Old 09-15-2009, 03:41 AM   #10576
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Spillertwo View Post
How did you shim out the steering so the ends don't drag on the upper deck ? Where did you put the shims ?
What I do is use camber ball end (One useed on shock towers)on steering rack arm with screw coming from top of the steering arm to attach, I then use the short ball stud on servo horn and there is pleanty of clearance.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-15-2009, 04:47 AM   #10577
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by da_John_wee View Post
you seen me crashed horribly many times Rui, BTW thanks for reminding me that!
That comment wasnt towards you... I know you dont crash
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 09-15-2009, 08:00 AM   #10578
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
One gold Losi washer on the top deck under each side of the steering rack. One under the post on the non servo saver side, and one under the servo saver. I just pulled the top deck off, took off the steering rack and put the washers in place over the screws and tightened it back down. The thickness of the washer was enough to take the drag out. I had done it on my first one when I saw it leaving marks and literally catching as it passed the outside edges turning left or right. Now I have a good 1/32" clearance at least. There is enough thread on the screws that come up from the bottom side that I didn't have to use longer ones. Funny how 2 little washers fixed a major steering issue.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-15-2009, 09:21 AM   #10579
Company Representative
SweepRacingUSA's Avatar
of cos........NOT! haha
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 09-15-2009, 09:31 AM   #10580
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
John Lee is one of the best Drivers in the country and should be touring around the world representin' the US......... Losi is very lucky to have such a great wheel and we're very lucky to have him race with us at our local tracks, and let's not forget the valuable input he gives us on a daily basis!
See you at the next one John!
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 09-15-2009, 09:47 AM   #10581
then that will makes you a universal champion that you should travle to different galaxy racing Lunar rover paid by NASA, built by Hotbodies
I think Kwikvdub lost his mind cuz he got out qualified by me for less than 0.5 sec then got served on A main after he crashed horribly on first lap in last sunday.ahahha .....so race up at Jackson this weekkend or what ?
Old 09-15-2009, 10:10 AM   #10582
MikeXray's Avatar
Trader Rating: 73 (100%+)
I think Kwikvdub lost his mind by got out qualified by me for less than 0.5 sec and got served on A main after he crashed horribly on first lap.ahahha so race up at Jackson this weekkend or what ?
Lol, the blue shirt galaxy
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-15-2009, 12:09 PM   #10583
I run 2 gold washers under belkranks. then 2 washers under hub carrier ballstuds when I run LOW ROLL CENTER, 1 washer on MID ROLL center then no washers on HIGH ROLL center. all under 4deg total Castor.
in my measurement on a Hudy set up board that give a Zero bump steer.
Old 09-15-2009, 12:11 PM   #10584
That's a good way to keep it clean all the way out. I like it!
Old 09-15-2009, 01:29 PM   #10585
Kwikvdub's Avatar
I love you John!!
......... Good one Mike!
Alex Valdes
Old 09-15-2009, 01:51 PM   #10586
that galaxy is also known as "buttons" Mike hanulec should be a emperor of that galaxy. puahhaa
Old 09-15-2009, 02:05 PM   #10587
It was mentioned earlier that the outdrive would suffer under a full locked spool setup cause they are designed for a diff or slipper spool application. It is considerably more likely that you will damage parts period with a full locked spool over any other type of front diff design. This reality applies to all chassis.
I think John's simple mod is the easiest way to solve the problem if you are having lots of failures.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-15-2009, 02:11 PM   #10588
Something like a high tension servo saver on each drive output would be a neat idea in theory.
Old 09-15-2009, 02:22 PM   #10589
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Or you all could run the stock spool like Haynes Schreff and I did for many years and won countless races without issue.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 09-15-2009, 02:32 PM   #10590
There's that sound of reason again...
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
