Old 07-13-2009, 10:20 AM   #9826
Cirrc's Avatar
Default To buy or not
Hi all,
Just wanted to know if it still makes sense to buy the JRX-S type R.
I've always like the philosophy behind the design (centred battery esp), but have held back because of parts shortage where I live.
My question is, is the JRX-S type R still competitive with the latest TC offerings?
Also, will Losi come out with a new TC anytime soon? (Don't want to buy the type R then have it become 'obsolete' soon after I buy it)
Cirrc is offline   Reply With Quote
Old 07-13-2009, 10:50 AM   #9827
Trader Rating: 21 (100%+)
Originally Posted by Cirrc View Post
Hi all,
I've had a Type R for 2 years and love it. To my knowledge Losi is not coming out with a new version.
Parts are easy to get here in the US.
Still competitive, yes very much so.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-13-2009, 11:41 AM   #9828
YmeBP's Avatar
Trader Rating: 32 (100%+)
Hi all,
The car is extremely competitive, parts are available at a MUCH lower price than some competing brands there is a growing aftermarket as well for the areas that do need a little tweaking, which there aren't many.
I have a couple I run on a weekly basis, my son is 10 and I switched him from a TC4 factory team w/ carbon upgrades to a Type-R and he was 3 laps faster and has moved up to 13.5 from a 21.5 and has yet to break a part on his car (he's 10!! and can barely see over the rail on the driver's stand hahah).
The tracks in my area the Type-R is constantly the top or near the top of the finishes in Vintage, RCGT and 13.5 Touring.
Hard to beat it in today's crowd of cards.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-13-2009, 03:22 PM   #9829
There are many fast cars on the market but when you add up all the pro's and con's I would say it is hard to look past the HPI cyclone as the best AVERAGE TC on the market. That said I choose the Type R over it almost 6 months ago now and have not regretted it. The chassis performance exceeds that of the assumptions I made looking at the chassis and I am finding it to be easily the fastest TC I have ever had (asphalt/rubber/mod) and that is a decent list including offerings from Tamiya, Associated, Xray, and TOP. It has a proven record on foam so you will have no problem adapting it to your conditions.
Its biggest weakness is its diff if you run high power (like mod and 10.5 to a smaller degree) and lipo fit (which is almost non existent now thanks to Flying Fox RC). It also requires a small amount of creativity to install electronics to give you a good f/r balance as its layout was designed to suit nimh/brushed instead of lipo/brushless making it rear end heavy with batter and motor and servo installed.
It has the advantage of coming standard with some of the best ideas on the market like dual pivot front CVDs (LCD's) which are now being copied by other companies. It cost less than $10US for the front spool pulley to give you a slipper spool which is simply the best version of spool the is. And as said above parts are cheap. Almost all replacement parts cost less than $10US and have proven to be generally strong. Also Losi still support older generations of TC so parts will be around for years.
In short it is hard to look past.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-13-2009, 03:39 PM   #9830
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
+1 to that
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 07-13-2009, 04:01 PM   #9831
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 07-13-2009, 04:35 PM   #9832
Yeti35's Avatar
I have three and am currently building my fourth. I just wanted a new rubber car for IIC this year. My foam car never sees asphalt and I have a rubber car with a new chassis that has not seen asphalt either since the chassis change. I have one car dedicated at the moment soley to asphalt.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-13-2009, 06:09 PM   #9833
Cirrc's Avatar
Default JRX-S Type R
Thanks for all the replies... they've been very helpful.
Old 07-14-2009, 02:14 PM   #9834
Company Representative
SweepRacingUSA's Avatar
Default Aluminium Hex
hey guys
I found a problem with those wheel hex parts, after few weeks axle pin dig in to the hex and it created too much pressure to axle bearings cause to bind
I tried shims already wont help.
is this another just wear and tear parts?
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 07-14-2009, 03:19 PM   #9835
Yeti35's Avatar
Originally Posted by da_John_wee View Post
hey guys
Are you referring to the plastic kits ones? If so I could see that being an issue. I use the aluminum ones and have not experienced this at all.
22 2.0
22T 2.0
Old 07-14-2009, 03:40 PM   #9836
hey guys
If you have the kit plastic one then replace them with alloy. It is a small cost but is nice not having your hex's fall off every time you remove the wheels.
If you have alloy then try not to "crush" the whole setup when you tighten up the clamp. Also note that if your bearings are shot they may turn ok under no load but lock up under load. This may well also be the problem.
Powered by Falco
Old 07-14-2009, 04:08 PM   #9837
Lemme rephrase...
not after "few weeks".... I had these hexes for about "a year" I do have all three thickness and sometime thinnest one scratch bubs by that screw from beggining. and other thicknesses start having "digging" problems
thanks for the input but like It showed on the title the problem is for those "Aluminium" one
I didnt tried stock plastic one yet.
it may spin good on the hex but if you disassemble a hub carrier and tighten a wheel with a nut as usual, you might have one or two "crushed" feeling one that bind on spin.
thats how I test my Ballbearings since I found digged alloy hex on my car.
I dont think I crushed those nuts too far, I tried with brand new BB and result are same for the "digged" hex.
try spin a wheel ike I said above, you might find surprise for yourself.\
anyway. any fix or solution for this.? or any one had same problem like mine?
Old 07-14-2009, 05:08 PM   #9838
mojoman's Avatar
If you are using the .195 hubs, do not use the axle shim. The shim only works with the .165 hubs. That could be your binding problem.
Good Luck,
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 07-14-2009, 05:15 PM   #9839
You need a new car John. Maybe if you weren't as fast as you are, you wouldn't have this problem!!!!!!!!!!!!!
J/K LOL
See ya.
Old 07-14-2009, 05:24 PM   #9840
Good Luck,
I never used shims on any of alloy hex, I think shims are for Plastic hexes
J/K LOL
See ya.
hey blue Long time no see, see you soon!
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
