Old 07-14-2009, 04:46 PM   #9841
John Tag's Avatar
Trader Rating: 41 (100%+)
Originally Posted by da_John_wee View Post
Lemme rephrase...
not after "few weeks".... I had these hexes for about "a year" I do have all three thickness and sometime thinnest one scratch bubs by that screw from beggining. and other thicknesses start having "digging" problems
thanks for the input but like It showed on the title the problem is for those "Aluminium" one
I didnt tried stock plastic one yet.
it may spin good on the hex but if you disassemble a hub carrier and tighten a wheel with a nut as usual, you might have one or two "crushed" feeling one that bind on spin.
thats how I test my Ballbearings since I found digged alloy hex on my car.
I dont think I crushed those nuts too far, I tried with brand new BB and result are same for the "digged" hex.
try spin a wheel ike I said above, you might find surprise for yourself.\
anyway. any fix or solution for this.? or any one had same problem like mine?
I have had this issue in past.. It was a weak hex in genral. I replace with new hex and was perfect again.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 07-14-2009, 05:26 PM   #9842
Company Representative
SweepRacingUSA's Avatar
hmmmm thanks
I m going to try AE one next week hope this one last, any one know thickness of this hex?
or do I need one that made for TC5? (ASC31234)
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 07-14-2009, 06:02 PM   #9843
Yeti35's Avatar
I skimmed right over the title. Sorry about that. I personally have not had an issue with my hexes, but I don't mash them down when I tighten them on the axle either. Not sure how you are gouging out the slot in the hex where the pin goes.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-14-2009, 06:15 PM   #9844
i thinnk axle pin keep digging in to a hex every time I do side impact or over tighten that Rear right wheel nut (one that get loose all the time)
instead of tighten that nut harder, I ll just just replace that 4mm nuts more often
Old 07-14-2009, 11:00 PM   #9845
RussB's Avatar
Send a message via MSN to RussB
quick question... do the trinity 3800 packs fit the steel lipo tray and clear the belt pulleys?
RussB is offline   Reply With Quote
Old 07-15-2009, 04:16 AM   #9846
John Tag's Avatar
This is nuts I use, Xray sells them also in silver ... There not as tall so there better with cut axles also,There serated so they hold wheel a ton better and soo easy off and on....Jason and Larry turned me on to these right away...
Old 07-15-2009, 06:43 AM   #9847
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by Pablo Diablo View Post
I'm not far from showing you all my next part for the Type R!!!
Originally Posted by JRXS_chris View Post
Looking forward to seeing this!
Any clues?
Hows this for a clue. Its just a prototype so expect the production version to look a bit better.
No more sliping spools! It uses the the Losi clip in outdrives on both side so changing will be quick and easy, it will save some rotating weight and the pully runs true unlike the kit setup. I have to test it now to be sure it is unbreakable.
Team Losi JRXS Type-R-imgp4269a.jpg   Team Losi JRXS Type-R-imgp4270a.jpg   Team Losi JRXS Type-R-imgp4271a.jpg   Team Losi JRXS Type-R-imgp4272a.jpg
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 07-15-2009, 06:49 AM   #9848
wyd
Tech Legend
wyd's Avatar
Trader Rating: 49 (100%+)
Send a message via AIM to wyd
Yeah GOAT and Schreff told me about those type of wheel nuts as well. I bought a pack from GOAT that TOP has and never ever a loose wheel again (except behind the wheel ). Very easy to tighten up and just as easy to loosen. Actually want to buy a few more packs because they work great. Wish I would of had these over the last few years and it would of saved me alot of grief!!!!!!!!!!
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-15-2009, 06:52 AM   #9849
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
No more sliping spolls! It uses the the Losi clip in outdrives on both side so changing will be quick and easy, it will save some rotating weight and the pully runs true unlike the kit setup. I have to test it now to be shure it is unbreakable.
I need one of those and the new rear shaft. Let us know when they are ready to sell.
Edit: Lay shaft has been ordered. Can wait to see the spool!
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 07-15-2009, 07:07 AM   #9850
I will do. The Layshafts are in stock at Skyrocket Batteries if you want one now. Sould be around 2 weeks untill I have production spools.
Paul H
Old 07-15-2009, 07:19 AM   #9851
Like these? Special Threaded Locknuts Just asking as this is what my LHS can get in stock for me.
Old 07-15-2009, 07:23 AM   #9852
Oder completed, Ship it! This will be my first real attemp at touring car. I've run a couple of races, but haven't really taken our 13.5 class seriously. I'm hoping our track does a 17.5 Novice/Sportsmans class.
Old 07-15-2009, 07:51 AM   #9853
jkirkwood's Avatar
That's great I was hoping you would be making one. I'll order one as soon as skyrocket lists it on the website.
jkirkwood is offline   Reply With Quote
Old 07-15-2009, 08:03 AM   #9854
YmeBP's Avatar
Trader Rating: 32 (100%+)
Got your order it will ship ASAP!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-15-2009, 08:09 AM   #9855
jkirkwood's Avatar
Question for you gentlemen.
I've been running a 21.5 touring class this summer because all the 17.5 guys have taken the summer off. The tires we use are the Vintage spec tires but we allow any body as long as it's not a race specific touing body. The goal of the class is to have it look realistic and be slow enough for new guys.
I've been running a one-way and am faster with it over the diff by .3 sec per lap. It's fun to drive but with the one-way there is one hairpin corner I really have to be careful on which is located at the end of the strait. I usually us my 2wd off-road skills and just drift the car into the first corner. I'm estimating a loose of time of about .5-.1 sec loss by not being able to break hard into that corner. Keep in mind that I'm still quite a bit faster with the one-way over the diff.
Has anyone sucessfully got the spool to work with lowered power cars? I was going to try try it next time out but was just wondering if anyone else has had any experience with it.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DesertRat
