Old 10-26-2009, 09:10 AM   #10846
Company Representative
SweepRacingUSA's Avatar
Originally Posted by Giorgio View Post
Well, fellow Losi drivers...
Some sneak preview of the chassis.
Chassis itselfs is in his final form (99%). It's full of subtle things that the JPG doesn't show...
Upper deck is his first review, some more job to be done...
an I dea I had was milled out a pocket on the chassis where trasponder seats under a front diff so we can monunt a TP like the 1/12th scale, but still protected by thin layer of carbon layer.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 10-26-2009, 09:45 AM   #10847
wild_bill's Avatar
Send a message via Yahoo to wild_bill
Is there a layshaft that provides more clearance for the lipos? I am using Orion's 3800. I narrowed my pulleys and added a washer on each side to give me about 2mm more clearance but its still cutting grooves in my case from the pulleys. Does the Jrxs shaft give more clearance? Also what fans are being used to mount around the motor? Any feed back would be greatly appreciated. Thanks in advance.
Ps I did try the search button prior.
wild_bill is offline   Reply With Quote
Old 10-26-2009, 09:56 AM   #10848
Giorgio's Avatar
Dragonfire
Main chassis is different in the front/rear area, where the section is wider, this is the major one.
A nice difference is the battery area, even if look the same. It has been stretched out a bit, so the battery holder will not interfere (or at least...less) wth the chassis torsion.
For the flexi people, I can have it made in 2 versions, full carbon and carbon/glass/carbon. It's a touch heavier, but is more flexi.
da_John_wee
I've think about pocketing some areas. I've to speak with the carbon fiber guy about it.
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 10-26-2009, 10:00 AM   #10849
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Originally Posted by Dragonfire View Post
I tried the 41t front pulley when I 1st got the car and never liked it. Try just changing the pulley with no other setup changes and see how it goes.
what is the on track difrence between the 41t and 42t pulley
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 10-26-2009, 12:04 PM   #10850
Just go back over the last 30 odd pages and you will read about the "flying fox layshaft". Its a replacement layshaft that uses the standard pulleys but spaces them further out and also incorporates a spur gear holder so you can run most normal size spur gears.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-26-2009, 12:09 PM   #10851
I found it similar to running a shorter top link at the front. More initial steering but understeer mid corner. It was rather "loose" feeling.
Powered by Falco
Old 10-27-2009, 07:57 AM   #10852
Has anyone tried putting the 41t pulley in the rear of the car and a 42t spool pulley up front?
I was just wondering what it would do.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-27-2009, 09:17 AM   #10853
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
It would handle like a nitro car with 60mm rears and 55mm fronts, except the nitro car would get better over the course of the race as the rear tires wore down, whereas your car wouldn't. Bascially, it would be terrible everywhere.
FS: Awesomatix A800A $325 shipped
Greg Sharpe is offline   Reply With Quote
Old 10-27-2009, 09:25 AM   #10854
jrxs-r's Avatar
Don't forget the balancing pin holes!
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-27-2009, 09:26 AM   #10855
I found a foam car is always easier to drive (not always faster) with larger rears so going by that a 41t pulley on the rear will make you understeer.
Powered by Falco
Old 10-27-2009, 12:27 PM   #10856
MikeXray's Avatar
Trader Rating: 72 (100%+)
wouldn't a 41t rear make the car want to snap spin off power? I'm thinking with the weight riding on the nose and the rear wheels trying to spin faster than the fronts.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-27-2009, 01:03 PM   #10857
I don't know for sure... Its not something I have played with. I hace always found that balance onlong with good setup gives performance. Having one end of the car constantly trying to overtake the other dosen't seemed balanced to me so I would tend to stay away from it anyway.
Powered by Falco
Old 10-27-2009, 05:36 PM   #10858
Trust me, running overdriven rear wheels is not something you'd want for an entire 6 minute race with rubber tires on asphalt. We "deal" with it running nitro on foam because we have to, but that's only because our rear tire wear is so manically wild.
Old 10-28-2009, 04:10 AM   #10859
Smile
Hy guys.
Try this..........without cut or "dremeling" something
Raise the top deck of 6 mm; turn upside-down the servo; install on the servo a servo saver like 1/12/ style; go on your local track and drive...
ciao ciao
Belty Dog is offline   Reply With Quote
Old 10-28-2009, 04:19 AM   #10860
JRXS_chris's Avatar
PICS!
JRXS_chris is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
