Old 08-12-2009, 08:31 AM   #10186
jrxs-r's Avatar
Originally Posted by Pablo Diablo View Post
I'm finishing them of as we speak. I will PM you today. Spool on carpet sounds interesting. Do you guy run traction compound or is that not allowed.
Unfortunately traction compound is not allowed at all. With a good base setup like Mike Hayne's spool on rubber/carpet and adjusting from there to suit my driving style and traction conditions, it is actually a tad quicker than running with a diff. The track is small (1x legal basketball court), and has a very technical section. The spool helps pull it out of the corners better, and allows me to dive into the corners a fair bit quicker than my last setup did.
I've been running for about 3 club meets on the new setup and am happy with it. Will be experimenting a little more though.
Didn't think it would work... but I am glad I tried it.
On another note.... anyone here uses Sweep24s on carpet? Tried it tonight, and I quite like it. Have used Sorex 20r and 24r prior, and it seems to 'polish' up after a few meets. The Sweep24s seem to stay a bit more consistent and they don't get that 'shine' on them at all. I'll give it a few more weeks, and see what happens. Will be trying the Absolutes 24s sometime to compare as well.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 08-12-2009, 09:17 AM   #10187
jkirkwood's Avatar
Originally Posted by Dragonfire View Post
I tend to find that incidents are more a result of bad driving than bad setup. That said accidents do happen.
QFT
My brother was doing some testing with flex and top decks and managed to shatter the lap record. Although this wasn't a losi it is getting me interested in gutting out my deck.
I have prepared a top deck but haven't had time to do some controlled practice and get the results. Tekin threw out the software update this week so my priorities are learning that first.
jkirkwood is offline   Reply With Quote
Old 08-12-2009, 01:44 PM   #10188
tim fry's Avatar
Unless the track is really tight a spool is always quicker with rubber tyres. I would use Sorex 28s they work really well and we adopted them as a control tyre as they worked so well. Anything softer seems to go off midway through the race. We used to use the Vtec 24s and these were ok but began to snatch and give grip roll as the grip came up so we had to keep glueing the outer edge of the fronts. Sweeps are ok ish but Sorex work alot better
tim fry is offline   Reply With Quote
Old 08-12-2009, 02:00 PM   #10189
jkirkwood's Avatar
Tim, how many weeks are you running the Sorex 28s on carpet before they slow down too much to be competitive?
Old 08-12-2009, 02:08 PM   #10190
tim fry's Avatar
In 13.5 most people are getting 5 - 6 meetings at club level and in 10.5 about 4 maybe 5 depending on driving style. Most of us use 2 or 3 sets in a 12 meeting series as long as they dont get damaged. This is at club level though.
Old 08-12-2009, 06:15 PM   #10191
jkirkwood's Avatar
Tim, Thanks for the feedback. I've was getting slightly more than that with the Sorex 28s but running 17.5 at the club level. For a trophy meet I would expect to use a new set.
Old 08-13-2009, 06:13 AM   #10192
MikeXray's Avatar
Trader Rating: 73 (100%+)
A little tip when building type-r shocks, when I got my phi everyone told me to put the bladder in and push in the center with the back of an xacto before putting the cap on. I did this with my type-r bladders and it helped, I think its the first time I had that "vacuum" rebound where it would pull the shaft back in as well as rebound out.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-13-2009, 08:06 AM   #10193
I tested this last weekend and could not pick the difference although it is a track that has that trait. Full rebound vs zero both produced 17.2 second laps with the same feel. Mayb I need to run more droop to see a difference.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-13-2009, 08:40 AM   #10194
MikeXray's Avatar
I don't know if would be a performance thing yet, for me it just made me get 3/4 shocks right the first time vs 1/4
Old 08-13-2009, 11:28 PM   #10195
I'm thinking that the difference will be when you run enough droop to have "loose" springs at full droop. Currently I am only running 2mm all round as it is giving me fantastic brakes and throttle and a very neutral feel.
Powered by Falco
Old 08-14-2009, 06:28 AM   #10196
Yeti35's Avatar
I tried this method last night while building the shocks for my new rubber car for IIC. It works great and all the shocks appear to have even rebound. I applaud who ever came up with this idea for I struggled getting even rebounds when building shocks as well. I will remember this tip from now on.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-14-2009, 07:23 AM   #10197
liljohn1064's Avatar
Trader Rating: 17 (100%+)
My spool made it yesterday. Awesome product! I'll get it in tonight or tomorrow. I like the set of stickers that came with it.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-14-2009, 09:23 AM   #10198
Anyone try a fantom battery in their rig yet?
Old 08-14-2009, 09:35 AM   #10199
Trader Rating: 69 (100%+)
yes 5000,40c fit perfect
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 08-14-2009, 09:58 AM   #10200
YmeBP's Avatar
Trader Rating: 32 (100%+)
Fits like a glove, I run fantom stuff top of the heap same numbers as the thunder powers.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
