Old 09-11-2009, 05:32 PM   #10501
WheelNut's Avatar
Send a message via MSN to WheelNut
Could someone link me to the mod to move the centre pulleys farther apart. I've got 1mm of clearance on the right pulley and -1mm of clearance on the left side.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 09-11-2009, 05:39 PM   #10502
jebs's Avatar
Send a message via Yahoo to jebs
is this car made for foams? i want to race on rubber on asphalt do i need modifications to make the car competitive? thanks
jebs is offline   Reply With Quote
Old 09-11-2009, 05:52 PM   #10503
Who is running a losi at the IIC?
dasdaman is offline   Reply With Quote
Old 09-11-2009, 06:19 PM   #10504
jkirkwood's Avatar
I raced mine on with foam on carpet over the winter season. This summer on VTA tires and then last week on TC rubber tires. Same kit, it is very versatile and quick in both foam and rubber configurations. No modifications are necessary to make it competitive. I just recommend the Flying Fox Solid Spool for the Losi Jrxs Type-R and the Parma front bumper (it's harder than the stock one).
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 09-11-2009, 06:57 PM   #10505
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
The Parma bumper is a must have. Its saved me more than I've paid for it a couple times over in the 2 months I've had it on the car.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-11-2009, 07:29 PM   #10506
Company Representative
SweepRacingUSA's Avatar
just shaved down inner part of those pulleys and shimed em out little, but IMO it s not worth all that effort, just get a flyingfoxrc.com center shaft and your all set.
you may remove 4 screws from upperdeck support for ashpalt. then you set.! car rocks on any surface.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 09-11-2009, 07:51 PM   #10507
WheelNut's Avatar
Thanks John. I'll shave 'em down, gotta race tomorrow, so no time to order a shaft, but I might just order one later.
•Brad Comis
Old 09-11-2009, 08:52 PM   #10508
RedRocketRacing's Avatar
Would somebody mind giving me a run down or new parts and anything that might of changed or been learned in the last year. Thinking of blowing the dust off ot the Type R and going racing. Batteries, setups, aftermarket parts, those types of things, either a post or a pm would be great. Thanks.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 09-11-2009, 10:21 PM   #10509
RedRocket
Check this page out: http://team-spoon.bravehost.com/
Mr. Losi's, Mike Haynes and a few other really good setup exist out there. They are all still very good.
Old 09-11-2009, 11:16 PM   #10510
Yeti35's Avatar
You do not have to remove the the four stand off screws to get it to work on asphalt. It works just fine with the screws where they belong. If you need flex to get the car to work then your setup is off.
There are at least four people running Type R's I know of running the car at IIC. Myself in 13.5 rubber and foam. Friend of mine from SLC running it in 13.5 rubber and Mod rubber. Two guys from Maui running in 17.5 amatuer class. These are the only R's I am aware of at IIC.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-11-2009, 11:29 PM   #10511
I guess setup wasn't really what I am after, more curious about new parts and the latest lipo's that are being ran. Thanks again.
RedRocket
NWIC 2008/09
Old 09-12-2009, 12:44 AM   #10512
Originally Posted by MaxRain View Post
yes, track width is what I was trying to refer to.. After posting, I did a little research and discovered what the short and long settings were. I read the manual and found at the back that the rear is maxed at 190. I am going to check this out by using my setup station..
will let you know.
With 3.5 degrees rear toe and standard hex's you are at the full 190mm chassis width. Note that you need to measure this from the widest point which is the middle back edge of the rear wheels.
That said I run standard (narrow) hex's front and rear for rubber. I have tried wider but you just loose grip.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-12-2009, 12:53 AM   #10513
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
RedRocket
The IP batteries fit great and have 4mm plugs and need little to no modifications, maybe a dremel job to open the top deck up for the plugs to fit easily. The flying fox layshaft is a nice part in both quality and usefullness for battery fitment and it includes a spur gear adaptor. I like the new Duos for brushless power and any speedo with timing advance spofiles, Tekin RS , LRP SPX for 21.5-10.5 and SXX for mod 9.5 and lower.
Jaz406 is offline   Reply With Quote
Old 09-12-2009, 05:46 AM   #10514
Trader Rating: 17 (100%+)
The IP5000 needs major surgery to fit with steel tray and some for plastic one
billb60 is offline   Reply With Quote
Old 09-12-2009, 10:31 AM   #10515
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I find that a wider rear track is very helpful in high traction conditions for keeping the car free.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
