Old 05-22-2009, 10:44 AM   #9616
jkirkwood's Avatar
Pablo, I will order one from the US distributor once you annouce that. Looks great!
jkirkwood is offline   Reply With Quote
Old 05-22-2009, 11:01 AM   #9617
hamster778's Avatar
Send a message via MSN to hamster778
Hi ya, they look great. what would be the chances of getting some sent to the UK.
Cheers
Tim
hamster778 is offline   Reply With Quote
Old 05-22-2009, 11:41 AM   #9618
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by vabroom View Post
Pablo, will the PRS spur gears fit?
I've never measured a PRS spur but the PCD(diameter of hole patern) I use is 16mm. It's the most common PCD for spurs. Xray spurs fit as do RW and Robinson.
Just measure the distance between 2 opposite holes on your PRS spur. If its 16mm or 0.62" all is good.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 05-22-2009, 12:34 PM   #9619
Cheers
Tim
No problems. Postage from Oz to UK tends to be on the slow side but I can send them. If I get enough interest out of the UK I will sort something better out.
Paul H
Old 05-22-2009, 12:38 PM   #9620
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by Pablo Diablo View Post
Here are some photo's of the completed production layshafts. I found a way to make them a little lighter by removing some pockets. I am very happy with the way they turned out
The guys racing at the Much More Masters tomorrow come and see me. Everyone who has sent me requests, I will have enough for you all from the first run.
Anyone in the US, I am sending some to a distributor, who you can buy directly from. This will to save you postage costs from Australia. I will let you know the details once the deal is finalized early next week.
I really appreciate the interest shown.
That thing is sexy for sure.. I know its probably not set in stone, but what will the base price be, assuming you meet your finacial goals?
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 05-22-2009, 01:11 PM   #9621
Good to know its not just me who thinks that!
I don't want to do the wrong thing by my potential US distributor by anouncing a price before we have a final agreement. It will be more expensive than other products that allow the use of different spurs, but not so much that it is no longer competatively priced.
You have to understand that my layshaft also solves many other problems too. That gap btween the pulleys is a little larger allowing a wider choice of batteries(Im yet to find one that won't fit), It elimintaes all play between the pulleys and by being made out of one solid piece of aluminium your spurs and pulleys will run perfectly true and concentric.
It's also a far more complex part to make compared to anything else on the market.
Sorry I can't say any more, but expect something very reasonable.
Paul H
Old 05-22-2009, 01:39 PM   #9622
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i'm going to buy one as soon as they are in the us
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 05-22-2009, 02:10 PM   #9623
Radron's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Radron
I will surely be ordering one as soon as they reach the U.S., Thanks !!
Radron is offline   Reply With Quote
Old 05-23-2009, 04:44 AM   #9624
They look awesome in the flesh ( or my hand to be more precise)!
I have been running a prototype for a little while now and it has been flawless. Normal spurs, no lipo problems, and a little less weight too. You also get rid the e-clips.
It simply improves on losi's shortfall in the design of the layshaft to fit normal spurs and lipos.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 05-23-2009, 06:15 AM   #9625
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by TRF415boy View Post
Give it more front droop that will give you more on power stabiilty (and a bit less on power steering). Works every time
I tried a whole ton of stuff yesterday and finally started seeing great results with changing ride height and droop. The track was a bit dusty yesterday and unprepped but i think i may have a decent rear setup, now to work on the front end of the car.
What i ended up with was removing the washers under the front rear hinge pin blocks and adding them to the rear toe block, went with high roll center, moved the shocks outboard and went down to 4mm ride height and 3mm droop in the front and 1.5 in the rear. It was getting there, i think i need to come up .5 to 1mm on ride height because the chassis is bottoming out in the corners. I think i'm also going to stiffen the sway bars a bit too to keep me flatter.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-23-2009, 02:28 PM   #9626
Pablo
Let me know when you have the price set in Australia, I am interested in the new layshaft as I always have problems with the eclips.
MIKU
miku is offline   Reply With Quote
Old 05-23-2009, 08:36 PM   #9627
minittrackmann's Avatar
Anyone no of a good asphalt setup for the type r?
minittrackmann is offline   Reply With Quote
Old 05-24-2009, 03:30 AM   #9628
Default Dragonfire WINS
Congratulations to Dragonfire who today won the Much More Masters in Sydney. This is one of the biggest on road events in Australia and there were plenty of big named drivers competing, but it was Dragonfire with the little known Losi, who TQ'd and took the win.
Paul H
Old 05-24-2009, 03:55 AM   #9629
I'll get a setup sheet done tomorrow. Another losi driver ran the setup and did pick up some time. Note that he also said it had to be driven with a smooth throttle finger as well but if it is fast then it can be smoothed to suit your conditions (depending on your grip level).
Powered by Falco
Old 05-24-2009, 09:02 AM   #9630
Thanks and congrats brotha...
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
