Old 01-13-2009, 07:06 PM   #8821
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by Jason View Post
That won't prevent the diff from rotating. Need to put sandpaper disks between the rings and pulley, then lock it down tight. Shouldn't rotate anymore
Actually the way it is designed is to give a little. You merely need it locked down enough to not slip under hard acceleration.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 01-14-2009, 10:17 AM   #8822
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Hi,
I just purchased one of these cars and will be running on asphalt almost exclusively. I was informed that this car is better suited for carpet than asphalt. I was wondering if this car is as competitive on asphalt as it is on carpet?
IIGQ4U is offline   Reply With Quote
Old 01-14-2009, 10:19 AM   #8823
Trader Rating: 21 (100%+)
Default Asphalt
Originally Posted by IIGQ4U View Post
Hi,
The car is very competitive on asphalt.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 01-14-2009, 10:21 AM   #8824
IIGQ4U's Avatar
Great, thanks. I would imagine that as with most cars, you need to find a setup that works for you and the particular surface on which you are racing.
Old 01-14-2009, 04:13 PM   #8825
YmeBP's Avatar
Trader Rating: 32 (100%+)
That won't prevent the diff from rotating. Need to put sandpaper disks between the rings and pulley, then lock it down tight. Leave the balls in the pulley. Shouldn't rotate anymore
Thats the second time i've heard about these "sandpaper disks" i've never seen any do you cut them out yourself?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 01-14-2009, 05:21 PM   #8826
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I ran the same spool all summer with no problems at all, I think I replaced the outdrive with the nut in it one time. Ran 10.5 mostly some 13.5 with no slippage.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 01-14-2009, 07:56 PM   #8827
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
here is the setup that won the novak race in 13.5 , and put another car in the main, it also was used in my car which was 6th in 17.5
front
45 wt oil 56 piston losi oil
17.5 spring
0 toe
2 deg, neg camber
5.5 ride height
no kick or anti
diff low(front and rear)
4 deg caster
1mm over ride height
0 deg ft pivot
low+.030(gold washer) roll center
mid arm
shock position 2
steering rack 2
spindle 1
camber link 1
reg ballstud on camber link
one way
.225 ft width
rear
30wt losi oil
56 piston
12.5 spring
3 deg toe(1 on hub, 1 deg pivot)
5.5 ride height,
droop 2mm over
arm forward
-2 deg camber
low roll +0.030
low diff
.195 width
5 a camber +0.030 under ballstud
shock 1 outside
speed 6
no sway bars
jason used 41 tooth ft drive on his car, while josh adn i used 42....
otherwise the cars were identical
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 01-14-2009, 08:26 PM   #8828
Hey Mr Losi, Thanks for posting that, but I see a couple things missed.
Front Camber
Front diff height
Rear arm spacing
Also, no sway bars at all?
JoelV is offline   Reply With Quote
Old 01-14-2009, 08:40 PM   #8829
Jason's Avatar
Front camber -2*
Diff height low (front and rear)
Rear arms forward
No sway bars
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
Old 01-14-2009, 08:40 PM   #8830
Thank you.
Old 01-14-2009, 08:47 PM   #8831
Jason's Avatar
In rear, I used 2 degree block with 0 degree hubs instead of what Matt used...
Old 01-14-2009, 09:19 PM   #8832
Jason's Avatar
Losi sells a spool pulley. This is actually the part you want instead of making one out of your current parts.http://www.losipartshouse.com/servle...-PULLEY/Detail
Old 01-14-2009, 09:27 PM   #8833
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
That is the wrong pulley, the R pulleys have a larger diameter inner hole, that pulley that you provided a link for is for the JRXS and the XXX-S. It won't work unless you run the original JRXS diff setup on your car currently.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 01-14-2009, 09:32 PM   #8834
Jason's Avatar
Oops, sorry- guess I didn't look into it that much.
Old 01-14-2009, 09:40 PM   #8835
vabroom's Avatar
These are the ones: http://www.losipartshouse.com/servle...ds-cln-/Detail
vabroom is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
