Old 03-10-2009, 06:27 PM   #9316
Originally Posted by buckeye-mac View Post
Anyone have any luck getting a Trinity 5000 mah lipo,TRI20808, to fit?
I bought one and it seems a little tall in the rear, but the front seems ok.
Sounds like you need to hack away the bulkheads a bit to allow more clearence.
I was looking at the IP5000 on the weekend and it looks like unless they get rid of those bumps they will never fit in the losi. I am interested if anyone has played with the thunderpowers yet.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-10-2009, 06:47 PM   #9317
Trader Rating: 25 (100%+)
well I think I will return it get something else, I guess the Orion 2's fit with no hacking the chassis.
Fastraxx Hobbies 937-322-5052
WWW.Fastraxxhobbies.com
buckeye-mac is offline   Reply With Quote
Old 03-10-2009, 07:26 PM   #9318
Mayb we need to look at a better way to fit a lipo. If you made something to retain the front of the lipo you could hack away the lipo tray and that alone would make for a better fit.
Powered by Falco
Old 03-10-2009, 09:27 PM   #9319
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Can someone please provide a starting setup for a low-bite unprepared asphalt parking lot course. They use syrup to help with traction. Any help would be much appreciated!
Thanks!
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 03-11-2009, 05:43 AM   #9320
Thanks!
I would start with the kit rubber setup for low grip and work from there.
Powered by Falco
Old 03-11-2009, 10:45 AM   #9321
I have seen that setup but wanted to see if there was an improved setup that has been modified after years of testing and finding things that work and dont work.
Any help would be appreciated!
Chirag
Old 03-11-2009, 02:00 PM   #9322
Chirag
If you want I can post up my current setup. I have only run this chassis for 3 meets so far and have yet to get swaybars for it but so far I have been destroying the usual field at my club in 10.5. This is rubber on low grip asphalt.
Powered by Falco
Old 03-11-2009, 02:14 PM   #9323
Sure! Any help would be appreciated.
Anyone recommend starting point sway bars for low-bite asphalt?
Old 03-11-2009, 02:57 PM   #9324
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
yes please post
i would like to see what you run for a setup.
i also run rubber on low grip asphalt
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 03-11-2009, 05:12 PM   #9325
MikeXray's Avatar
Trader Rating: 73 (100%+)
I've got a set of alum XXX-S rear hubs NIP, they are the same as the hubs that come on the type-r. I've attached a pic, $40 shipped. PM me if your interested.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-11-2009, 08:52 PM   #9326
Yeti35's Avatar
Do you break alot of rear hubs or is it about the red color?
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 03-11-2009, 09:01 PM   #9327
Mike Haynes's Avatar
Hey i have some of those, they looks so perdy...
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-11-2009, 09:32 PM   #9328
Yeti35's Avatar
Not so much on a car that is pretty much all purple though!
22 3.0SR
Old 03-11-2009, 10:55 PM   #9329
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default 41 tooth VS 42 tooth front one way pulley.
I recently found that I have been running the 41 tooth front pulley on my one way and it has been very twitchy. Swapped it for a 42 tooth and had to re-tune the car some and it was better/smoother. Is the 41tooth/overdrive change usually reserved for Asphalt? The car was all over the place in a chicane and lost rear grip during off throttle and worse when braking, and now the car is predictable. Running the Haynes IIc carpet set-up with 20lb front springs.
Just some info, share your thoughts too.
Jaz406 is offline   Reply With Quote
Old 03-11-2009, 11:49 PM   #9330
Hi,
i run a typre R at Tempe in 17.5. the guy i bought my car off had it setup for foam so i have no idea where to go from here. i would be interested to see your setup!
im running a front one way, is it worth it with a 17.5?
brett240 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
