Old 08-18-2009, 02:59 PM   #10231
Trader Rating: 64 (100%+)
What deck braces are you talking about?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 08-18-2009, 10:27 PM   #10232
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
The rear pair I believe. But it was hinted at earlier.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 08-19-2009, 12:41 AM   #10233
S_fender's Avatar
Hello,
Lucas Urbain Euro setup sheet :
http://www.petitrc.com/reglages/losi...802/index.html
S_fender is offline   Reply With Quote
Old 08-19-2009, 08:31 AM   #10234
Originally Posted by S_fender View Post
Hello,
Merci!
Per the pictures in the link, both sets of supports.
John Higgins
Old 08-19-2009, 09:03 AM   #10235
JRXS_chris's Avatar
How's Lucas's droop being measured?
JRXS_chris is offline   Reply With Quote
Old 08-19-2009, 09:48 AM   #10236
Company Representative
SweepRacingUSA's Avatar
Hello,
picture from Redrc.net show Lucas had 1deg rear pivot to make total of 2deg, set up sheet of petit and Losi.com need to be adjusted, I ran very simulate set up last weekend worked great!
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 08-19-2009, 09:50 AM   #10237
Total down travel - riding height = Droop
Old 08-19-2009, 10:03 AM   #10238
Do you run uptravel limit on your rig? (the screws are there on mine, but backed out to the point of being useless) Or just sway bars?
John Higgins
Old 08-19-2009, 10:40 AM   #10239
it all depend on the track barrier and traction
if the track have a wooden barrier or CRC barrier (walls) and have good amount of traction then I limit 1mm-2mm of uptravle.if track use road dome or cement zebra as barrier/ low grip then I just removed those screws.
Old 08-19-2009, 10:57 AM   #10240
l.urbain's Avatar
I suggest you to always use those screws. At the Euro I used a lot of ground clearance (3mm above ride height) but usually I run it around 2mm. Less droop gives usually more corner speed as the car takes less roll. Droop is a good way to set the way the car rotates around corners (rear droop) and the way it will exit (front droop).
l.urbain is offline   Reply With Quote
Old 08-19-2009, 11:00 AM   #10241
hey Lucas
he s asking about up travle limiter screws, one that on inside pivot of arms. I dont think you had that on your car at ETC, did you?
also can you clearfy rear pivot degrees? 1 deg block as pictured right?
Old 08-19-2009, 11:08 AM   #10242
hey Lucas
Exactly, the ones inside the pivot located on the extension that the sway bar snaps onto.
John Higgins
Old 08-19-2009, 11:21 AM   #10243
MikeXray's Avatar
Trader Rating: 72 (100%+)
Do these flex mods add rear traction? My type-r was good in 17.5 with the exceptions of quick transitions and getting on power the rear end would to come around, otherwise the car was a bit pushy. The car had excellent highspeed steering.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-19-2009, 11:42 AM   #10244
yes, even on 13.5 I had a traction and half. my car actually had too much steering I had Paul Leumix worked on my car to get rid of some initial steering.
happend to be too much FR camber and diff being too tight.
try that mod for ashpalt you'll like it
Old 08-19-2009, 02:18 PM   #10245
l.urbain's Avatar
hey Lucas
OMG ! I'm sorry I badly understood :s
For my defence I'll say that I'm french -__-'
No I've never used those screws (because I've never tried).
Yes you are right, I used a 1deg block at the euro and 0deg hub, so 2deg rear toe.
Mike : I basicly did the flex modification to get more steering. In fact it gave me more stability at corner entry, more mid corner steering, more overall grip and a little bit less corner speed. It's usually faster like this (up to 2/10 a lap).
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
