Old 03-17-2009, 01:03 PM   #9361
Company Representative
SweepRacingUSA's Avatar
Originally Posted by dcuz383 View Post
Does anybody have or no where I can get some PRS adapters? I contacted PRS and they told me there out of stock for 4 weeks. I have a state race the 28th. I need two but would buy 4 if someone has them.
give 360raceway.com a call, I m sure they have them
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 03-17-2009, 07:00 PM   #9362
dcuz383's Avatar
Default FDR Chart
Here is two FDR charts for the JRX-S. One for 41T pulleys and one for 42T pulleys. Both have two pages. Pinions from 10 to 70 and Spurs from 60 to 130. Let me know what you think.
File Type: pdf Internal Drivetrain Ratio for 41T Pulleys.pdf (24.8 KB, 198 views)
File Type: pdf Internal Drivetrain Ratio for 42T Pulleys.pdf (24.7 KB, 217 views)
I would probably hate me too!
dcuz383 is offline   Reply With Quote
Old 03-17-2009, 07:04 PM   #9363
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by mojoman View Post
Here you go. Stormer had it for a better price but they jumped ship and marked the price down I think they are all out of stock now. The price is reasonable for the greatest kit you'll buy.
i got mine for 315 through a main
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 03-18-2009, 02:35 PM   #9364
Trader Rating: 27 (100%+)
stephenianjames is offline   Reply With Quote
Old 03-18-2009, 02:38 PM   #9365
Hi guys,
Just wondering if you can help me....what lipos is everyone using that fit?
I bought an IP3800 25C and find that it rubs against the front belt drive pulley that is connected to the 'top shaft' (the central shaft which drives the front and rear belt).
I also tried a Yeah Racing 3200 stick pack which just fits but runs very close to the front belt (ie approx 1mm or less).
What do you guys use and how to you stop them from sliding around and rubbing against belts, pulleys etc?
Thanks,
Steve
Old 03-18-2009, 03:18 PM   #9366
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by stephenianjames View Post
Hi guys,
Thanks,
Steve
Widen the pulley, pretty much any good pack is going to hit there. Search this thread, I've posted the instructions.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-18-2009, 03:55 PM   #9367
Hi guys,
Thanks,
Steve
Just use some shims between the alloy spacers on the layshaft and the drive pins. You should be able to fit 0.2mm on both sides which stops the rubbing. We are waiting on a machine to turn up this week then we will be making a replacement layshaft the dosen't have this problem plus has a normal spur adaptor.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-18-2009, 09:44 PM   #9368
Hi guys,
Thanks,
Steve
I have a orion 3200mah 20C, speed energy 4000mah 35C, that is good fit, or you may try some lipo without case such as by energy 3500mah 25C that I think is good for JRXS
billbill4u is offline   Reply With Quote
Old 03-18-2009, 09:56 PM   #9369
Look like it wasnt all that good to save few dollars at Amain hobby according to your signature.
it says
"AMAIN HOBBIES THE WORST WHEN IT COMES TO RC!! "
Old 03-19-2009, 04:43 AM   #9370
Thanks for the replies on fitting Lipos. MikeXray, I've tried searching but in the search function it only reveals the entire thread with hundreds of pages to sift through. Perhaps I'm doing it wrong though.
I can't see how the pullys can be widened although I have no doubt they can be, as you guys say they can. Currently I've fitted a PRS adaptor, and each pulley is hard against the E-clips that secure them to the layshafy, so they have no room to move. Am I missing something simple here?
Thanks,
Steve
Old 03-19-2009, 05:16 AM   #9371
John Tag's Avatar
Trader Rating: 41 (100%+)
I took both my pullies appart and did the following.. Flat sanded plastic side of pully with 120 grit sand paper and remove .5mm off the inside face. Then took metal side of pully and installed on my tire truer as that stud was exact same size as tire axle. I then sanded with emery file(nail file) same amount .5 off inside face. It took a few minutes with metal side. Slapped both ends back together and now have a ton of room to fit any pack. I actually concider this NARROWING pullies.
Note: This is done to larger diameter area on pullies not shaft opening
Hope this helps
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-19-2009, 05:33 AM   #9372
Thanks John for the prompt reply...much appreciated.
I thought about thinning the pullies down but didn't want to weaken the part. Now I know you guys do it , I'll give it a go.
Regards,
Steve
Old 03-19-2009, 05:44 AM   #9373
John Tag's Avatar
Regards,
Steve
When completed my pully area where belt rides is slightly wider than belt. As the Lipos usally rub the larger face of pullies in past so that is area removed.....
Old 03-19-2009, 09:44 PM   #9374
Any brother can help me to improve my losi setup? I start with the kit rubber setup but change to Front AE oil 35 and 17.5lbs / Rear AE oil 30 & 17.5lbs
the track is outdoor asphalt, thx so much
Also, I use 11.5T, what ratio is recomment? I use losi 118t 64p with pinion 48t 64p that is the max limit, I feel the car is not fast enough, I don't have the PRS adaptor it out of stock.........
Old 03-20-2009, 12:33 AM   #9375
dcuz383's Avatar
Talking
Thanks. They had them. I will have them in time for the next race.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
