Old 02-22-2009, 01:14 PM   #9121
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Allright, all these measurements are with a custom lipo tray that is flush with the chassis-
Height avaliable- 23.3mm (21.3mm at the bulkheads)
Width avaliable - 46.5mm at the pulleys (un-modified)
Length avaliable-aprox. 139 mm with un modified bulkhead and jr 9000s servo with no serrvo mount spacers.
The orion lipo (3200) is 46.1mm at widest point, 137.5 mm long, and 23mm tall including the cell "bumps".
Looks like you got some pulley widening to do!! its pretty easy, mikexray posted how to do it a few posts back.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-22-2009, 01:51 PM   #9122
Originally Posted by a_main_attendee View Post
Another thing to consider would be the location of the leads coming from the pack, most top-exiting leads won't work, but most bullet connecter holes will.
I'll measure my chassis and orion batt to give ya an idea of space needed. I'll be back.
I dremeled my top deck to provide a bit more clearence for this. You also need to make sure your wires come out of your plugs at close to 90 degrees to clear the steering bellcranks. I am thinking of triming the servo saver horn a bit to provide more clearence here.
There is a guy here in oz making up a replacement layshaft that incorporates a spur gear mount for normal spurs. I might get him to have a good look at the pulley clearence issue and he could solve that problem along with a spur gear adaptor. You also get a much lighter layshaft so a bit more punch in spec racing.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 02-22-2009, 03:47 PM   #9123
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
The old orions (3200/4800), the losi lipos (5000 20c/4400 30c)
Those are for sure able to fit, i beleive the trakpower 4900 fits as well as the older 28c SMC 4000, but i'm not 100% sure...
so the losi lipos are direct fit no modding to anything correct?
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 02-22-2009, 03:55 PM   #9124
That's what i've heard!
Old 02-22-2009, 03:59 PM   #9125
you run a losi lipo dont you ?
W.P.A.C crawlers
The Raceway
Old 02-22-2009, 04:02 PM   #9126
Actually, no.
Currantly the old a$$ orions.
I have a TP 40c coming though, i don't mind a little modding.
Old 02-22-2009, 04:04 PM   #9127
Actually, no.
i wouldnt either but the car is new and its my baby and i dont want to hurt her also when you go to resell it the price value will decrease because of the modding
W.P.A.C crawlers
The Raceway
Old 02-22-2009, 04:37 PM   #9128
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
You have to widen the pulleys for this one too.
If you take your time and do it right this would not decrease the value
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 02-22-2009, 05:19 PM   #9129
MikeXray's Avatar
Trader Rating: 73 (100%+)
They lose half their value as soon as their run modded or not
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-22-2009, 05:59 PM   #9130
Andy Crosson's Avatar
The SMC 5000 28c takes quite a bit of drilling and a lot modifications. It took a while to dremel 3-4mm off the rear bulkhead. I know that trakpower 4900's, flightpower 5400's and the orion 5000 fit right in with no modifications. I know there a lot of other batteries out there that fit but those are the ones I know fit from my personal experience.
www.hobbyplexraceway.com
Ken's Graf/x | Stickit1
Team Losi Racing | Spektrum | ORCA | Tekin
2011 8-Hour & 2010 2.4-Hour Trans-Am Enduro Champions: Me, Wilcox, Hatcher, Romanik
Andy Crosson is offline   Reply With Quote
Old 02-22-2009, 06:58 PM   #9131
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
still for sale, lowered price. great car!
Team Losi JRXS Trype R sedan and parts
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 02-23-2009, 06:09 AM   #9132
jrxs-r's Avatar
I'm interested.... I've got all my pullies lathed down already, so as long as the layshaft takes standard drive pullies it will be good. Have you got a contact?
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 02-23-2009, 06:27 AM   #9133
well if the orion 5000 fits in shouldnt the 3800 orion fit in?? (the 3800 should be smaller?)
W.P.A.C crawlers
The Raceway
Old 02-23-2009, 06:34 AM   #9134
do you mean this pack??
http://www.amainhobbies.com/product_...ducts_id/31890
my pack is
Length: 136mm (5.3")
Width: 47mm (1.85")
Height: 22mm (0.87")
and the orion 5000 is
Length: 137.5mm
Width: 47mm
Height: 23mm
so that means it should fit with no mods
W.P.A.C crawlers
The Raceway
Old 02-23-2009, 07:09 AM   #9135
Hey all,
I was absentmindedly building a brand new diff while watching TV. Built it right but then tightened it too much; it went "click." I loosened it and turned it, and it just clicks like a bike one-way. Then I took it apart, checked all the parts (they look fine; the thrust rolls fine it seems) regreased everything and put it back together. Now it has crunchy spots evenly around its rotation. Do you know what part is causing this trouble?
Thanks.
Yub, yub, cmdr! is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Deano
