Old 03-19-2009, 11:45 PM   #9376
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by billbill4u View Post
Any brother can help me to improve my losi setup? I start with the kit rubber setup but change to Front AE oil 35 and 17.5lbs / Rear AE oil 30 & 17.5lbs
the track is outdoor asphalt, thx so much
Also, I use 11.5T, what ratio is recomment? I use losi 118t 64p with pinion 48t 64p that is the max limit, I feel the car is not fast enough, I don't have the PRS adaptor it out of stock.........
Well, what do you want the car to do? is it loose? does it push? is there enough on power steering? etc. I am not the one driving the car, so its hard to tell what needs improvement on the car.
Are you positive that you have a 48 tooth in the car? that sounds awefully high for an 11.5. Make sure you don't have a faulty pack or motor. If anything, i'd say that you'd need to gear down!
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 03-20-2009, 02:41 AM   #9377
I feel a little bit push(on power)
billbill4u is offline   Reply With Quote
Old 03-20-2009, 02:47 AM   #9378
Well, you can do a variety of things, but i'd start by decreasing front downtravel, and see how that works.
Old 03-20-2009, 09:27 AM   #9379
Company Representative
SweepRacingUSA's Avatar
get rid of JR link if you have them, also balanced the chassis FR to RR and LF to Right.
of cos minimnize the droop and riding height.
those things helped me alot.
SweepRacingUSA is offline   Reply With Quote
Old 03-20-2009, 07:10 PM   #9380
ok, I will try your setting tonight, thx so much!
if I want more steering, is it necessary to add more weight on the front as what the manual said? Front 52%, rear 48%?
Old 03-20-2009, 08:06 PM   #9381
Sooo... Who's reppin' the R at the nationals?
Old 03-21-2009, 11:31 AM   #9382
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Any of you own JXR-S Pro and JXRs Type-R ???
I am wondering if its possible to fit the Type-R A-arms and Shock Towers on the Pro w/o major modification ? (Small dremeling and shaving off i can do)
Basicly i wanna have JXR-S Pro with the front motor but with the New longer suspension travel of the Type-R.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 03-21-2009, 11:37 AM   #9383
I think it may be too much of a hassle, but i'm not sure. I have a buddy who has an original jrxs and i'll ask him if he can bring it over. The only thing i can see being an issue would be the diff mounts being too wide to allow the hinge pins to come closser to the centerline, but again, i'm not sure. I beleive the shock towers are simular.
Edit, the rear are simular, the fronts are not.
Old 03-21-2009, 11:44 AM   #9384
I think Larry Fairtrace and maybe Mike Larcher
Old 03-21-2009, 11:57 AM   #9385
iPearl's Avatar
By rear similar,...
Do the mounting points that screw the shock tower down line up correct to the metal part ???
and do the A-Arms fit ???
So the front is completely different ?
Only the rear is similar ?
I am happy with the Weight up front and the weight shift up front.
But that new suspension interests me,
Old 03-21-2009, 08:24 PM   #9386
Larcher ran the Corally. Mike had bad luck throughout the whole week. Ron Goetter ran the losi but also had some bad luck.
In 17.5 foam Brian Lutz is sitting in 4th with the car and I am sitting 7th.
In 13.5 foam Dave Johnson is running the car in the 10th spot.
Rubber tire, Lutz is qualified 7th. Larry is in the 10th spot.
Sorry to any I missed simply because I was unaware.
It has become apparent to me at the nats that it is all about the right package and a majority of the top racers all tend to have similar patterns in chassis/motor/battery/speedo choices. Almost everyone is running a DUO based motor. Most common speedo being the tekin RS/RS Pro. The clear best stick is the Thunder power 40C. Chassis' there is a variety, but mainly a sea of corally's.
JoelV is offline   Reply With Quote
Old 03-22-2009, 11:33 AM   #9387
forgot about "da Goat" !
SMC Losing a ground against TP as expected..I heard TP fits better on the Losi too.
Larcher you trader!!!
Old 03-22-2009, 11:53 AM   #9388
MikeXray's Avatar
Trader Rating: 73 (100%+)
at 360, the phi is better, my type-r would have held up better and probably been easier to drive, but I knew there wouldn't be enough time to "test" both cars. Joel's car looked awesome this weekend.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-22-2009, 07:18 PM   #9389
Why are you guys so keen to get rid of the "JR link"? have only had the chassis a short while but I have had no lack of pace with it yet. In theroy a long link provides more mid corner bite which on a very resposive chassis is not a bad thing.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-22-2009, 08:55 PM   #9390
Yeti35's Avatar
I ran the car for awhile with it then dropped it and I feel it is even better. I will probably never go back to it.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
