Old 05-21-2009, 07:19 AM   #9601
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Dragonfire View Post
The easaiest thing to try would be more rear toe. I run 3.5 everywhere.
Another big factor is the diff (something I have been working on a lot recently). It needs to be smooth. If its gritty or too tight (excessive limited slip effect) you will struggle to use power out of corners. The biggest advance I have made with my diff is to remove the cage from the thrust bearing and use more thrust balls. You can fit 3 extra without the cage and it makes a noticable difference on the track.
I just rebuilt my diffs with a thrust bearing Schreffler and Fairtrace reccomended, they are smooth as a baby's butt now . I'm tempted to do the d-ring mod on the diff tube as well to loosen up the rear diff.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-21-2009, 07:21 AM   #9602
YmeBP's Avatar
Originally Posted by Jaz406 View Post
Is this on asphalt?
I found a 41 tooth front pulley will make the car twitchy, rear felt much more stable with equal pulley sizes.
I'm with Dragonfire on the rear diff --My rear diff was going out (loose) and it also caused the car to be loose in the rear and not predictable on power and in chicanes. More rear toe will give you more forward bite on accel. I run 3* to 3.5* in both my cars as a starting point.
I would run a level rear hinge pin, says you have a .030 washer in front.
Late in a run if the rear is loose but it was fine at the start of the run, it's most likely tires overheating try 27's/28's.
Those are what I have found on different instances.
Hmm you may be onto something with the tires!! I'll have to try the toe as well I'll let you know how it works out for me this weekend.
Old 05-21-2009, 10:20 AM   #9603
mtveten's Avatar
Trader Rating: 27 (100%+)
Most likely the bulk of your problem is tire, start with some sorex32s and tire warmers. You could try 28s but they will probably overheat. On the chassis front start with both roll centers & diffs in the high position and go from there.
mtveten is offline   Reply With Quote
Old 05-21-2009, 11:50 AM   #9604
YmeBP's Avatar
What does the the high roll center do for the car? Does it make the car roll more easily or make it corner flatter?
Oh and it's not just for me ... my 10 year old son is now running a type-r and the little bugger keeps asking me "why are you changing this or that" and honestly i don't have good answers for him most of the time . It's just what i see the faster racers do so i do it too.
Old 05-21-2009, 04:45 PM   #9605
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Best way I can explain it is roll center affects the angle the force is applied to the tires contact patch. Too low (small angle) the tires will not grip and just "slide". I notice roll center changes more in 180* corners than anywhere else. Get the roll center right and you'll be amazed at the speed you can carry through them.
Sway bars are what help the car corner "flatter" and limit lateral movement without hurting front to rear weight transfer/traction.
Tires are the first choice of getting traction unless "spec".
Camber adjustments
Roll center adjustments,
Droop settings
Camber link position and camber gain shims on the outer hubs and steering blocks.
Jaz406 is offline   Reply With Quote
Old 05-21-2009, 05:38 PM   #9606
YmeBP's Avatar
Camber adjustments
Droop settings
Perfect thank you!!
Old 05-21-2009, 06:30 PM   #9607
Company Representative
SweepRacingUSA's Avatar
what is that D ring mod? slot round side of hub to fit another D shaped diff ring?
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 05-21-2009, 07:00 PM   #9608
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Pretty much, but the d-ring replaces the brass and steel slipper "shims". ( i think, i've never done it)
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 05-21-2009, 07:08 PM   #9609
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Yes you slot the diff hub to accept the D ring. We found that this helped free the car up on carpet. It allows for a much freer diff. The only problem I've found with doing this is if the diff slips it pretty much ruins it and has to be rebuilt.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 05-21-2009, 09:20 PM   #9610
adamge's Avatar
Perfect thank you!!
Except for the part where he didn't mention that a higher RC, for all the extra traction you get on the outside wheel, you lose about the same amount on the inside wheel.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 05-21-2009, 11:24 PM   #9611
adamge:
Your exactly right that's why the right amount of hinge pin height is important if you read into the statement, changing the roll center (force angle) would move the force to the inside or outside of the contact patch of the tire. I'm just trying to be helpful and here's a link that explains more.
http://http://www.rc-truckncar-tuning.com/roll-center.html
Now if I could put these adjustments into my car at the right time I would be happy
Old 05-22-2009, 07:17 AM   #9612
YmeBP's Avatar
adamge:
Even better thanks guys!!
HOLY CRAP!!! This site is the motherload of info!! It's even better than the xxx-main rc book!
Old 05-22-2009, 07:34 AM   #9613
TRF415boy's Avatar
I may have asked this before but .... with this many pages in the thread I can't find it so i'm putting it in the title this time to make it easily searchable (hence the godzilla keyword ).
Situation:
Low temperature (track was 56*) medium bite surface relatively high speed
Major areas of my setup :
45/40 front rear shock oil, 17.5 springs all the way around
both diff's low (tried high/low front rear as well)
high roll center front (tried low low as well)
Low roll center in rear (1 washer under front roll center thingy)
tried both jr links and camber links in front
rear is 4 inside and farthest one from shock tower on the hub (B i think)
rear shocks are straight up and down
front shocks are second hole from up and down.
RP24 tires
6.5mm ride height, and 2mm droop all the way around.
I was really loose in the rear coming out of the corners, going in the corners i was good.
I also tried both over drive (smaller front pulley) and even.
What steps would I take to lock the rear of the car in more.
Give it more front droop that will give you more on power stabiilty (and a bit less on power steering). Works every time
TRF415boy is offline   Reply With Quote
Old 05-22-2009, 10:16 AM   #9614
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Here are some photo's of the completed production layshafts. I found a way to make them a little lighter by removing some pockets. I am very happy with the way they turned out
The guys racing at the Much More Masters tomorrow come and see me. Everyone who has sent me requests, I will have enough for you all from the first run.
Anyone in the US, I am sending some to a distributor, who you can buy directly from. This will to save you postage costs from Australia. I will let you know the details once the deal is finalized early next week.
I really appreciate the interest shown.
Team Losi JRXS Type-R-layshaftcomplete.jpg   Team Losi JRXS Type-R-layshaftmachining5.jpg   Team Losi JRXS Type-R-layshaftmachining4.jpg
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 05-22-2009, 11:42 AM   #9615
vabroom's Avatar
Pablo, will the PRS spur gears fit?
vabroom is online now   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
