Old 01-09-2009, 02:33 PM   #8806
Andy Crosson's Avatar
And the thing is, is that with the weight setup I posted above ^^^ I put it on scales and both the front and back were within .5 grams of each other with no ajustments. All I did was set the ride height to 5mm the night before.
*If you want to use scales make sure all the arms, spindles, etc. are completely free. I had a car that had an arm that was stuck because of to many spacers and the car would change 50 grams every time I put it on the scales.
www.hobbyplexraceway.com
Ken's Graf/x | Stickit1
Team Losi Racing | Spektrum | ORCA | Tekin
2011 8-Hour & 2010 2.4-Hour Trans-Am Enduro Champions: Me, Wilcox, Hatcher, Romanik
Andy Crosson is offline   Reply With Quote
Old 01-09-2009, 02:40 PM   #8807
Originally Posted by sportsman4life View Post
do any of you guys think this is a good deal? I am thinking about picking this up. Jrxs on ebay
Yeah you may think that is a good deal, but you want to buy parts as you break them instead of having 150 parts you most likely wont use.
Old 01-09-2009, 04:35 PM   #8808
MikeXray's Avatar
Trader Rating: 73 (100%+)
there are holes in the chassis to do f/r balance on the pins.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-09-2009, 04:38 PM   #8809
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by metalracer2 View Post
cool i will have to pick up some of the pins so i can get the car balanced
hey rusty remember those little pin things i tried using at the Mazda Cup? Most people use those.
Syber Serulean is offline   Reply With Quote
Old 01-09-2009, 05:03 PM   #8810
John Tag's Avatar
Trader Rating: 42 (100%+)
Hey all..
I have had a few request my set up from The Track in Maryland. Indoor Rubber touring Carpet med/high bite. Semi flowing track.
Front:
Black Piston 57
50wt
20lb spring
.060 bar
Spool 41T
Spool High/Med(OD get's spool mid range)
Roll center High
Arms middle
Camber link inside high tower
Tall ball stud outside
steering #1 rack #1 spindle Tall ball stud no spacer
.195 Hex
shocks #2 hole
5mm RH
1MM droop over RH
4* caster blocks
1* Camber
Rack foward
Rear:
Red Pistons #56 stock
40 wt oil
17 Lb springs
.050 bar
#3 outside on tower shocks
Shocks outside on arm
wheel base short
Stock hubs
1* block
diff High
Roll center High
Tall ball stud with .030 washers
Camber 1 1/2 *
4A Camber link
.195 Hex
Lrp TC spec speedo LS car
Rec Transponder RS car
28 grams lead RS
14 front servo
28 grms under top deck
Novak Fan RS Bulkhead above motor
118x46 13.5 DUO
Sorex 28R's Cleaned with WD40-Race Prepped with Jack the Gripper
Ip380035C Lipo
Mazda 6 Body
WT 1510 Grams
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-11-2009, 08:01 PM   #8811
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
if anyone is interested,
the car just won the 13.5 rubber class at the novak race at trackside
it was also 7th in the same class
and 6th in 17.5
i will psot the setup used in the morning
very tired
matt
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 01-11-2009, 08:08 PM   #8812
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i tried out the 41t spool pulley this weekend.
it worked out pretty good it took the push out of the car
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 01-12-2009, 09:12 PM   #8813
anybody run a type R for VTA racing?? if so what would be a good setup for VTA
jon Perkins is offline   Reply With Quote
Old 01-12-2009, 09:35 PM   #8814
Mike Haynes's Avatar
Here ya go
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-13-2009, 10:47 AM   #8815
YmeBP's Avatar
Trader Rating: 32 (100%+)
Can I build a one way for the type-r from the old jrx-s one way? I can't seem to find a3358 in stock anywhere.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 01-13-2009, 11:18 AM   #8816
Administrator
Matt M.'s Avatar
no...the bearings are backwards...my friends and i have been trying to replace them, but cant find the correct bearing....we did it to one but the bearing did not last.....
Old 01-13-2009, 03:10 PM   #8817
squirrel's Avatar
Does anyone know how to properly build the spool for the type r?
squirrel is offline   Reply With Quote
Old 01-13-2009, 05:26 PM   #8818
Administrator
Matt M.'s Avatar
i do
Old 01-13-2009, 05:31 PM   #8819
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
put it together the same as you would a diff but don't use the lube on the diff rings.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 01-13-2009, 05:59 PM   #8820
Jason's Avatar
That won't prevent the diff from rotating. Need to put sandpaper disks between the rings and pulley, then lock it down tight. Leave the balls in the pulley. Shouldn't rotate anymore
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
