Old 02-24-2009, 10:07 AM   #9151
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by metalracer2 View Post
I need a little help with my set up
The car has a push in the high-speed turns and in the entrance of the turns but it turns good mid to exit.
Also the rear wants to come lose on the exit or a turn
How big of a deal is it to have a washer under the ball stud on the spindle and what does it do for handling wise?
something is up with the attachment, its small and unreadable.
A washer under the front spindle will give a little more camber gain, I personally prefer the way the cars drives this way, feels like it has more sidebite.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-24-2009, 11:14 AM   #9152
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i can get it to work right but this is what it is
Front
Toe: 1out
Ride height: 5mm
Caster: 4
Droop: 3
Roll Center: high
Arm Spacing: middle
Shock Position: 2
Steering Rack: 2 no washer
Spindle: 1 no washer
Camber link: 1 ball stud lois long
Sway bar: .040
Arm length: long
Spool 41 high, lcd, Hex .165 stk
Shocks
45 losi, 56 piston black bladder, spring 17.5
Rear
Toe: 2
Ride height: 5mm
Camber: -2
Anti Squat: .030
Std Hub
Rear pivot 1 degree
Roll center low
Arm spacing; short
Shock position: 2 outside
Camber link: 7B standard ball stud
Say Bar: .030
Long arm
Diff high, rcd, hex .165stk
Shocks
40 lois, spring 15, black bladder
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 02-24-2009, 11:40 AM   #9153
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Pablo Diablo View Post
Definitely for real. Around 2 weeks from the first production run. We really want to be sure they are spot on before they are released. This is the first part we will release to the public and our reputation will ride on its quality.
Thanks for your interest. Just keep in touch with this thread and you'll be up to date.
I'm interested as well. Please check your PM.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 02-24-2009, 11:44 AM   #9154
MikeXray's Avatar
Front
Toe: 1out
Ride height: 5mm
Caster: 4
Droop: 3
Roll Center: high
Arm Spacing: middle
Shock Position: 2
Sway bar: .040
Arm length: long
Shocks
Rear
Toe: 2
Ride height: 5mm
Camber: -2
Anti Squat: .030
Std Hub
Rear pivot 1 degree
Roll center low
Arm spacing; short
Say Bar: .030
Long arm
Shocks
I'd say for a quick test disconnect both bars.
I just put most of this setup on my car, I need to go back and add shims for kickup, car needs just a bit more turn in, and lots of rip, GTB's suck
http://www.petitrc.com/reglages/losi...ip20081130.htm
Old 02-24-2009, 12:37 PM   #9155
i will give it a try but i'm not sure how well it will work for me some of the traks i run on are in parkinglots and thet have no grip.
but i'm hoping that will change
there are two tracks opening within a hours drive of me and i think one is going to be carpet and the other is going to be concret
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 02-25-2009, 01:30 PM   #9156
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
hey guys i was putting my type r together and found parts to be wrong/mising does anybody have these parts and can over night them to me i can paypal you the $$
i need a ball stud for the steering rack (mine broke when tightening it)
2 shock ends(missing from kit) and a shock standoff for the shock tower (made wrong they are all different sizes) please pm me if you can help a racer out thanks cody
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 02-25-2009, 01:39 PM   #9157
Thats sucks. You gotta wonder if the packers at losi drink while they work. I got the wrong diff springs in my kit and 3x front arms and 1x rear arm. I knew my setup skillz would be tested trying to get that to work!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 02-25-2009, 01:41 PM   #9158
LOL ya im just kinda mad cuz i want to race it this sunday for the first time(i used to run the origanal jrxs) but i probably wont be able to i talked to the hobby shops around here none of them have the parts i need
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 01:42 PM   #9159
I WOULD CALL LOSI AND ASK THEN TO SEND YOU THE PARTS OVER NIGHT
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 02-25-2009, 01:45 PM   #9160
i called was on hold for over 2 hours then i got through and the dumbass acidently hung the phone up
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 01:46 PM   #9161
i have a question whats the purpose of the center body post ?? just wondering cuz i left it off on my old car
W.P.A.C crawlers
The Raceway
Old 02-25-2009, 01:52 PM   #9162
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
PM me what you need I'll get it out for you tomorrow. I'll get the parts back from Losi. Dont want you to miss out too many weekends on running this lovely car.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-25-2009, 02:17 PM   #9163
rocketron's Avatar
Trader Rating: 16 (100%+)
Please PM me the part numbers you need and I'll get this taken care of for you. I'll get it turned around the same day I receive the list.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 02-25-2009, 03:51 PM   #9164
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Hood and window support for lightweight bodies and mod classes, supposively to maintain frontal downforce at high speed.
I don't know if anybody is using it though.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-25-2009, 03:55 PM   #9165
hey having troublw figuring out how exactly to mount electronics could you post a pic of yours please?
W.P.A.C crawlers
The Raceway
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
