Old 02-25-2009, 03:58 PM   #9166
Mark506's Avatar
Trader Rating: 41 (100%+)
Ive seen most people run there ESC down the left side, sometimes vertical, and reciever on opposite side.
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 02-25-2009, 04:01 PM   #9167
EViLSouL's Avatar
Send a message via AIM to EViLSouL
Originally Posted by Dragonfire View Post
Thats sucks. You gotta wonder if the packers at losi drink while they work. I got the wrong diff springs in my kit and 3x front arms and 1x rear arm. I knew my setup skillz would be tested trying to get that to work!
I had the same problem with the diff springs. Was missing two bulkheads too. Didnt notice the diff springs at first. Horizon did fix the bulkhead issue. Packager #38 had a brain fart the day he packaged my parts
EViLSouL is offline   Reply With Quote
Old 02-25-2009, 05:01 PM   #9168
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by sickjamminracer View Post
hey having troublw figuring out how exactly to mount electronics could you post a pic of yours please?
I don't have any pics, and my car is in peices now.
Basically, here's the rundown...
The speedcontrol (xcelorin) is on the driver's side, servo taped to both the bottom deck as the well the first top deck standoff. The speedcontrol is on it's side leaving the motor and batt. wires on the rear side of the car. The capacitor is directly by and behind the motor sensor cables as well as the power wires, mounted stood up as if it where a can of soda. The receiver lead is routed above the battery under the top deck. The receiver is on the passenger side (spektrum pro HRS for futaba) mounted flat as if it normally would be mounted, however, the ports are facing the inside of the vehicle for a easier and tidier lead setup. It is mounted up next to the standoff but only taped on the side touching the chassis. The transponder is under the front diff. The battery wires (bullet-style connecters) are cut at about equal length, the negitive wire is placed under the belt and does not have the ability to reach the positive terminal, the positive wire reaches over the belt to the positive terminal.
Hope this helps? lol...
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-25-2009, 05:29 PM   #9169
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
hows this for my first wiring job
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 02-25-2009, 05:36 PM   #9170
Mark506's Avatar
Cut the wires, then run the along the chassis for a cleaner look
Mark Ament
Old 02-25-2009, 05:37 PM   #9171
Not bad, i'd shorten the motor wires ALOT and get rid of the mile long sensor wire (150-175mm should work fine), and you probably won't be able to fit the batt. leads under the top deck wit a pack it, also, you may be able to run the servo lead behind the servo between the bottom of it and the bulkead and between the side of it and the arm mount, it keeps alot of it out of veiw, but i don't know about your servo size (i run a jr 9000s)
Old 02-25-2009, 05:37 PM   #9172
ya but then its hanging off the chassis
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 05:38 PM   #9173
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
hey guys i was putting my type r together and found parts to be wrong/mising does anybody have these parts and can over night them to me i can paypal you the $$
i need a ball stud for the steering rack (mine broke when tightening it)
2 shock ends(missing from kit) and a shock standoff for the shock tower (made wrong they are all different sizes) please pm me if you can help a racer out thanks cody
Contact Losi about the missing parts. They are the ones that screwed it up.
crazy4wdracer is offline   Reply With Quote
Old 02-25-2009, 05:40 PM   #9174
yeah, but so is your speedo and cap.
I've never had an issue with the wires on the side. EVER. even when running brushed a couple years ago. I broke the sh!t outta my speed control fan though the first time i got t-boned.
Old 02-25-2009, 05:41 PM   #9175
i called was on hold for over 2 hours then i got through and the dumbass acidently hung the phone up
read that
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 05:41 PM   #9176
If you want to keep them that long, you might as well move the speed control to the passenger side.
Old 02-25-2009, 05:43 PM   #9177
read that
Oh, I missed that part.
Old 02-25-2009, 05:45 PM   #9178
its not about the length if i would run them the other way like mark suggested they hang off the end of the chassis and if i got hit i dont think that would turn out to good -------
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 06:27 PM   #9179
hi guys,
just wondering if the steel lipo tray is still available and who stocks it?
thanks.
brett240 is offline   Reply With Quote
Old 02-25-2009, 06:32 PM   #9180
Originally Posted by brett240 View Post
hi guys,
thanks.
yes it is amainhobbies.com sells it
W.P.A.C crawlers
The Raceway
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
