Old 09-02-2009, 09:18 PM   #10396
Company Representative
SweepRacingUSA's Avatar
Originally Posted by MaxRain View Post
I use this with the regular rod ends with no problem. what I like most about the studs is that they are longer than the Losa6026. When you put them on, the are flush with the bottom edge of the c-hub. Only downfall is that you have to use the losi wrench to screw them on and off. Other than that, they work great.
I dont use a LOSa6026 either that thing is too short, I made my own i thought you saw that on my blog?
SweepRacingUSA is offline   Reply With Quote
Old 09-02-2009, 09:41 PM   #10397
Trader Rating: 21 (100%+)
Hey John .... I've got my R up for sale if you anyone.
Blue
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 09-02-2009, 09:48 PM   #10398
MaxRain's Avatar
I did, however I found these studs in my tool box and decided to try them out. I was suprised with the result as it removed lots of slop.
Have you downloaded the roll centre calculator for the type-R. This may help solve the tire situation, Re Paul L.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-03-2009, 05:47 AM   #10399
Trader Rating: 68 (100%+)
On PRS i was looking for the gear adaptor,it does not show the type r are they the same adaptor?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 09-03-2009, 05:56 AM   #10400
nitrobeast's Avatar
Trader Rating: 41 (100%+)
http://www.precisionracingsystems.com/products/18
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 09-03-2009, 06:20 AM   #10401
Yeti35's Avatar
They are the same. Nothing different about the original car and the R in the area of the adapter.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 09-03-2009, 07:46 AM   #10402
Blue
I See you want to sticking with the Oval in NC, good luck sir!
yes I do have that program but IMO camber rod giving me too much camber gain when I had to run 1.5-2 deg static camber with the Jaco blue.
I have a RPS adaptor for sale, if you need one lemme know 1/2 price from brand new incld mailing! wow!
Old 09-03-2009, 07:56 AM   #10403
i will take it sir
SpeedZone Batteries
Old 09-03-2009, 08:10 AM   #10404
i will take it sir
TY YGPM
Old 09-03-2009, 02:56 PM   #10405
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Setup theory
17.5 carpet rubber tires "blues"
Been playing around with front roll centers a lot this past week. I was fighting a car that was "twitchy" and went from super high roll centers +.050 high to +.030 low in a few days and found that the car wanted softer springs with high roll centers and stiffer springs with lower roll centers.
Also it looks like the JR link forces grip on the outside edge of the tire and not the inside like the ball stud setup?
Anyone found the same things?
Jaz406 is offline   Reply With Quote
Old 09-03-2009, 03:12 PM   #10406
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Hey guys. I'm lookin to sell off my BMI Type R. Its only every raced at one big race(Snowbirds and it was in the A-main) so it's pretty much brand new. PM me if your interested. I will be posting it on For sale thread soon just wanted to give you guys first shoot.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 09-03-2009, 05:59 PM   #10407
Default Brushless motor fitment.
I bought a Tekin Redline system for my JRXS and I can't get the motor to fit. I have a Losi 90 tooth 48p spur and a 37 tooth pinion. I shaved some off the inside of the left side rear hinge block, but it seems like I'd have to take a lot more material off to get it to fit. Does any one have this motor in their car? can I see pics of the hinge block? I'd hate to have to take plastic off the back of the motor. Just for giggles I tried to fit a Xcelorin motor inn there as well, it fits, but just BARELY. If I hadn't removed the material to try to fit the Redline motor in I doubt that the Xcelorin would have fit either. Are all brushless motors going to be a tight fit in this car?
MonkeyFist is offline   Reply With Quote
Old 09-03-2009, 06:20 PM   #10408
Losi, Trinity fits fine, Tekin need to shaved that plastic off in most case.
Old 09-03-2009, 06:43 PM   #10409
Trader Rating: 33 (100%+)
I have a Tekin 10.5 I had in the car and I had to shave down the aluminum block so it would fit. I have since gone to a Fantom Duo 10.5 and it seemed to drop right in.
Pete720 is offline   Reply With Quote
Old 09-03-2009, 07:01 PM   #10410
John Tag's Avatar
Trader Rating: 42 (100%+)
I personally like a solid not twitchy car also. Little stabe not on edge. I run 15 springs all around, High roll centers all around, 40/45 oil, 3mm droop over RH, Stock shock location,Ball stud w/inside top front,4/b rear link, .040 front and rear bars, 1* rear block, short rear and med front wheel base. 4Caster Blocks,Spool 41T, Rear Diff high, front 3/4 highw/41T. 104/50 REG speedo,112/47 With Timming Boost.
Just something to try...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
