Team Losi JRXS Type-R
#9466
Dragonfire --> Well done! A lap over the whole field is very impressive... Care to share your setup with us?
Just finished the WA Electric State Titles and managed to bring home a 4th in 10.5 amongst a field of XRays and 2 Tamiyas... Was also the only one running an SP10.5 too... I'll post my setup in the next week or so when i get some time.
Front Rear
Shocks
15lbs 12.5lbs
50wt 40wt
No57 No57
3 3 outside
Geometry
JR low 3 B 4
Full low roll center with no spacers under anything
Camber
-1.0 -1.0
Toe
+1.0 -3.5
Ackerman
Steering rack 1
Spindle 1
2nd softest swaybar all round
Front spool
Stand pulleys
Low diffs
Protoform LTC-R
#9469
Has anyone tried fitting the SMC5240CM Battery in the JRXS-R? Any clearance issues?
#9470
Yeah thats ashpahlt rubber. The feeling and turn in on new rubberz was unreal but the track seems to be graining the tyres so they don't work too well next run. I think this is the track though as it wasn't happening at the same track before they pressure washed the surface. I was looking at the rollcenter program and I think I found a better balance so I will compare the 2 settings next chance I get. Also take not that my setup uses Integy Silicone oil in the shocks so if you use something else it may not be the same.
#9471
setup worksheets Excel format
For those who have asked about this, attached find the files.
If you think something is missing, please let me know and I will add it, or you can do it on your own.
You can use this for qualifiers and mains, create a new copy of the worksheet and rename it.
Use it to keep track of your progress.
This sheet helped my progress at the last race I participated in and it helps you track your changes. When making changes, do only one or two at a time, that way you will be able to recognize the difference from one setup to the next. This will help you achieve faster lap times, and remember drive slow to go fast!!
Enjoy
Enjoy
#9473
Thanx... Though I have been "burning" my tyre recently but I think that is track specific... Anyway...
Front Rear
Shocks
15lbs 12.5lbs
50wt 40wt
No57 No57
3 3 outside
Geometry
JR low 3 B 4
Camber
-1.0 -1.0
Toe
+1.0 -3.5
Ackerman
Steering rack 1
Spindle 1
Front spool
Stand pulleys
Low diffs
Protoform LTC-R
Front Rear
Shocks
15lbs 12.5lbs
50wt 40wt
No57 No57
3 3 outside
Geometry
JR low 3 B 4
Camber
-1.0 -1.0
Toe
+1.0 -3.5
Ackerman
Steering rack 1
Spindle 1
Front spool
Stand pulleys
Low diffs
Protoform LTC-R
#9474
Anyone tried this thrust bearing before in the JRX-S type R?
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSA3098
Was wondering if it will fit and how well it works?
#9475
#9480
