Old 09-13-2009, 08:35 PM   #10546
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by da_John_wee View Post
Great racing today Greg, you looked great, actually better on behind "borrowed" mini cooper then your own car. hahah
You're spot on, Chris's Mini really was better than my VTA! And as a bonus, it actually turned on for the main. My radio is apparently vintage as well. Faulty neutral pot.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 09-13-2009, 08:55 PM   #10547
jrxs-r's Avatar
on your set up sheet I found 1mm droop on the rear! wow! some ball on that car!
Yeah... and more than than and there was quite a fair bit of off power turn in with the spool and running pretty heavy springs on the rear of the car for the conditions. I'd rather have the rear end more stable than I need, and dial in more steering if needed. Usually about 2mm droop over ride height is normal.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 09-13-2009, 10:29 PM   #10548
MaxRain's Avatar
Had a chat with a fellow friend who is not into RC about static roll centre.. He told me that it is best to have static roll centre as close as possible to the ground, must be above ground though. If it is under ground it will have a negative effect on your suspension geometry.
After having this discussion, I checked the settings I used this past weekend and discovered that he was right.. I set the roll centre as per the attached screen shot and was impressed with my findings.
You will notice that I set ride height at 6mm (front) and 6.5mm (rear) which plays a huge roll with static roll centre. Now I see why, the JR link can be adjusted in a high/low position, as this has an affect also.
In addition, downforce created by the body we choose to use will affect static roll centre also. If you are travelling in a straight line, the ride height will generally drop from the downforce created by the body. To maintain the ride height, you need to have springs stiff enough to limit the movement (of ride height) from changing too much. Then as you enter a corner, you want weight transfer to help you steer thru it. Downforce plays a roll in the corners, but it is speed dependant. Generally, weight transfer has a larger roll, which needs to be controlled by sway bars.
If you have a track that has elevation changes, and or bumps, shock oil is your next best friend.
When it comes to vehicle dynamics, there is no "perfect" setup as tires and the body we choose to use can affect performance.
Hopefully this helps those who have been wondering about vehicle dynamics as I have thought about this for a long time and I think I solved some of my own issues..
Lastly, if you haven't already, download the roll centre calculator.. It is worth it, because it's FREE..
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-14-2009, 10:15 AM   #10549
Company Representative
SweepRacingUSA's Avatar
My diff outdrives are getting stripped on both side with a Flyingfox spoool set up.
can you make one look like one-way tube using one-way outdrive set? http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSA3353
out drives are beefier screwed down, also using shorter bones with less weight.
SweepRacingUSA is offline   Reply With Quote
Old 09-14-2009, 11:55 AM   #10550
MaxRain...you have a PM
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 09-14-2009, 12:04 PM   #10551
dcuz383's Avatar
I was wondering how they would hold up in the new spool. I can't get mine to hold up in the stock spool even when I try to glue them in they only hold for a few runs. Seems like some sort of pin can be used to hold them in place. Someone figure it out and let me know.
I would probably hate me too!
dcuz383 is offline   Reply With Quote
Old 09-14-2009, 12:17 PM   #10552
yeah I ran 17.5 yesterday on kinda rough track with few bumps and that landing after bumps is what did this.
when Pablo was mentioning 1pc tube I posted to ask him to make it look like the oneway tube and he came out with this diff looking tube, I though oh well maybe he gotta better idea
but after a month of running this spool I found out I was only wrong once when I though I was wrong. ahahhaha (I got that from someones signature)
another advantage of running oneway type is outdrives price, its a 1/2 price per set!
if he dont make this newer spool than I m going to drill a hole on each side to put 4/40 set screws through it.
Old 09-14-2009, 01:14 PM   #10553
Spillertwo's Avatar
Hi guys,
Wanted some help for my JRXSR for selecting a new brushless motor.
Today i'm running the LRP X11 in 10.5 turn (class in which we have the most races over here)
and i'm looking for a replacement with a bit more power.
How would you rank these suggestions in your opinion:
1. Speed Passion Competition version 3
2. Tekin redline sensored
3. Novak Balistic
4. Fantom Ion 2
5. Trinity or Epic Duo 2
I think all of them have variable timing which is something the LRP lacks.
I have ranked them in my order of favorite according to a few hours reading on the internet.
