Old 09-08-2009, 05:24 PM   #10441
Company Representative
SweepRacingUSA's Avatar
Originally Posted by MikeXray View Post
I find this interesting john, as I've had 2 type-r's and never had this issue even on foam. Are you using losi bearings in the knuckles? I almost always still need a shim behind the pin on my axles.
Mike take out the hub from the car and try rotate with a wheel on it, with or with out shims don't matter but with shim(s) are worse. you will see what I mean. I tried with genuine Losi BB and ceramics all same.
Originally Posted by vabroom View Post
http://www.rctech.net/forum/6318087-post174.html
Anyone in the know if there's any truth to this? You can still order it from Horizon, maybe they're trying to get rid of the last of them?
I dont know what hes been smoking but that stuff is toxic.
SweepRacingUSA is offline   Reply With Quote
Old 09-08-2009, 06:43 PM   #10442
Trader Rating: 21 (100%+)
New touring cars to come soon ??
Did you finish reading the other thread?
Already answered on that one.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 09-08-2009, 07:19 PM   #10443
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by John Tag View Post
I have found lightly sanding the back of the allum. hexes really helps solve the grinding feeling. After I started doing this there ultra smooth feeling now on front.......
I don't even bother sanding the aluminum hex adaptor, I simply sand the injection molding seam on the plastic hub. Takes two seconds with some light sandpaper.
I found this out swapping hubs between my Type-R and mid-motor JRXS, but it isn't a big deal.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 09-08-2009, 07:35 PM   #10444
so you use a plastic set? dont they pop out when you take a wheel out?
also waht do you mean by swapping between type-r and pro's hub? they are same hub, ain't it?
Old 09-08-2009, 07:40 PM   #10445
vabroom's Avatar
Nothing new posted, the only answer is the one I posted.
vabroom is offline   Reply With Quote
Old 09-08-2009, 08:01 PM   #10446
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default 17.5 jaco blue setup
I personally like a solid not twitchy car also. Little stable not on edge. I run 15 springs all around, High roll centers all around, 40/45 oil, 3mm droop over RH, Stock shock location,Ball stud w/inside top front,4/b rear link, .040 front and rear bars, 1* rear block, short rear and med front wheel base. 4Caster Blocks,Spool 41T, Rear Diff high, front 3/4 highw/41T. 104/50 REG speedo,112/47 With Timming Boost.
Just something to try...
Jon, I put the basic components on the car and liked the feel. oil is at 45/35 and inside lower front camber link. The car feels smooth. Took out 1mm front droop for more on power steering but the major difference is that I have a 42T one way in the car. Gearing was money. That's what I have in the car now anyways. Thanks for the setup, I though I'd give it a try since 1/2 our racers are in Vegas so tonight was a perfect night to practice.
Jaz406 is offline   Reply With Quote
Old 09-08-2009, 08:06 PM   #10447
YmeBP's Avatar
Trader Rating: 32 (100%+)
I posted, thanks for the heads up. Gotta love rumors .
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-08-2009, 08:21 PM   #10448
vabroom's Avatar
Oh by the way, YmeBP, what size teeth are the spurs and pinions on your website?
Old 09-08-2009, 08:39 PM   #10449
YmeBP's Avatar
48 or 64 on the spurs. 64 only on the pinions. The pinions are a sight man .. these things are sweeeeet!!
Old 09-08-2009, 09:30 PM   #10450
vabroom's Avatar
Sorry, I should have wrote it this - Your site doesn't seem to let you choose how many teeth you want.
Old 09-09-2009, 12:19 AM   #10451
Same here... I always use the shims to get rid of play. Its possible you have bad bearings although if there are a few of you with the same problem then that is less likely. I'll have a closer look myself during my next rebuild.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-09-2009, 03:19 AM   #10452
John Tag's Avatar
Trader Rating: 42 (100%+)
I do that also...I take away about .3mm off face of hub where outside bearing is. When completed the outside bearing shoulder is slightly exposed...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-09-2009, 03:21 AM   #10453
John Tag's Avatar
Glad ya liked it..I also run lower inside link in front outdoors..I love the extreme high speed steering it gives....
Old 09-09-2009, 05:38 AM   #10454
Just as I said, I use the aluminum hex adaptors but instead of sanding aluminum I simply sand down the hub (which is made from plastic).
And yes, the hubs on the Type-R are the same hubs found on the original JRXS mid-motor chassis, but I didn't assemble my Type-R, so I didn't notice the difference in pin location until recently.
Old 09-09-2009, 08:36 AM   #10455
YmeBP's Avatar
Yes, I'm working on that, sorry about that I should have that updated tonight. This store software takes some work to get things just right . I still have broken images and such all over the place and some of my ordering options are not showing up the way I intended ... work in progress but i'll get that updated tonight.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
