Old 02-11-2009, 09:01 PM   #9001
MaxRain's Avatar
Originally Posted by StadiumChris View Post
Zip file is Invalid
attached is the file again.. I also included my version of the setup sheet
So has anyone come up with an ingenious way to mark their springs?
I mark my springs with a silver sharpie. I got mine at home depot. This works much better than adding weight or using the dremel to mark the spring.
Originally Posted by jag88 View Post
I was rebuilding the diff and noticed that no matter how tight I set the diff it still slips. I figured out that the suspect part is the plastic diff drive (LOSA3318). With all that aluminum it still acts like a plactic diff because of that one part. It can't stand up to the clamping force exerted by the screw.
Does anybody know of an aluminum replacement part ?
Thanks.
I had the same problem and fixed this by grinding a 4-40 nut small enough to slide into the hub. My diff never comes loose after this mod.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 02-11-2009, 09:14 PM   #9002
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by VenturaDC View Post
ive been running this car for about a year now and have only broke one c-hub, and ive had my share of meetings with the boards, did u file down the axel that sticks past the wheel nut? helps alot
you have to cut your axles other wise the c-hubs will break very easy... also I run a parma bumper on my cars
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 02-11-2009, 09:33 PM   #9003
Yeti35's Avatar
Interesting, I was wondering about that. Why would they design the diff to slip a little when everyone else has 'd' rings on both halves ? I would think the mod foam guys would
hate that.
Thanks.
I actually think it was designed this way for Mod drivers. Todd made mention of it that it allows a little slip to save the diffs from frequent rebuilds. So yes, it was made that way on purpose.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 02-12-2009, 06:38 AM   #9004
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
My car has a wider hex on the front, and the axles do not protrude outside the nuts. Its crazy how easy they seem to break though!
jrp is offline   Reply With Quote
Old 02-12-2009, 06:41 AM   #9005
Xpress's Avatar
Are you using the EA-3 or graphite parts? I have yet to break an EA-3 caster block in over a year of running the car.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-12-2009, 06:53 AM   #9006
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Havent broke a C hub in a year or so probably. EA3 is way more durable than the graphite.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-12-2009, 06:57 AM   #9007
jrp
jrp's Avatar
I'll have to check. I am still getting up to speed on this car. I suspect they are not EA3. Thanks for the tip.
Old 02-12-2009, 06:58 AM   #9008
MikeXray's Avatar
Trader Rating: 73 (100%+)
I honestly believe that some batches of parts are better than others. I have put a kydex bymper from a phi under a hard parma bumper on my car (a few people at our track now run this), it needs some trimming, but nothing crazy, and 2 holes for the posts. This helps a lot.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-12-2009, 07:06 AM   #9009
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
same here.
with my xray, I was breaking chub almost everynight. + the xray part are double the price of losi price !!!!!
do you have a good bumper?
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 02-12-2009, 07:17 AM   #9010
jrp
jrp's Avatar
Just checked and my C hubs are EA3.
The only bumper on the car is the Losi foam bumper with the small plastic bumper assembly that holds the body posts.
I am not a beginner, so its not a constant crashfest or anything.
Old 02-12-2009, 07:33 AM   #9011
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
I havenít cut my axles yet and I havenít broken a c hub in about a year.
But now that I say that I will break one the next time out
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 02-12-2009, 12:40 PM   #9012
anyone know where i can get a conversion kit to turn a jrxs to a type r
MiniMike is offline   Reply With Quote
Old 02-12-2009, 12:46 PM   #9013
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Both cars only really share spur gears, spur shafts, bearings, hubs and caster blocks... It really wouldn't be worth it. It would be FAR more economical to purchase either a new or used Type R.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-12-2009, 12:50 PM   #9014
Glad I read that. I was leaning towards upgrading.
ricktheracer is offline   Reply With Quote
Old 02-12-2009, 08:40 PM   #9015
Yeti35's Avatar
Chassis's are completely different. The only upgrade would be to sell your JRXS and get a Type R.
22 2.0
22T 2.0
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
