Old 02-28-2009, 12:18 PM   #9226
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Originally Posted by Hetfield6J View Post
Hi all. I'm new to electric sedan, and recently purchased a type-R. I must have made a mistake on the front diff assembly because when i turn any of the wheels without all the wheels moving, it loosens the diff to the point it would actually come apart if you kept turning. I un-assembled and re-assembled the diff with no effect. Any quick idea's on what may be causing it?
Thanks for any help.
Look for a mispackaged diff spring that is too long. In my friends kit they included two diff springs that were black in color and too long. The diff springs are silver and when installed the diff screw will be close to the "v" on the dif tube. The incorrect spring will show on the "v" area of the diff tube.
Jaz406 is offline   Reply With Quote
Old 02-28-2009, 02:25 PM   #9227
Default Need Help !! Losi type-r
sold
Brooklyn41 is offline   Reply With Quote
Old 02-28-2009, 03:20 PM   #9228
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
ones that ive seen that are really small in the type-r are the orion 3200 carbon editions and the 3400 25c race spec orion as well. Maybe those will work.
Syber Serulean is offline   Reply With Quote
Old 02-28-2009, 06:13 PM   #9229
Originally Posted by brett240 View Post
Hi,
what thermofans for the motor is recommended and where is the best place to locate them on the type R? i know there is 3 positions.
how do they get wired in?
can anyone help? i have a brushless 17.5 which runs pretty hot.
brett240 is offline   Reply With Quote
Old 02-28-2009, 06:20 PM   #9230
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Fans seem pretty inefficient considering today's brushless motors and the lack of vents. There would be no penetrating cool, and only the outside will be slightly effected. Your best bet would be to gear down.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-28-2009, 06:24 PM   #9231
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
yes the fan doesnt do crap correct me if im wrong but be close to a 3.5 fdr and that should lower the temp
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 02-28-2009, 06:47 PM   #9232
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by jrp View Post
Rubber Tire Newbie here...
Running pretty much Haynes setup on med bite carpet with Jaco Blues. Car works pretty good, but in a few corners wants to traction roll too easy. Have tried various changes, but really haven't gotten the traction roll out of it. Throw some ideas at me to try.
Thanks in advance.
i tride his set-up as well to....lay the front shocks down all the way...how are you setting droop?
i run 2mm over ride height...lmk
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 02-28-2009, 06:54 PM   #9233
when i have traction rolling problems i add more droop
W.P.A.C crawlers
The Raceway
Old 02-28-2009, 07:28 PM   #9234
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i think that adding drrop makes it worse....
i ran mikes setup and i could not get it to tip......if anthing it was too stable.....
make sure the car is square and not bound up.....just how you set ride height, tweek, and droop can make your car handle poorly
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 02-28-2009, 08:48 PM   #9235
decibels's Avatar
Its quite simple a fan by itself won't do jack really but if you get a heat sink fan then you can drop your temps by 10 to 15 degrees. i think my heatsink fan is yeah racing. but basically with the extra surface area of the heatsink it has to first heat the heatsink but with the air flow from the fan it's harder to get hot. i recommend that you have thin long fins and that you run your fan at 7.2 volt. this enables me to go from 38mm rollout on my sp 10.5 to 41mm rollout without going over 75 degrees celcius and really wakes up the motor as sometimes undergearing is no good for some spec motors. hope this is helpful but i consider it a must to any spec racer!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 02-28-2009, 09:50 PM   #9236
Yeti35's Avatar
I'll run 6 degree on a large asphalt track... It has too little on-power steering for carpet though. On carpet i'll run 4 degrees, 2 degrees is a little much, and 0 degrees is damn near undrivable.
Are you running the 6 degree with rubber of foam on carpet? I run 4 degree with rubber and 6 with foam. There is plenty of on power steering when running them with foam. I personally never had an issue running the 4 degree on asphalt with rubber. That is the only hub I run on asphalt.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 03-01-2009, 12:33 AM   #9237
Yeah, i should have specified that the 4 on carpet is rubber. On foam i forgot to mention that i ran 6 degree. I havn't ran foam since 2007 though.
About asphalt, it depends what track... If i go to a larger track (that caters more to the nitro guys) i'll run 6, a smaller track 4. I've never tried 8 degrees anywhere and i havn't found any practical use for 0 and 2, plus, its easier to keep a pit box full of 4's.
Old 03-01-2009, 07:19 AM   #9238
Has anybody had any problem with servo arm going on a jr servo, i have the jrx-s type r and any suggestions on where to mount the esc and reciever I just got done building it I am going to run the novak gtb and futaba 2.4 reciever just curious where some good advice on mounting locations are any info would be helpful,thanks.
ripnroar is offline   Reply With Quote
Old 03-01-2009, 07:44 AM   #9239
Mount them both towards the front of the car, it helps balance weight front to back.
dasdaman is offline   Reply With Quote
Old 03-01-2009, 11:22 AM   #9240
Hi guys,
I recently bought and built up a Type R to race here in Australia. I haven't actually raced it yet as I'm going to try it out in 17.5T brushless stock (I tried a 10.5T brushless not having driven one before and found it too quick for my skill level just now). I have a couple of questions if I may:
(1) Can you buy the 4 degree C hubs just in pairs without the steering knuckles?
(2) Is the car considered to be generally pretty robust? In my couple of testing outings with the 10.5, clipped the boards pretty lightly and broke a suspension arm and a c-hub on separate occasions.
(3) Are there any aftermarket parts that are stronger than the kit parts? (like the aforementioned arms and c-hubs)
Thanks in advance,
Steve
stephenianjames is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
