motors I believe.
FlyingFoxRC Team Twister Hobbies
Fantom Team Wave
Hmmm....I guess everybody that has all the problems with their diffs is because you guys run outside? I run on carpet foams and have never thought that the diffs were ever an issue with this car. I rebuild my diffs like once a month and that's with racing twice a week and sometimes an extra practice day here and there.
wow Lots of wheel time! I consider myself lucky if I get to race once per month with my R.
Support your local race track 100%, or be a loser with a toy car.
Yup, I only ran mine indoors, both carpet and asphalt until this year and although I always thought they worked better with a fresh rebuild, it wasn't bad. I clean and regrease them every day when running outdoors.
Mike L.
www.MikeLdesigns.com
Schumacher Mi3.5, Losi TypeR
Losi XXX-CR, Kyosho ZX5 SP - http://www.raceway.com
Kyosho MR02 Mini-z - Http://Majshobbyshop.com, http://www.nyrcsuperraceway.com/
I wait until MikeXray asks why my car has two spools, then I rebuild the rear diff.
www.jacksonRCracing.com <---schedule, announcements, euro style curbs, naked ladies
SJCCR - Brownie's - Horsham - Blue Diamond
You meet the nicest people as you hit them in a Mini! -Tom Slick
Speaking of setups, are any of you guys who are running 17.5 rubber on carpet running at the new 1350g minimum weight? If so, what kind of setup are you running at that weight?
Hot Bodies - Tekin - PowerPush - KO PROPO - eXpress Motorsports - JR - KillerKoncepts
1350? I though 1420 was the latest?
