Old 05-12-2009, 08:15 AM   #9571
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
when you guys get the lay shafts done let me know i want one
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 05-12-2009, 06:18 PM   #9572
baf1's Avatar
Default yeah ...
yeah me to,on that lay shaft..
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 05-12-2009, 08:06 PM   #9573
As we speak the 1st stage of the 1st batch of layshafts (50 or so) are being turned. I believe finishing them off will happen before the end of the week. I'm sure Paul will let you know when he has some finished. He managed to find someone who will allow him to use the machinery himself to turn out decent numbers quickly so that will reduce the cost per unit.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 05-12-2009, 08:26 PM   #9574
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by schreff View Post
There is no part number difference. There was a running change in the trays that fixed some fitment issues in the car and some batteries. It was mainly just changing the size of the pocket in the tray to just a tick bigger and double checking tolerances on it fitting the car.
Thanks, i'll look into it.
Originally Posted by Dragonfire View Post
I don't know why you guys use a metal tray unless you have very light lipos. Almost all the weight on my chassis is over the front to get it nicely balanced.
On that note...
Who would be interesed in a chassis conversion kit to better balance this chassis f/r? It is an idea being looked at to eliminate the spread of weight from one end of the chassis to the other and focus it in the middle. In theroy you will have more rotation speed (faster steering) with the same setup and electronics positioned better (not right up front with long wires running to the motor). Anyway its a work in progress at the moment.
About the weight thing, i think most guys who run tp lipos are still underweight, and a metal plate adds around 100-150 grams (depending on which one you have) in order to make ROAR min. weight for rubber tire (1500 i think?)
About the conversion kit, sounds promising, but it kind of reminds me of the hpi pro 3 as far as layout ballast goes. Moving the motor a touch more forward would be an interesting change. I guess only experimenting and time will tell! Would it have the same effect as say... moving the arms backward, but to a greater extent?
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 05-12-2009, 08:32 PM   #9575
baf1's Avatar
Default cool.
cool cool.
Old 05-12-2009, 09:23 PM   #9576
I only have just over a 100gms on my chassis. All of it is in front of the battery. I imagine that if I had a metal tray then my chassis would certainly have rear weight bias. They other element is that a steel tray effects the chassis. It reduces flex and stores tweak if it gets twisted.
The layout would most likely be almost identical to the pro3, but with losi parts. The explination I have been using is this. Get a weight and tie it to the end of a string. Swing it round as fast as you can. You will find there is a limit to how fast you can go. Now grab the string closer to the weight and try again. You will be able to swing it around alot faster. This is the same effect we are looking at with this mod. The JRXS chassis is the best chassis on the market for centering weight l/r but this results in a large f/r split. Considering that everyone runs more weight on one side of the chassis to balance their speedy, Why not just move the servo there and tighten up the f/r split. I can see any negatives to this so far. The million dollar question is do we move the layshaft forward with the motor or move it behind the motor? I like the idea of moving the layshaft backwards. This gives you a long front belt and inherently more steering as a side effect.
Powered by Falco
Old 05-13-2009, 06:39 AM   #9577
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I think you mean CAN'T.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 05-13-2009, 10:03 AM   #9578
mojoman's Avatar
The steel tray is invaluable. I have never had a problem with it either stiffining the chassis or tweak.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 05-16-2009, 05:47 PM   #9579
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys
which lipo pack fits the losi with the least amount or no mods???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 05-16-2009, 08:28 PM   #9580
Yeti35's Avatar
Originally Posted by Chris08527 View Post
hey guys
Losi packs from what I hear. No mods at all. I am running the Protek 4000's in mine and just ground the case where the pullies would rub. I did not want to shave the pullies at all.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 05-16-2009, 09:01 PM   #9581
I think the TP 40c fits with the "new" steel battery tray with very little or no mods.
Even if you have to mod it, its worth it to fit to be able to run the tp 40c.
Old 05-17-2009, 01:53 PM   #9582
Trader Rating: 70 (100%+)
Where can you get the metal tray?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-17-2009, 04:05 PM   #9583
http://www.horizonhobby.com/Products...rodID=LOSA4312
Old 05-18-2009, 11:07 AM   #9584
Chris08527's Avatar
is that the 5000/40c
Old 05-18-2009, 12:48 PM   #9585
YmeBP's Avatar
Trader Rating: 32 (100%+)
Default Steps to get rear traction Godzilla
I may have asked this before but .... with this many pages in the thread I can't find it so i'm putting it in the title this time to make it easily searchable (hence the godzilla keyword ).
Situation:
Low temperature (track was 56*) medium bite surface relatively high speed
Major areas of my setup :
45/40 front rear shock oil, 17.5 springs all the way around
both diff's low (tried high/low front rear as well)
high roll center front (tried low low as well)
Low roll center in rear (1 washer under front roll center thingy)
tried both jr links and camber links in front
rear is 4 inside and farthest one from shock tower on the hub (B i think)
rear shocks are straight up and down
front shocks are second hole from up and down.
RP24 tires
6.5mm ride height, and 2mm droop all the way around.
I was really loose in the rear coming out of the corners, going in the corners i was good.
I also tried both over drive (smaller front pulley) and even.
What steps would I take to lock the rear of the car in more.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
