Old 03-08-2009, 10:41 PM   #9301
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by Jaz406 View Post
I think it the weight down the center does not allow for the same amount of weight transfer as other cars so spring pressure is needed to make the car "grip"
I would have thought that the low polar weight of the car would mean the car rolls less than other cars and you would go softer to get a bit more roll.Doesn't more roll mean more weight over the outside wheels?
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-08-2009, 11:44 PM   #9302
Sorry guys but I can't understand the concept of low rear, high front. I would imagine that you would get a monster reactive front end that throws the back around like a toy into turns but then understeers like crazy. This would work with foam but not rubberz. You must be runnning on funny tracks to use such a setup or just insane grip levels.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-09-2009, 12:19 AM   #9303
I agree with you 100%. And that is how my car felt too. But you have to agree that if people like Larry Fairtrace, Todd Hodge and Jason Schreffler use these setups to great success in some of the world biggest events there must be some good in it.
It just may be that they do race on tracks with very high grip levels. The setup attached is Larry Fairtrace's winning setup from last years Reedy Race.
Paul H
Old 03-09-2009, 12:25 AM   #9304
dcuz383's Avatar
Originally Posted by morris View Post
looks good to me...what lipo is that in there..still running nimh here..
Losi 7.2V 4400mAh High Performance Lipo
dcuz383 is offline   Reply With Quote
Old 03-09-2009, 01:04 AM   #9305
Just thought I would post a few pics of my adjusted layout on my chassis with the new speedy.
Speedy on the right, mounted side on and against battery tray to keep weight near center.
I removed the solder posts and put the wires straight into the holes to reduce weight up high and help keep things a little lower.
Power wires are setup to use packs with terminals on either side.
The capacitor is behind the speedy with the switch on top.
All wires excluding power and motor run under the top deck to keep weight low.
Reciever on left up near the front with transponder under and in front of the front diff.
There is 40g on front left in front of reciever to balnce chassis left to right.
There is 60g over the front with 20g on the back of the servo, 20g on the back side of the front bumper (nice spot here being well forward), and 20g around the transponder.
The weight and placement gives the chassis 52/48% f/r weight balance and a ready to run weight of 1488g (without swaybars which should turn up tomorrow)
There is also a fan heatsink on the motor but I have yet to put the fan on it which will slightly effect the balance but it won't be much.
This layout was not to bad to drive considering there was no swaybars and was over 0.5sec a lap up on the nearest guy in 10.5 rubber at my home club.
Team Losi JRXS Type-R-pic_00025.jpg   Team Losi JRXS Type-R-pic_00026.jpg   Team Losi JRXS Type-R-pic_00029.jpg   Team Losi JRXS Type-R-pic_00033.jpg
Powered by Falco
Old 03-10-2009, 05:27 AM   #9306
Trader Rating: 21 (100%+)
Default 1 of my Type R for sale
I have a Type R for sale RTR listed below:
Losi Type R (RTR) Rubber Setup
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 03-10-2009, 07:08 AM   #9307
Mike Haynes's Avatar
That has always been popular to help get rubber cars to rotate and have a good balance, the high front pin keeps the car from washing or just dumping on the nose especially when running a spool.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-10-2009, 08:11 AM   #9308
So does that mean high rear pins will help settle down to much rotation? My car is turning in great but doesn't want to stop rotating causing me to have to be realy carefull getting back on power.
I've tried different camber link combinations and different spring rates but it always wants to keep turning. The only thing working is very soft(10.5lb) rear springs.
Thanks for continuing to help out us Type R guy's.
Paul H
Old 03-10-2009, 12:30 PM   #9309
Higher rear pins will usually give you more rear side bite, you may also consider running more toe in, i was runner 4 per side in rubber the last few races i ran a type r.
Old 03-10-2009, 01:18 PM   #9310
hamster778's Avatar
Send a message via MSN to hamster778
Hi Mike.
I'm one of the few peeps using the type R over here in the UK, I still think its great. I haven't done too bad with the car in Pro-stock (10.5 b/l). For this year going back to Mod. Should be fun (Losi better make lots of spares).
Would you able to post up or send me ( To post on my setup pages ) your final rubbers setups. Did you just use the 1 deg toe in blocks with the 2 deg pivot or did you achieve it another way.
Many thanks for all the help you gave us over the time with the team. All the best with the Mission.
Cheers
Tim
hamster778 is offline   Reply With Quote
Old 03-10-2009, 02:12 PM   #9311
Well my swaybars should be here this week so I'll run them 1st then try high rollcenters the following meet.
Powered by Falco
Old 03-10-2009, 03:31 PM   #9312
jag88's Avatar
Mike, when running the higher rear pins do (did) you raise the rear inner camber link at the same time to keep the same camber gain ?
Thanks.
jag88 is offline   Reply With Quote
Old 03-10-2009, 03:47 PM   #9313
Thanks.
Generally you try to match the angle to what you had before otherwise you are making two changes at once.
Powered by Falco
Old 03-10-2009, 04:39 PM   #9314
MikeXray's Avatar
Trader Rating: 72 (100%+)
Thanks.
I'm sure mike has tried that link, but no we do not change it with the pin height, typically if we change the link it will be shorter, or going from inside to outside on the hub.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-10-2009, 05:55 PM   #9315
Trader Rating: 25 (100%+)
Anyone have any luck getting a Trinity 5000 mah lipo,TRI20808, to fit?
I bought one and it seems a little tall in the rear, but the front seems ok.
Fastraxx Hobbies 937-322-5052
WWW.Fastraxxhobbies.com
buckeye-mac is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
SEO by vBSEO 3.5.0
