Old 06-30-2009, 06:54 AM   #9781
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Catbutt View Post
The problem I have been having with the diffs and dirt is not with the diff balls and d-rings (I run regular ball diffs, not spool)but with the part of the outdrive that goes into the diff tube and the tube itself. Because the outdrive has an open channel where the dogbone fits into it, grit tends to get in-between the outdrive and the diff tube through this opening and creates resistance in the drivetrain. I find I have to re-build the diffs often because of this, the rear about twice as much as the front. I am trying to figure out a way to prevent this from happening but have not had any luck to date. This is the only area on the type R that has given me problems and I would greatly appreciate any thoughts on a fix for this. Thanks in advance.
don't know if this would work but maybe something to coat the plastic with that makes it slippery so you can just blow the dirt off? Not sure how you would get the slipper stuff to not be on the part of the hub that you want to be sticky.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-30-2009, 09:06 AM   #9782
jrxs-r's Avatar
What about a thin piece of foam? I don't generally get problems as I run rubber on carpet, but as and when I do run on asphalt, a good blow out with an air hose generally keeps things quite clean. I also use minimal lube on the balls as possible.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 06-30-2009, 09:39 AM   #9783
Catbutt's Avatar
After I posted last night I thought of using the foam rings you put on the body post holes might work as a outdrive cover. That coupled with a makeshift dustboot attached to the foam and extending over the dogbone shaft as is done on fullsize cars like my 67 VW beetle cvd dustboots. I tried cutting a foam circle and using servo tape to attach it to the outside of the outdrive but this did not work- wouldn't stay put. Perhaps the foam body ring might work though. Maybe this is something flying fox could find a fix for- hint, hint. Thanks for your thoughts on this.
You can do it your own way, if it's done just how I say-
Evil will always triumph because good is dumb!- Dark helmet
Catbutt is offline   Reply With Quote
Old 06-30-2009, 12:35 PM   #9784
Company Representative
SweepRacingUSA's Avatar
Originally Posted by YmeBP View Post
Start with a fresh diff hub, assemble your thrust bearing insert it into the opposite side of the spool, put a little bit of diff lub on the side of the ring that is going to mate with the diff sides, i use a teeeeeny bit of losi purple lube, put the two halves together. you can use a little bit of super glue as mentioned before (i don't because i'm f'in clumsy when it comes to glue) and tighten it down. Tighten it down until it makes contact with the spool pully and then tighten it down a little at a time (1/4 to 1/8 turn) util you cannot turn the spool pully with your fingers and then give it anothe 1/4 turn. You want it tight but not tight enough to strip out the diff hub.
A couple additions i've added recently were the sand paper discs from the xxx series. they make it so the pully doesn't spin as easily due to mechanical friction of the sandpaper.
cool I dont use a glue either for same reason
I went to race last sunday and broke 2 axle pins at same time! I think I got some of these pins mixed with CVD coupling pins and those pins are weaker I beilive.
also noticed diff wont last very long with the D ring mod, I'm going to try little tighter diff on next run.
happy hoilday!
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 07-01-2009, 07:46 AM   #9785
Hi catbutt.
Try this: close with rubber tape or shrink tube the slot into outdrive. If you use the tape, secure it with a "tear" of instant glue on the end
The residue little little slot between the "D" ring and the tape yuo could close with rubber glue like Bostik
close all-round the hole on the diff tube with rubber tape or shrink tube. If use tape secure it with instant glue
close the internal hole in the other outdriver with an "O" ring and rubber glue
close the faces of the pulley with adesive paper.
Hope this hel you
ciao ciao
Belty Dog is offline   Reply With Quote
Old 07-03-2009, 01:25 PM   #9786
JRXS_chris's Avatar
^^^^ Pics required please matey!
My Flying Fox layshaft arrived here in the UK yesterday and has been installed. VERY impressed with the quality of the item!
JRXS_chris is offline   Reply With Quote
Old 07-04-2009, 05:28 AM   #9787
JRXS_chris's Avatar
Default Couple of pics
Hi everyone. Just thought I'd post a couple of pics of my Type-R.
Here it is in full-
I'm running a Nosram Matrix Stock Spec speedo on a 10.5 Novak motor. It's geared at 4.68 for our massive BRCA Nationals tracks. Current setup is a slightly modified version of the kit rubber set up.
You may notice that I have removed the 4 screws from the top deck and removed the centre of the top deck. You'd be amazed at the extra flex this gives and has increased traction massively.
Flying Fox layshaft is installed and works perfectly.
I was determined to be able to use the latest Lipos so some mods had to be made. I didn't fancy filing a 90 battery down. Cue a friend and a CNC machine on the steel lipo tray. The walls have been thinned out and the slight chamfer removed. Slots have also been cut in for the positioning lugs on the battery. A couple of coats of black spray paint and it looks as though it was born that way!
The tray mods have lost about 60g off the weight which is a slight negative, but it has enabled me to add a few more weights around the chassis without being well over our 1500g limit. It's perfectly balanced L/R now so I can mess about with the front to rear balance for tuning.
Old 07-04-2009, 05:30 PM   #9788
Here it is in full-
well done! I also do the same modification on the original tray so I can use all the 5000mah 40C lipo, and I put all the balance weight on the front and rear rather than using the steel tray because of easier front and rear weight transifer, am I right?
billbill4u is offline   Reply With Quote
Old 07-05-2009, 07:41 PM   #9789
Default jrx-s type-R gearing question
I am wanting to run a novak 17.5 brushless motor , 2-cell lipo battery, gtb esc, my trans. ratio is 1.83 what tooth spur and pinion would I need to get close to a 3.50 F.G.R. either a 64 pitch or a 48 pitch, I also have the prs adaptor, I tried a 90t spur and a 46t pinion 64 pitch and I did not have enough travel on my mount to slide over for the teeth to mesh, any information would be greatly appreciated, thanks
ripnroar is offline   Reply With Quote
Old 07-05-2009, 07:50 PM   #9790
Chris08527's Avatar
Trader Rating: 16 (100%+)
where do you guys run your front and rear roll centers on rubber tire asphault???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 07-05-2009, 07:58 PM   #9791
Trader Rating: 21 (100%+)
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-05-2009, 08:05 PM   #9792
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
I am selling my Type R in the for sale section if anyone is interested. Thanks.
Ty is offline   Reply With Quote
Old 07-05-2009, 08:31 PM   #9793
go with 104/53 that will fits fine
BTW taht kinda tall, make sure check the temparture in every 2minutes or so.
Old 07-05-2009, 11:05 PM   #9794
Kajman's Avatar
Stop spaming every thread with this useless adverts.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-06-2009, 12:22 AM   #9795
Chill_Will's Avatar
Ripnroar - I have a 102 spur you can try. You will need to get a 53(3.52), 52, 51 just in case your motor gets too hot.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
