Old 02-04-2009, 07:27 PM   #8956
Mike Haynes's Avatar
Originally Posted by Jaz406 View Post
Thanks Dragon,
I run Mike Haynes IIC rubber tire setup and Jaco greens. I currently have the front inner link @ short upper location and 1mm spacer under outside link on hub. It increases initial steering response.
I am suffering from severe on power push and I'm down to 2* rear toe but still not helping enough. Thought about reversing the .5* rear hub to take out more is that possible?
That is possible however i would recommend the 41 pulley up front instead, then you will have gobs of on power steering.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-04-2009, 08:35 PM   #8957
Rommel's Avatar
Now Available!
Custom Cut Urethane Chassis Protector for Losi JRX-S Type R #LOSA4305 chassis!
Rommel is offline   Reply With Quote
Old 02-05-2009, 12:55 AM   #8958
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Sad thing is I saw that in an earlier post and installed it on the one-way a few weeks ago. Front droop is at 1mm O.R.H. rear is at 2mm. I'll post the setup so you all can see how it looks. wish I had the setup sheet on pdf.
Too much weight transfer to rear on accel?
Thanks Mr. Losi for yours.
Mike, Larry congrats on the Snowbirds showing!
Jaz406 is offline   Reply With Quote
Old 02-05-2009, 09:37 AM   #8959
Easy way to save a setup sheet since you can't save the pdf is fill it out and then use the snapshot tool to copy the entire thing into a photoshop type program and save as a jpg. You can't modify it later, but at least you'll be able to share it.
Yes you are right on the reason. Too much weight is being transferred to the back of the car relative to the front of the car. So when you are in a turn, the car turns when the weight is on the front tires. When you accelerate, it transfers the weight off the front tires and back to the rear tires causing that on power push.
JoelV is offline   Reply With Quote
Old 02-05-2009, 04:53 PM   #8960
I would need the modifiable pdf and then could save it as jpg have done that for the Cyclone sheets in the past.
So thicker oil in the rear or rear anti squat?
Old 02-05-2009, 04:59 PM   #8961
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Anyone have a good starting setup for asphalt rubber. It is a unprepared parking lot that gets wiped down and covered in syrup. Can be a little dusty at times and traction is sometimes a problem. I would be running 17.5 and 13.5 Any help would be appreciated.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 02-05-2009, 05:02 PM   #8962
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Hey,
The DHW track is inconsistent. Each time I have gone, the car and grip were extremely different. Hopefully one of the locals has a TypeR and can help you out.
IIGQ4U is offline   Reply With Quote
Old 02-05-2009, 05:30 PM   #8963
Trader Rating: 21 (100%+)
editable PFD file for Type R
http://www.gearchart.com/setup/setup...XS-R_blank.pdf
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 02-05-2009, 05:41 PM   #8964
J@UNE's Avatar
Default Setup
Mike, Larry,
Any updated setup from the birds or fastcats or they are similar to the vegas ones?
Thanx
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 02-05-2009, 06:04 PM   #8965
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by J@UNE View Post
Mike, Larry,
Thanx
Hey Jon,
I can't talk for Mike and Larry about rubber setups, but as for FOAM tire stuff, setups really didn't change at all. All we did was change shock oil. 60wt front/50wt rear. Other than that, everything else is the same. The car is still unreal on foam tires.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-06-2009, 11:26 AM   #8966
hamster778's Avatar
Send a message via MSN to hamster778
Originally Posted by mr. losi View Post
front
45 wt oil 56 piston losi oil
17.5 spring
0 toe
5.5 ride height
no kick or anti
4 deg caster
1mm over ride height
0 deg ft pivot
low+.030(gold washer) roll center
mid arm
shock position 2
steering rack 2
spindle 1
camber link 1
reg ballstud on camber link
one way
.225 ft width
rear
30wt losi oil
56 piston
12.5 spring
3 deg toe(1 on hub, 1 deg pivot)
5.5 ride height,
droop 2mm over
-2 deg camber
low roll +0.030
low diff
.195 width
5 a camber +0.030 under ballstud
shock 1 outside
speed 6
Hi guys, I have posted on here for ages, but been reading when i can though.
I'll be add your setup to my setup web pages. It has a editable pdf setup sheet too.
http://team-spoon.bravehost.com/
If you have any more that you would like post up there, feel free to email them to me.
Cheers
Tim
hamster778 is offline   Reply With Quote
Old 02-07-2009, 09:41 AM   #8967
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
I just got a type R. does anybody know where I can get a new one-way for it?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 02-07-2009, 10:34 AM   #8968
J@UNE's Avatar
Originally Posted by schreff View Post
Hey Jon,
Thanks shreff! I miss running foam so much
Jon Gagnon
DirtTrax - Team FLR
Old 02-07-2009, 11:52 AM   #8969
Losi parts house, Stormer hobbies, A main hobbies.
Old 02-08-2009, 10:49 PM   #8970
MaxRain's Avatar
Default FDR and rollout calculator
I created this as I don't have access to gearchart at all times..
It is an excel spreadsheet. You can customize the sheet to suit your needs
Any comments or questions, feel free to ask.
Note this sheet will calculate FDR and rollout with 41 and 42 pulleys.. To do so, make sure you change the number at the top of the sheet.
Gordon
Gordon
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://youtu.be/owXBpsQkyjE
Facebook: CARCAR
MaxRain is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
