Old 01-28-2009, 06:46 AM   #8896
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by a_main_attendee View Post
So who's running tha losi car in florida right now?
schreff, haynes, fairtrace, I believe Goetter went too.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-28-2009, 08:11 AM   #8897
StewartFan20's Avatar
Mr Haynes (or anyone that may know ),
On your rubber tire setup for the 2008 IIC, are the droop settings you have (1mm front and 2mm rear) measured over ride height or using a droop gauge?
Also, does anyone know how the Trinity oil compare to the Losi oil?
I am having issues getting the rear end to stick. It is really loose. I started with the IIC setup, but I am using Losi oil instead of Trinity. I have added an additional shim under the outer camber link in the rear (now have two), gone down to 35wt shock oil and 15lb springs in the rear.
Any suggestions?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 01-28-2009, 08:28 AM   #8898
Jerry P's Avatar
Trader Rating: 44 (100%+)
Any suggestions?
It's over ride height. I've never seen haynes use a droop guage.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-28-2009, 08:31 AM   #8899
MikeXray's Avatar
Any suggestions?
what tires are you running?
Old 01-28-2009, 08:37 AM   #8900
Jaco Greens.
Old 01-28-2009, 08:46 AM   #8901
MikeXray's Avatar
Jaco Greens.
that's interesting, usually greens have so much grip they make my car push. A few things to try would be low rear diff, 2dg camber, lay down the rear shock one hole, and goto a .040 sway bar.
Old 01-28-2009, 09:04 AM   #8902
We have a pretty low traction track. Thanks for the advice, I'll try that next time out.
I wonder if the tires are worn out. The seam is gone, but the inserts don't feel broken down.
Old 01-28-2009, 09:47 AM   #8903
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
I see a lot of you guys using Jaco tires on carpet. Will they work on asphalt? Or are they just a carpet tire
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 01-28-2009, 11:19 AM   #8904
Trader Rating: 21 (100%+)
Default tires
They will work on either
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 01-28-2009, 02:37 PM   #8905
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
i have used mikes setup. and spoken to him about it...
i also used losi oil,
the droop is over ride height
going to 35 wt and 15 lb springs will give it MORe steering...
i would check your rear diff settings, make sure your shocks are the same
the car is not tweaked....swaybars ....
for me mikes setup pushed on high traction, and i went to the setup posted above for the novak.....
i do use mikes setup for club racing.....it works very well....
let me us know how it turns out
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 01-28-2009, 02:38 PM   #8906
Administrator
Matt M.'s Avatar
my cars loose rear bite a min or so into the run when the tires are shot
Old 01-28-2009, 06:59 PM   #8907
morris's Avatar
Trader Rating: 40 (100%+)
i am using haynes set-up (spool).
it works good...im using all but the antidive things.
i was also having probs with the ass of the car being loose.
so i went to a long camber link...lowest setting...and a 25 spring in the back...in thoery to me i thought making the rear softer will cure the problem..just to find out it made it come around easier.so went back to square one and went with the 25 spring.
works good....im using jaco greens as well on a low bite track.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-29-2009, 01:04 AM   #8908
Rommel's Avatar
These will be available soon for anyone who might be interested.
Custom Cut Urethane Chassis Protector for Losi JRX-S Type R #LOSA4305 chassis!
Rommel is offline   Reply With Quote
Old 01-29-2009, 07:47 AM   #8909
Administrator
Matt M.'s Avatar
i will take one....
Old 01-29-2009, 12:14 PM   #8910
Rommel's Avatar
If anyone else interested please post on my protector thread and I will let you know when available.
Originally Posted by mr. losi View Post
i will take one....
PM sent!
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
