Old 06-02-2009, 07:57 AM   #9661
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
are the lay shafts available in the us yet?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-02-2009, 08:00 AM   #9662
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
They should be in the air as we speak. The moment I get confirmation they are at the shop I will let you know.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 06-02-2009, 08:06 AM   #9663
cool
thanks
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 06-02-2009, 06:00 PM   #9664
Originally Posted by Catbutt View Post
I know it's a little late in the game but I thought I'd share some pics of my new type R. I did not include any under the hood pics as I'm sure by now everyone knows what to expect there I'm new to on-road (experienced in off-road-Losi 8ight electric conversion) and this is my first. The car is brilliant and was easy to build. It is also a unique design and comes LiPO ready right from the box-nice touches and helped my descision. I run on ad-hoc parking lot tracks against X-Ray and Kyosho nitros with high-end racing modified mills and hang with them with ease. Under the hood I run a Novak GTB, 3.5r brushless, TrueRC 5000 LiPO, Nomadio reciever and all 3 fans on the can. I am having problems keeping the rear from stepping out under acceleration after hard turns. To combat this I installed a 41 tooth overdrive pulley up front and now the rear comes around on me during hard breaking turns or hard off power turns. Any ideas for a fix in this area would be welcome. My next step is to try a different set-up like Schreff's Jackson set-up which is very divergent from where I'm set now.
I have been running this car for a short while now and have had good success with it. The biggest problem I have had with this chassis is getting a good smooth and tight rear diff. I have tried many parts to improve it so far and these are the things that have made an improvement so far...
* Mill/File the alloy diff tube (large allloy piece that the diff bearings run on) to allow the use of a d-ring type diff ring on both sides of the pulley. This will eliminate the "tweaked" feeling you get on power when the diff slips.
* Dissasemble two thrust bearing cages and make up a thrust bearing using the standard washers but use loose balls. This allows you to have a 10 ball thrust bearing vs the 7 in the cage.
* Get better diff balls. I have found the associated diff balls (TC5) to be the best I have used so far. Stay away from ceramic in modified, they slip too easy under load.
Also use a bit of super glue on the thread of the diff hub before assembling the diff as this helps to keep the diff from loosening up during a run. Another thing to consider is your motor. I have found a 4.0 is the most you will need and is what all the pro drivers run with 6cell/lipo. The 3.5 will take its toll on the chassis and its performance with too much power. Ultimatley if you run on dirty surfaces like a car park you will find your diff only good for about 2 competative runs anyway as it will fill with dirt real quick. I suggest you build a few diffs up so you can swap them out every couple of runs when they start feeling "gritty".
Hope this helps.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-02-2009, 06:43 PM   #9665
Lapcounter's Avatar
Originally Posted by Pablo Diablo View Post
I know the Yun Tong (Reedy) 35c Lipo's fit. I've heard of people using Thunder Power 5000 40C's but that involves some dremel work.
By Yun Tong, do you mean the European sized version?
http://aedownloads.com/press/in_052009_reedy711.pdf
Thunder Power looks like it isn't hard case. I am seeing that correctly or am I looking at the wrong ones?
Thanks for the info.
Lapcounter is offline   Reply With Quote
Old 06-02-2009, 08:30 PM   #9666
The yuntong (and I imagine the reedy) packs have the bullet connectors in a fair margin from the edge of the pack. For this reason you do need to dremel the top deck a little. I believe the reedy packs can be brought with deans plugs already installed so I imagine they would fit no problems. I have been told by a number of people that the Thunderpower 5000 40C fits with no mods. In my experience though any decent pack goes as good as any other. You need to run mod to pick the difference. This is proven by lap times.
Powered by Falco
Old 06-03-2009, 11:03 AM   #9667
Suspended
Originally Posted by Jaz406 View Post
Start here with Mike Hanyes VTA setup
Thank you for your drawings
Christopher13 is offline   Reply With Quote
Old 06-03-2009, 11:23 AM   #9668
Suspended
Originally Posted by L.Fairtrace View Post
I feel like banging my head against the wall.............
Why?
Old 06-03-2009, 05:15 PM   #9669
adamge's Avatar
Chris, I think that the correct answer to the TP5000 in the TypeR has been given on this thread about 15 times, and someone came in here and gave the wrong answer.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 06-04-2009, 12:11 PM   #9670
Suspended
Originally Posted by Kwikvdub View Post
Hey Larry, What do you think of the new Losi LiPo's??.......... How's the fitment in the car and performance??
Wasn't sure if you ran it on Sunday. I know you had the other cells with ya, the one's you had at Blue Diamond.
Thanks Bro!
I ran the new losi lipo's in my 13.5 foam car sunday.
Old 06-05-2009, 02:18 PM   #9671
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Anyone have any suggestions on how to get more chassis flex out of the Type R without messing with the setup too much? I am running on a low/medium bite unprepared parking lot track. I think that the steel tray is taking away flex but I like the weight at the low CG. Any suggestions would be much appreciated..
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 06-05-2009, 06:04 PM   #9672
Company Representative
SweepRacingUSA's Avatar
Lose 4 screws from the top deck to get some flex. If track is lose I thnk it will be better to get rid of the metal plate and run leads around the chassis.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 06-06-2009, 01:26 AM   #9673
Ditto... Dump the steel tray and use the kit tray. Balancing weights up front to get 50/50 weight distribution will also make you faster.
Powered by Falco
Old 06-08-2009, 03:18 PM   #9674
YmeBP's Avatar
Trader Rating: 32 (100%+)
Thumbs up Layshafts in STOCK!!
The Flying Fox Lay Shafts are in my hands as we speak! They are up on the website too ready for shipping.
As a bonus the first 10 orders, use coupon code "flyingfox" to get half off shipping for a limited time!!!
http://www.skyrocketbatteries.com/pr...products_id=81
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-08-2009, 03:57 PM   #9675
jkirkwood's Avatar
Order placed. Look forward to seeing the quality for myself.
jkirkwood is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
