Old 09-16-2009, 06:30 PM   #10606
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by bmcallister View Post
Would it be recommended on a tight indoor carpet track?
Mine never comes out..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-16-2009, 07:21 PM   #10607
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Originally Posted by John Tag View Post
1 Reason may be during the season last year there was a batch of pullies that were shipped as 42T and were actually 41T,since packing has been fixed.
Some may just be converting back. Like Cory said 41T in front will really help car drive hard on power thru the entire corner. I know I have been running the 41T on front spool for 2 years now and Schreff and Larry also have with great results while they ran there Type-R's.
spools by nature have less on power steering and the 41 tooth option really helps out. Our track now is very tight and a one way is needed but in more open layouts on our carpet track it's a great option.
Jaz406 is offline   Reply With Quote
Old 09-16-2009, 07:44 PM   #10608
Company Representative
SweepRacingUSA's Avatar
isnt that the other way around? tight tracks with hair pins needs a spool and nice wide open track needs a oneway.
SweepRacingUSA is offline   Reply With Quote
Old 09-16-2009, 07:51 PM   #10609
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
You're generally correct for asphalt, but he is reffering to carpet which is funky and sometimes backwards.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 09-16-2009, 09:20 PM   #10610
LOL, I heard that. I spent two race day chasing set up for a "green" track. All the non losi drivers use corally, t.o.p. cars and we we going opposite in spring rates. I was going up and they were going down. Weird that this car likes more spring when there is less traction.
da John ..you may be right about the spool when we get some grip into the new layout.
Old 09-16-2009, 09:44 PM   #10611
not only a spring, the sway bars too, lots of opposite effects I monitered from this car, only thing I can think of it is cuz most of weight trasfer from center to inside of the tires instead of like most other cars weight transfer from out side of the chassis to outside edge of the tire.
Old 09-17-2009, 06:46 AM   #10612
MikeXray's Avatar
Trader Rating: 73 (100%+)
I think the geometry of the short arms plays the biggest role in this.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-17-2009, 07:53 AM   #10613
I was mearly generalizing about asphalt vs carpet on rubber tires, and I believe this car reacts to setup changes better than other chassis, but it does so in the same way. I didn't think the car was backwards, just the surfaces we race them on are sometimes setup differently.
And talk about short arms, I had the orginal JRXS and MYGOSH those arms were short. The setup window was smaller than the cash slot at a 7eleven register in midtown Philly.
Old 09-17-2009, 08:10 AM   #10614
good point, could be,.
I dont know, I feel backwards many time on this car..come to think of it....I think I only felt that way on carpets...hmmmm
Old 09-17-2009, 10:00 AM   #10615
jkirkwood's Avatar
I don't think the car works backwards. Sometimes people will say stuff works backwards because they they do something and the car didn't do as they expected but in reality they misdiagnosed the problem from the very beginning.
For example, there are a series of corners at the local track the car will want to roll onto the front in the mid corner. People was wanting to get more steering so they was softening the front as you should but what they didn't take into account was how much car was dumping and rolling. To the point that the cars was bottoming out. As soon as the car bottomed out it in effect was running a rock hard suspension which equals no steering. I told them to go stiffen it up a bit to prevent the dumping out and instantly they gained the steering they needed.
There a usable range for all settings however differences in driving style, conditions and other factors prevents us from making blanket statements of what those ranges are. One could say that you will never use a 10lb spring on the front but then we will find a track and conditions where that would be useful and nullify the statement.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 09-17-2009, 01:55 PM   #10616
YmeBP's Avatar
Trader Rating: 32 (100%+)
I'm glad you explained it that way, i'm going to try stiffer springs on my setup for the blue diamond. i did notice there was quite a bit of chassis scrub on the sides of my chassis and the car felt like it was washing out in the corner and i'm wondering if i wasn't compressing the suspension to it's limits in the fast sweeper and slapping the chassis on the track.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-17-2009, 02:06 PM   #10617
Nice post... From my exp most people don't truly understand what is wrong with their car when they are trying to fix or improve the setup. Most people I talk to only look at grip and don't have any knowledge about response and its realation to grip. I have seen some very funny setups even from top drivers that don't understand.
I have run many different cars and have helped to setup many others. I have always found that all but one car (or should I say brand) responds to setup changes in a normal fashion and if it seems like it hasn't it it more than likely you have another problem masking the change. the JRX-S type R responds perfectly and predictably to setup change.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-17-2009, 10:02 PM   #10618
I like both of these statements. I am fortunate to have a fellow type R racer to share info with. I feel the changes made in this car, and I too think it responds well to those changes. There is a "traction window" like jkirkwood said. I enjoy trying different changes as much as racing the darn thing.
You guys are right about the finding the right combination of reactivity and traction. It's fun learning this stuff and it's still ongoing for me.
Old 09-17-2009, 10:09 PM   #10619
I could have same problem on the carpet about chassis bottoming out, haynes was running 5.75 mm front ride height with highroll center front! I thought he was nut! then maybe he had reason.
Old 09-17-2009, 10:11 PM   #10620
liljohn1064's Avatar
Trader Rating: 17 (100%+)
This car has some interesting dynamics as far as lateral loading in corners with respect to the center of gravity. The car stays flatter to begin with than any other chassis I've ever driven. It transfers weight differently. It almost feels like when it loads to the side, instead of pushing heavily, it catches traction and balances itself really quickly. Other cars roll, stay loaded to one side, then rock back when the load goes away or they traction roll.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
