Old 07-26-2009, 10:15 PM   #9946
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by Pablo Diablo View Post
Here are some pics of a production spool. Its about 1gram lighter than the prototype. Its lightened on the inside rather than the outside like the prototype. All testing has gone very well. Should be available in 1 week.
put me on the list for one!
vr6cj is offline   Reply With Quote
Old 07-26-2009, 10:52 PM   #9947
Company Representative
SweepRacingUSA's Avatar
sweet!
would it be available by Aug/15/2009 in US? we having a Xray race at out local track on that date, I like to pick up 2 set from tory and run on same day if possible.
good job
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 07-27-2009, 12:35 AM   #9948
I am lucky enuf to have the spool pictured here in my car right now. Took it for a run over the weekend on asphalt with some foamies on. Couldn't really pick much of a difference in handling between the standard setup and the new spool but it did however have much better brakes! I guess I may not have had the slipper setup tight enuf but my brakes were noticeably better between 1st (kit slipper) and 2nd (flying fox spool). It was also quite a bit lighter as mentioned before so more weight over front for better balance. As I run mod I can't tell you if it accelerated faster as mod is always quick but it should improve your 17.5t performance slightly too.
Just a note guys that the spool requires 2 x diff outdrives for you to use it so you will need at least one spare when you get it. Other than that it simplifies your front end so you have less to worry about and also less things that can go wrong and ruin your run.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-27-2009, 06:08 AM   #9949
Chrissy C's Avatar
Hi , a quick couple of questions for you...
1) Could you use the the new Type R diffs with the JRX-S plastic transmission housings?
2) Is it possible to simply buy the Type R pivot blocks and longer wishbone set up and bolt them directly on to the JRX-S chassis?
Thanks fellas!
Chris
Chrissy C is offline   Reply With Quote
Old 07-27-2009, 06:35 AM   #9950
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by joey View Post
this is the site you would get the thrust bearing from, as for size i cant remember its been awhile since i ran a losi...
http://www.mcmaster.com/
I have these thrust bearings in my car Goetter put me onto them, they are FANTASTIC!!! I've rebuilt my diff a couple times, and put probably a whole season on this car and it looks new!
I will have the correct thrustbearing for the Losi listed on my website in about a week. I will also have ones for gas cars as well.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-27-2009, 06:38 AM   #9951
YmeBP's Avatar
I will have one of these outdrives as part of the kit I have a bunch of them on the way already.
Old 07-27-2009, 06:49 AM   #9952
YmeBP's Avatar
Originally Posted by tim fry View Post
All I'm having rear diff issues and cannot seem to get it as smooth as I'd like. I have bulit many diffs over the years so its not not a lack of skill. I seem to remember there was some good advice way back but after ages looking through the thread I cannot find it. Can anyone help.
Originally Posted by da_John_wee View Post
that s da company! I think this is the part http://www.mcmaster.com/#7806k53/=2x8js3
oh BTW Joey!
YOU TRAITOR!
This was the post with the spool instructions : http://www.rctech.net/forum/6001473-post9779.html
replace the spool pully w/ diff and diff balls: I use the clearish silicon diff lube on the rings, and i use the Losi dark reflective spekly thick goop on the thrust bearing (and use that thrust bearing).
I have to rebuild one of my diffs soon so i will take photos step by step and post them, probably this coming weekend.
Old 07-27-2009, 07:14 AM   #9953
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
sweet!
good job
They should be stateside well before then. They are about 48hrs from leaving OZ. The rest will be up to my favourite people at Australia Post!
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 07-27-2009, 08:03 AM   #9954
jrxs-r's Avatar
Nice work there Paul... LMK when you have them ready to go!
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 07-27-2009, 08:20 AM   #9955
You still running a spool? I thought you were running a front diff. Anyway I'd be happy to send you a spool.
Paul H
Old 07-27-2009, 08:22 AM   #9956
jrxs-r's Avatar
Paul, I've been giving the spool a go on Asphalt, and it took a little while to get used to....
I'll send you a PM towards the end of the week... You got my last one?
Cheers,
Zack
Serpent S411
Old 07-27-2009, 08:23 AM   #9957
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
i want one....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 07-27-2009, 08:42 AM   #9958
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by mr. losi View Post
i want one....
M, let me know when you order. Maybe Jim will want one too and we can save on shipping. I've already picked up and installed the layshaft on mine.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 07-27-2009, 11:07 AM   #9959
can you make 2 out drive a set with the spool? I want to start with fresh set of outdrives and keep a old one for spare.
Awesome!
Old 07-27-2009, 11:04 PM   #9960
MaxRain's Avatar
Default thrust bearing
Can someone post a picture of the thrust bearing available from McMaster. Are they built similar to the Losi stock one?
Gordon
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://youtu.be/owXBpsQkyjE
Facebook: CARCAR
MaxRain is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
