Old 08-16-2006, 10:27 PM   #91
POOKYT's Avatar
Originally Posted by KarpetRacer93
2 weeks?!?! Hold on a minute i thought it was supposed to come out early october?
The 2 weeks thing is an old joke we always use when we are wainting on something new. Sorry to get your hopes up.
BTW--I keep up with the Losi 8 nitro thread and they keep using the "2 weeks" thing too!!! LMAO Iz all good fellas!!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 08-16-2006, 10:47 PM   #92
Yeti35's Avatar
Originally Posted by POOKYT
Yeti--2 weeks ago in our 2 day big club race I ran mod and 19 turn with my car. Once I dialed in enough steering for my mod motor, the car was even faster in 19 with the same set-up. Bring both car with you to Vegas!!! We may need the parts by the time I finish my practice runs!!! LMAO
Brant
I planned on havin both there anyhow since I will be running both!! No, you are not strippin either one of my cars for parts!!
There will be a hobby shop on the property, just tell Shane now what parts you break the most so he can have them there for you!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-17-2006, 03:32 AM   #93
Originally Posted by ApexSpeed
Can't wait to get my hands on one... though, if I had one, I'd have no place to race it.
DITTO
Davenport is offline   Reply With Quote
Old 08-17-2006, 07:54 AM   #94
Tornado_Racing's Avatar
This is what I wouldn't mind seeing in the new kit:
1. Sway bars front and rear
2. BK and KB lower shock mounts
3. Rear Bulkhead milled for the rear-front shock mounting
4. Pre-drilled holes for weight placement as needed (lower chassis plate)
5. Spool Pads
6. Vari-length arms front and rear
7. No body
8. No tires or wheels
9. All polished aluminum finish (accept shock bodies)
Option parts:
1. One-way front diff
2. Various add-on threaded weights (bolting to the chassis)
3. 2 degree standard and off-set rear hubs
4. Optional Thicker/Thinner chassis and top decks
5. Optional fan mounts (top deck and chassis)
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 08-17-2006, 08:30 AM   #95
JRXS_chris's Avatar
Definately no body, tyres or wheels.
JRXS_chris is offline   Reply With Quote
Old 08-17-2006, 09:02 AM   #96
EricF's Avatar
no red annodizing (kyosho). green would be cool, Todd chose wisely with that color. no tires, wheels and body can and should be left out.
E
EricF is offline   Reply With Quote
Old 08-17-2006, 10:06 AM   #97
RCSteve93's Avatar
5. Spool Pads
7. No body
Option parts:
Wouldnt you want it to be a no options needed car??
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 08-17-2006, 10:10 AM   #98
Matt Howard's Avatar
no car will ever be a "no options needed" car. There's just way too many variables involved regarding how the car will be run. Person A might think a front oneway is a needed option while person B wouldn't, and so on.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 08-17-2006, 10:32 AM   #99
Default Building of the new Losi-Type R Sedan.
In the past running for losi I will admit that there was just a few small bumps in the building of the cars. There is and always has been burrs from the molds and some minor tweeking in order to build a car correctly. I also must add this is not only for the Losi products but many other car companies. That is why it is a car kit!
This new Losi - Type R sedan kit was one of the easiest Losi vehicles I have ever built. I was very pleased how this kit went together. It seems as though it will be an easy car to work on and change parts for tunning benifits. Kudos goes out to Losi on this one.... I can not wait to run this car.... The excitement is .... making me ......Yeah - LOSI! AAAAAAAAAaaaaahhhhhhhhhhhhhhhhhhhhhhhh!
Mike Dumas is offline   Reply With Quote
Old 08-17-2006, 10:46 AM   #100
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Mike, did you get a pre production car or is it one of the full prototypes like Todd's and Randy's that I've seen?
Jon Kerr is offline   Reply With Quote
Old 08-17-2006, 11:51 AM   #101
EricF's Avatar
Todd,
How many kits do you guys assemble before they ship to the distributors? 500, 1000?
Just wondering.
E
Old 08-17-2006, 12:09 PM   #102
Trader Rating: 45 (100%+)
Originally Posted by Juan Valdez
Yeah, foams are faster by a noticable amount. Some people just prefer racing rubber tires on sedans, no matter what the surface. I've done both, and for what ever reason I just like running the rubber tire class more. I can't explain it. Also, if I'm not mistaken, foam tires on sedans is a relativly new thing. I believe TC's were raced competitivly for a few years before foam tires were allowed. Also, the foam tire/carpet thing is mostly just the U.S. They're both cool to do though (so lets avoid the foam vs. rubber debates ).
We started racing Tamiya TAO1/Yokomo YR-4 sedans on carpet with foams back in '97 at The Track. I think we were probably one of the first tracks to start running sedans with foam tires back then. I remember when we had to mount foam on the rubber tire rims.
Apex is offline   Reply With Quote
Old 08-17-2006, 12:40 PM   #103
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
5. Spool Pads
7. No body
I like the sound of that.
I am actually hoping the same thing.. i hope the rear bulkhead has that option to run the tower/shocks leading or trailing.. Todd mentioned it may cause motor access problems... however from what i immagine the car to look like, from conversations with Todd, the motor will be accessable from the top. Just my interpratation of his words 6 months ago... things could have changed a million times... or I could just be way off.
I guess we will find out soon.
OUT
Keith Billanti is offline   Reply With Quote
Old 08-17-2006, 03:03 PM   #104
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Black anodized parts
Old 08-17-2006, 06:01 PM   #105
POOKYT's Avatar
Ditto on the No body-No tires or wheels. Heck if you guys don't have to pack a body in the box even it will cost less since it will be smaller!!!!!
Brant
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
