Old 09-03-2009, 09:54 PM   #10411
fastzach's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to fastzach
Hey guys, i am building my kit now, and the diffs act like they dont tighten down all the way. the screw doesnt seem to thread far enough into the plastic outdrive. It says to tighten diff until slight resistance is felt, but it looks like its about a 1/4 inch from even being tight. theres still slack between the outdrive and the pulley.
what gives? surely it isnt normal
fastzach is offline   Reply With Quote
Old 09-03-2009, 10:05 PM   #10412
fastzach's Avatar
never mind, i figured it out. just have to really give it hell to get the diff tight
Old 09-03-2009, 10:45 PM   #10413
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by MonkeyFist View Post
I bought a Tekin Redline system for my JRXS and I can't get the motor to fit. I have a Losi 90 tooth 48p spur and a 37 tooth pinion. I shaved some off the inside of the left side rear hinge block, but it seems like I'd have to take a lot more material off to get it to fit. Does any one have this motor in their car? can I see pics of the hinge block? I'd hate to have to take plastic off the back of the motor. Just for giggles I tried to fit a Xcelorin motor inn there as well, it fits, but just BARELY. If I hadn't removed the material to try to fit the Redline motor in I doubt that the Xcelorin would have fit either. Are all brushless motors going to be a tight fit in this car?
I have it in my car, it fits nicely once the block is shaved down. you don't have to shave the whole face down, just the part that intrudes into the motor bay. I would need a new block to change my roll center though. I picked up a couple different sized spurs to fit my FDR needs, but I can get 6 or 7 different pinions on before I need to swap out spurs. I have 41 to 52 pinions and 110, 114 and 118 PRS spurs.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 09-04-2009, 02:06 PM   #10414
jkirkwood's Avatar
Will be hitting the asphalt for the first time with the car this weekend. Been running alot of rubber tire on carpet. Perhaps the setup will transfer with just a few changes.
jkirkwood is offline   Reply With Quote
Old 09-04-2009, 02:19 PM   #10415
I'm not sure what I'm going to do yet. I may just keep the ESC and use a different motor. The ESC is the best part of the system anyways.
Nice paint JKirkwood. Did you do that yourself?
MonkeyFist is offline   Reply With Quote
Old 09-04-2009, 02:33 PM   #10416
jkirkwood's Avatar
Yes. I can't take all the credit. Skipgear designed the paint scheme about 9 years ago for me that I've used since. I've just learned (with his permission) on how to paint it.
Old 09-04-2009, 04:08 PM   #10417
Company Representative
SweepRacingUSA's Avatar
Very nice & Unique. GJ
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 09-04-2009, 08:57 PM   #10418
MaxRain's Avatar
Has anyone considered using these with the plastic tray? I think this would give more flex for those who are looking for it..
http://www.rc-mushroom.com/product_i...ducts_id=16802
Gordon
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://youtu.be/owXBpsQkyjE
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-04-2009, 11:02 PM   #10419
rocketron's Avatar
With the new lower weight limit I run the plastic tray and my car comes in at 1418grams ready to set down on the track and its balanced. Just need to add a small bit of weight to get up to 1425
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 09-04-2009, 11:06 PM   #10420
Yeti35's Avatar
Where were you last Saturday? I was at Bending Corners pretty much all day!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-05-2009, 08:50 AM   #10421
Trader Rating: 21 (100%+)
Default Type R For sale
Losi Type R, SP 1.1, Radio Bag, Core & Imax B6 chargers +
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 09-05-2009, 09:38 PM   #10422
jkirkwood's Avatar
Car was great today on the asphalt. First time on an outdoor track for about 8 years. Took the TQ & A-main win. Only changed a few things from my carpet setup. Could had maybe needed a little more steering entering the turn but it got better all day as I got use to how the spool wanted to be driven. Probably would had been faster win a one-way after seeing the track but not sure if I would had of been as consistent.
Old 09-05-2009, 10:29 PM   #10423
MaxRain's Avatar
Default diff
Recently there has been discussion about diff building so I decided to try something different by taking the cage that holds the diff balls on the thrust bearing. I then took extra balls and put them between the two washers with finish line teflon grease.
Then I use associated diff lub #6591 on the pulley and tighten it up. One mod that I have done to improve the tightness was to take a 4-40 nut, grind the edges down, slide it in the hub, result, no more stripping/coming loose.
I find that the balls don't have an opportunity to grind thru the cage now that it is gone and it is much smoother now than ever. One thing I did notice that on the front diff, the front right wheel would stop sooner than the left when applying brake. To remove this symptom, I tightened it up a little more and it went away.
The only problem I see with building the diff this way is the potential to loose the thrust balls when you do a rebuild. Other than that I am much happier with this method.
Gordon
Facebook: CARCAR
Old 09-05-2009, 10:58 PM   #10424
rocketron's Avatar
Old 09-06-2009, 02:53 AM   #10425
Spillertwo's Avatar
Hello MaxRain,
Interesting stuff you are talking about but what do you mean when you say "taking the cage" ?
Maybe you could post some pictures of the mod to make it clear ?
Still looking myself how to make these diffs good and last longer.
Spillertwo is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
JUNI, tobyzhang
SEO by vBSEO 3.5.0
