Old 08-20-2009, 03:34 PM   #10261
Originally Posted by da_John_wee View Post
no way!! is that what he did?
I did nothing it was late and I stopped there thinking that I must be missing something. I'm going to trim the tubing shorter and see how it goes.
MonkeyFist is offline   Reply With Quote
Old 08-20-2009, 10:40 PM   #10262
I use a hobby knife and trim around the edge of the LCD tube section. From my experience that is all you need to do and everything will go together with no mods required.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-21-2009, 08:37 AM   #10263
sportpak's Avatar
Trader Rating: 26 (100%+)
Is there any good pics of the "flex" mod available? I'm interested but haven't seen any pictures yet.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 08-21-2009, 09:01 AM   #10264
Company Representative
SweepRacingUSA's Avatar
1-2mm is all it need
attached
Team Losi JRXS Type-R-fri-losilucasurbain-1.jpg   Team Losi JRXS Type-R-fri-losilucasurbain-3.jpg
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 08-21-2009, 09:05 AM   #10265
Default Robinson spur
Hey guys
did any one tried a Robinson spur on the FLyingfox center shaft yet?
like this one?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEZ15&P=7
can't get no RW gears no more around me, I used Kimbrough in last race but it only last a day or two.
Old 08-21-2009, 09:11 AM   #10266
jrxs-r's Avatar
Hey guys
like this one?
From memory it doesn't fit. Don't quote me on that though. The PCD of the bolt holes are entirely different. If you can get hold of HPI spurs, the kevlar ones are very durable, and I use them on asphalt.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 08-21-2009, 09:16 AM   #10267
jrxs-r's Avatar
Paul,
Got the spools, battery stay replacements and the shaft hardware! Thanks for that! Will try them out on carpet and asphalt soon!
Cheers,
Zack
Serpent S411
Old 08-21-2009, 09:22 AM   #10268
HPI makes kevlar spur? do you have a part number or link for that? nothing in the Tower
Old 08-21-2009, 09:22 AM   #10269
vabroom's Avatar
Hey guys
like this one?
Not an answer to your Robinson spur, but Nexus sells RW spurs and they should fit:
http://www.nexusracing.com/index.php?cPath=145_321_322
vabroom is offline   Reply With Quote
Old 08-21-2009, 09:32 AM   #10270
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Hey guys
like this one?
Robinsons will work fine. I have some robinsosns with 6 holes, the one you have a picture of seems to have only 2??. I can't see a problem with using only 2 screw though.
Other gears that fit are XRAY and XENON/HPI. PRS will work if you drill out the the holes one size bigger.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 08-21-2009, 09:33 AM   #10271
YmeBP's Avatar
Trader Rating: 32 (100%+)
Hey guys
like this one?
I use robinson on my type-r's and they work great, kimbrough also works and i've used prs as well. I like the robinson the best so far.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-21-2009, 09:39 AM   #10272
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I use PRS spurs and pinions, they work perfectly.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-21-2009, 09:45 AM   #10273
thanks for the input guys,
well here is the issue I have, my local track/shop closed thier door in last spring. that s where I got all my supply incld spurs
then my new supply (on-line) only carries Kimbrough and ribonson, wasnt sure bout Robinson's hole so I got K gears last week ran it at Xray, it s all chewed up already.
and I'm getting a Tekin ESC which requires lot bigger spur gear to make FGR lik 6.25.
so I gotta get spur gear that could work with my car, I dont want to order several and found nothing fits or some...
I already have more than 5 Losi spur gear doing nothing here.
Pablo can you make a center shaft for Losi spurs? more and more ESC's coming with boost timing that will increase RPM that need bigger spur gears.
man trand of everything makes big revolution and come back to us ...always..
Old 08-21-2009, 09:53 AM   #10274
Tory, Robinson you used is that the one with 2 hole inside? then you use 2 screws to mount a spur?
I cant find one with 6 inside hole for Robinson, if you can pass me a part #?
thanks
Old 08-21-2009, 10:07 AM   #10275
YmeBP's Avatar
thanks
Yes i use the 2 hole ones, but they also have 6 or 8 holes around the outside as well. I just use the 2 holes on the inside.
I use 111 and 115 from this page:
http://www.robinsonracing.com/catalog/64pitchspur.html
Why would you need 6 holes? more rotating mass. Actually I'm sourcing some short titanium screws and short aluminum screws so we can reduce rotating mass even further.
You really only need 2 screws.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
