Old 09-09-2009, 09:46 AM   #10456
Company Representative
SweepRacingUSA's Avatar
Originally Posted by Greg Sharpe View Post
Just as I said, I use the aluminum hex adaptors but instead of sanding aluminum I simply sand down the hub (which is made from plastic).
wherer do you shave on a hub? if you just shave outside, it wont help.
only way that can be done on the hub is milled inside of hole where bearing sits in so bearings can get closer.
I trid plastic hexes last night and it is the way it should be, no grinding! I gguess I will need to stick with the plastic one for awhile.
GUYS TAKE OUT A HUB FROM THE CAR, MOUNT A WHEEL AS YOU NORMALY WOULD AND SPIN , YOU WILL FEEL ME.
SweepRacingUSA is offline   Reply With Quote
Old 09-09-2009, 11:28 AM   #10457
MikeXray's Avatar
Trader Rating: 73 (100%+)
I just checked my car, took the knuckle off the car completely and it spins fine. I have the stock lcds, one shim, unshaved face of the hub and alum hex. If I put too many shims I have made the bearings lock up, but that was easy to spot. I'm using losi bearings as well.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-09-2009, 11:32 AM   #10458
I have no shim at all, even a single piece shim in there makes thing locked up. if you turn the hub holding a wheel does hub spin back with gravity?
Old 09-09-2009, 11:36 AM   #10459
MikeXray's Avatar
Yes, its very free, as free as a bearing should be, valls brought up a good point, maybe you have a new batch of knuckles, or a bad batch? remind me on sunday and will give you 2 that I have that are older and see if it makes a difference.
Old 09-09-2009, 11:47 AM   #10460
Trader Rating: 21 (100%+)
Did you ever think it might be 'just' John and not the knuckles??????
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 09-09-2009, 11:56 AM   #10461
no I have old one from XXX-S (graphite) and new one EA3, I also have one that I borrowed from you at Jackson. they are all same it's not on hub, just look at the picture of it.
they drilled the axle too close. they drilled it closer than the XXX-S CVD, with XXX-S we only had to run 1 washer, never had any problem, with that much closer you can not run a washer, are you coming to SI this sunday? that s where i 'm gonna be at.
no Blue, with a brand new hex my wheel spins fine, after few run it get grindy, or locked. LCD, RCD all same.
Old 09-09-2009, 12:00 PM   #10462
MikeXray's Avatar
If I remember right you borrowed a rear hub from me, are you using lcd axles in the rear?
Old 09-09-2009, 12:02 PM   #10463
MikeXray's Avatar
Uhm, Pot calling kettle there???
Even if it is something John is doing, no harm in helping him figure it out here.
Old 09-09-2009, 12:09 PM   #10464
RCD on the rear, I think I found the problem. I ll be back after few more testing to prove it
BLUE! (I need a flaming face icon with blue color!)
Old 09-09-2009, 12:41 PM   #10465
Trader Rating: 17 (100%+)
Default O-RING SIZE
Anyone have the size for the differential carrier retaining o-ring?
billb60 is offline   Reply With Quote
Old 09-09-2009, 12:44 PM   #10466
Default Aluminium hex mystery on JRXS type-R Solved
Found a source of the problem.
I found out CVD, LCD axle hole got enlarged after 1 1/2 seasons of use. the hole on my axles are oval shape.
I just tried new set of LCD and no problem with a same hub, same BBs, all same old alum hexes.
but here is the kicker
I looked at my 8years old XXX-S CVD hole and they are fine, perfectly circled holes.
only thing I can think of it is XXX-S CVDs are made by MIP here in the USA, and I believe all this LCD and RCD's are made in Taiwan even thought all the packaging showing "made in USA" (old green color tag)
Losi once been sued for improperly used a “Made in the U.S.A.” label and lost, then they changed all their label to "Made in Taiwan" (new Grey color tag) you can read the settlement here
in my past experience American steel products are far stronger than one that from Asia and I think this is a same case too.
now if your wheels get grindy even with new set of BBs then you will need to go buy new axles for $14.00/pair which will last longer than $12.00/pair alum hexes.
drilling a hole closer on this soft steel axle made things worse and I thank Losi knows that.
Old 09-09-2009, 12:56 PM   #10467
1/2" Dia
Old 09-09-2009, 12:58 PM   #10468
MikeXray's Avatar
Good to see you found the problem. We'll have to take what we can get as far as quality, yes it may not be as good, but they are not $45 each like an Xray unit, and if they have to be replaced once every 1-2 years that's still getting a lot of use for the cost.
Old 09-09-2009, 01:18 PM   #10469
One thing that I want to add to my post is
I read once that old fashioned burger shop in DC refused to go franchise with big corp, the owner said " once this suit wearing corporation ppl take control they will try to save cost on everything and I know that will bring my burgers quality down, I ll rather stay in family own, operate business and keeping my quality for my customers.
This is a true story I read when Mr president Obama was picking up burgers from the burger joint and made to news.
I know when Losi sr own this joint this will never happened and if some goes wrong he will address right away like he did on XXX-4 front shock tower.
Old 09-09-2009, 01:55 PM   #10470
MikeXray's Avatar
You should by a TOP if you want that kind of service these days, Horizon/Losi are the Walmart/McDonalds of the hobby industry. Luckily the car has no major flaws, just some minor ones... I'm not saying it's right, but its the way that it is, and no amount of internet posts will change that.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