Spillertwo is offline   Reply With Quote
Old 09-14-2009, 01:25 PM   #10554
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
#5 Trinity Duo!!
http://www.express-motorsports.net/index.html
Enjoy!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-14-2009, 01:29 PM   #10555
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Spillertwo View Post
Hi guys,
3. Novak Balistic
4. Fantom Ion 2
Fantom Ion 2, Trinity, Express etc Duo-2's are interchangeable performance wise and would be the way I would go. I actually like the Original Duo's a little better than he Duo-2's but that's me.
Novak Ballistics are the same performance as the original SS line, and are not quite as quick as the Duo based motors, however they have the advantage of having user replaceable winds which reduces the cost of smoking a motor.
Tekin motors are strong contenders but you will have to grind the hinge pin holder a little to get full pinion gear range out of it.
I have no experience with the speed passion v 3 i did use an older speed passion and i couldn't change the timing.
All in all i haven't found a clear performance leader in my tests, but again that is me and i've yet to test some of the newer motors from corally and some of the other manufacturers.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-14-2009, 01:39 PM   #10556
YmeBP's Avatar
Don't forget this part of the car was originally engineered to absorb the impact and take the damage away from more expensive components in the front end.
I think Fairtrace mentioned this earlier in the thread. I've actually been running my spool with a 4.5 and i haven't had any issues with stripping, slipping or binding yet, but I really have to tell you that i haven't hit much with the car because i'm terrified that with the 4.5 the whole car will just disintegrate.
In my 10.5 car at blue diamond i hit things pretty often and again i really havent had any issues w/ the spool setup.
I must admit that i do not have a spool in my 13.5 car yet (waiting on new stock to arrive so i can fill my back order hahaha) and yesterday getting it ready for Ashley to run in the regionals i put a 10.5 in it. I came off the track and walking back to the pits i hear a loud *snap* and i swear my speedo is dead. I mean it was loud. Dorian thought he saw something spark and i started sweating hahaha. Turns out it was the screw side hub giving up the ghost it just snapped after the race. I'll take a photo of it when i do maintenance and change it over to the FF spool when they arrive.
So i've busted up about 4 stock spools and no FF spools and actually no outdrives in either the stock or FF spools. Not sure what i'm doing different.
Old 09-14-2009, 01:45 PM   #10557
Originally Posted by Kwikvdub View Post
+1
The Duo's have generally been the gun motor in spec for a while now. The original Duo is torque based while the Duo 2 is RPM based. With a good speedy I would tend to lean to the original Duo. I believe SkyRocketBstteries will have stock of them (Fantom label) so there is your source.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-14-2009, 03:25 PM   #10558
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I tried the high setting for the F/R diff. I have been running the high F and low R. I made the change and it had a effect on a the car different than what I thought. The car reaction got more responsive and squared up faster onpower out of the corner. It was a bit more twitchy but the corner speed seemed to be a bit faster. It was a bit harder to drive smooth but if I stopped driving hard the car was faster.
What are the input for running both diffs high?
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 09-14-2009, 03:50 PM   #10559
Blackstring's Avatar
Where is the download located?
Short course? Never heard of it.
S&N's Trackside
Blackstring is offline   Reply With Quote
Old 09-14-2009, 03:52 PM   #10560
you dont hit things hahah
unlike PROS, I do hits a lot like rest of us and this parts was made and sold most to them most like any other parts/products
well but it's got not much to do with hitting somethng, like I mentioned when you race on rough surface if car get jumpy and landing few times in every map it can grind that part down easily, just think about it.
just pull out the out drive from your car and inspect that slots on the out drives, it's got bigger and out drives rocking back and forth inside of the tube, beilive me I'll inspect your car next time we meet to show you if you dont do it by your self
Larry mentioned this before we all know that, but think about all other cars in the past that had a 1pc solid axle on the front, why can't this car handle the stress ? the oneway is like a spool in forward motion and stock out drives for one way never had any problem, it might stripped a spur gear if you have a stock centershaft but I never heard outdrives got stripped.
anyway I know FF is good products and all but there is always room for improvement and making one like one way tube can be better version.
Add: pic of my out drives added and wanted to mentioned you may say I did something wrong installing cups in it but both of out drives have same damaged on it and I dont think I can make same exact mistakes on both out drives on same time.
when I race at Jackson (very flat surface) I was fine but 1 day on parking lot style racing killed this parts.
Team Losi JRXS Type-R-09142009_outdrives.jpg   Team Losi JRXS Type-R-09142009_outdrives2.jpg
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
