Old 01-01-2009, 03:02 PM   #8746
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Ok guys, our local track just got a fresh repave with a totally new type of surface then before and everyone is having to change setups
my setup.
Front
Toe: 1deg out
Ride height: 5mm
Camber: -2
Kick/Anti-dive: 0
Caster: 4deg
Droop: 3mm above RH
Roll center: high
Arm spacing: Middle
Shock position: 2
Steering Rack: 2
Spindle Ackerman: 1
Camber Link: 3
Arms: Long
Front drive: spool
Diff: high
Oil: 35wt
Spring: 17.5
Rear
Toe: 3deg
Ride Height: 5mm
Droop: 3mm above RH
Camber: 2 deg
Anti/Pro squat: 0
Hub: std
Roll center: high
Arm spacing: middle
Shock Position: 2/out
Camber Link: 6b
Diff Height: low
Oil: 35wt
Spring: 12.5
Now what i need is more steering all the way around. running mod the car is just flat out stuck and with a little more steering this thing will be dialed.
Any Ideas as what to try?
what will switching to hole#1 on the steering rack do?
thanks for any help
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-01-2009, 03:58 PM   #8747
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
my setup.
Front
Toe: 1deg out
Ride height: 5mm
Camber: -2
Kick/Anti-dive: 0
Caster: 4deg
Droop: 3mm above RH
Roll center: high
Arm spacing: Middle
Shock position: 2
Steering Rack: 2
Spindle Ackerman: 1
Camber Link: 3
Arms: Long
Front drive: spool
Diff: high
Oil: 35wt
Spring: 17.5
Rear
Toe: 3deg
Ride Height: 5mm
Droop: 3mm above RH
Camber: 2 deg
Anti/Pro squat: 0
Hub: std
Roll center: high
Arm spacing: middle
Camber Link: 6b
Diff Height: low
Oil: 35wt
Spring: 12.5
thanks for any help
Try going to 45 front oil and 40 rear oil with 15 lbs springs in the rear. If it still doesn't turn enough go to hole #1 on the steering rack. If you go to hole #1 you will need to lenghten your steering link. What switching to location #1 on the rack does is increase ackerman.
You also might search this thread for one of Larry's setups and try it just as he has it. If you don't use it just how he has it, it won't work right....
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 01-01-2009, 07:05 PM   #8748
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I had a couple questions in regards to the Type R. I previously used to have a Phi and am looking to possibly get a Type R or the E4. I want a car with the lipo down the middle.
1. On the Phi, a lot of people were switching to the Tamiya Shocks. Is this type of change done for the Type R by any racers?
2. I noticed that the steering has a dual crank system. Anyone tried to modify this into a single crank system?
Any pros/cons compared to the E4 would be very beneficial as well. I am not worried about part availability since the track that I run at doesnt have a hobby shop.
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 01-01-2009, 09:12 PM   #8749
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
venturaDC,
change front shock oil to 40wt
you might want to try a low roll centre at the rear with 17.5lbs springs and use standard camber links upfront with short neck ball stud.
and run stabilizers
|JayFlores|2 is offline   Reply With Quote
Old 01-01-2009, 09:17 PM   #8750
MikeXray's Avatar
Trader Rating: 72 (100%+)
1. They should fit, but no one seems to deem them necessary, the stock shocks are good and don't leak.
2. There is no room, the battery is too close to the servo.
3. Don't know anyone with an E4, can't say
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-01-2009, 09:27 PM   #8751
Thanks for the help Mike!
What is the difference between the RCDs and LVDs? Which ones should you run on the front and rear for carpet rubber?
Chirag
Old 01-01-2009, 09:36 PM   #8752
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
you guys beat me to it.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 01-01-2009, 09:50 PM   #8753
Chirag
difference is LCD's can move freely than the RCD's because there are 2 joints between the driveshaft and the axle plus it eliminates the chatter while the axle and drive shaft is on an angle.
LCDs - front
RCDs - rear
Old 01-02-2009, 12:14 AM   #8754
who or what manufacture makes the Take Offs brand rubber tires??? do they have a web site and where is a good place to buy them??
thanks
Jon
jon Perkins is offline   Reply With Quote
Old 01-02-2009, 05:27 AM   #8755
MikeXray's Avatar
I tried the RCD's up front not too long ago and the car just felt odd, it definitely didn't have the extra steering that it was supposed too, and the car just didn't flow well at all.
Old 01-02-2009, 05:56 AM   #8756
jkirkwood's Avatar
I finally got the time to get the car together. I hope to get some free time to dial it in on the track next week. Sorry blurry iphone image.
jkirkwood is offline   Reply With Quote
Old 01-02-2009, 08:27 AM   #8757
Talking
Without having to go through 280+ pages, can someone tell me the P/N for the optional steel LiPo battery tray?
Bob Oaks
bob o is offline   Reply With Quote
Old 01-02-2009, 08:38 AM   #8758
VenturaDC's Avatar
Then why not look it up on the losi site?
either way
LOSA4312
Old 01-02-2009, 09:06 AM   #8759
VenturaRC
Thanks you for the number. I did try to look it up on their site, but could not find it under the normal option/hop-up parts.
I went back after getting this number and found it using the "LiPo tray" as a wild card search.
Thanks again
Bob Oaks
Old 01-03-2009, 11:37 PM   #8760
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
thanks
Jon
schumacher makes the cs-27 takeoffs, but you can get the premounted jaco rubberz, muchmore sweeps, and rp-30's if i remember correctly.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
