Old 12-18-2008, 07:07 PM   #8671
Company Representative
SweepRacingUSA's Avatar
Originally Posted by a_main_attendee View Post
That's cool, but the added stress on the arm, hinge pin, and hinge pin mounts would seem to cause more trouble (broken arms, tweaked chassis) than some cheap hubs. Very cool nonetheless, where'd you pick them up at? i know dynamite had aluminum hubs for the xxx-s, but that's about it.
those GPM made caster block was garbage aand only in 0' I remember.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 12-18-2008, 07:20 PM   #8672
MikeXray's Avatar
Trader Rating: 72 (100%+)
Also, why do you run a short lcd and a long outdrive?
yet your arms are long?
thats for the one-way, only way you can run it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-18-2008, 07:21 PM   #8673
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Ah, i see.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 12-18-2008, 07:55 PM   #8674
markf3x's Avatar
Originally Posted by RCSteve93 View Post
How much did it cost to get them made, and where did you get them?
The machinist that made these is a real busy guy last time I checked.. I'll ping him again and see if he's interested in making any more of these.
He also made 1 or 2 sets of rear hubs (I know Dumas got a set). I never managed to get these.
Anyhow, I'll let you guys know, but my hunch is he'll tell me "No".
markf3x
markf3x is offline   Reply With Quote
Old 12-18-2008, 08:07 PM   #8675
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Any ideas as to where i can lose some weight on this car? im gonna run open MOD and pro 13.5 this season and i prefer the power of my enerG 4600 nimh over any of the lipo's ive tried, it comes in like a pig at 1586 grams and with the new rules dropping weight to 1500 grams i would like to lose as much as possible.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-18-2008, 08:12 PM   #8676
Lightweight bodies, low profile servo, no servo saver, Jaco wheels...
That's all i can think of, but i've never heard the losi to be a heavy car either.
In open mod you can run a 3.5 or a 2.5 with a five cell.
Without going Lipo though, i dunno what else you can do.
Old 12-18-2008, 08:15 PM   #8677
Also, shorter ESC wires, and novak's are also damn bulky as well, connectors add up, as well as the removal of unnecesary fans.
Old 12-18-2008, 08:27 PM   #8678
mojoman's Avatar
Aluminum rear hubs Link
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 12-18-2008, 08:30 PM   #8679
Hum, i don't remember the last time i broke a rear hub.
Old 12-18-2008, 08:32 PM   #8680
Depends on how drastic you want to go to lose the weight. Short case servo, no servo saver, trim the inside open on the c hubs a bit trim some of the material on the rear bulkheads. All these were mentioned combine a light body with minimal paint. Shorten your wires to all your electronics...tons of things to do depends on how desperate you are. Soft foam bumper versus the harder one...I could go all night. Clean all the grease out of your bearings and use a light oil. All of this ads up I have 2 R's I have been toying with. The foam car weights in at 1402 race ready with a Checkpoint 5400 lipo n steel tray and the rubber car weights in at 1453 race ready. Electronics are Futaba 9550 servos LRP TC esc with fan and heatsink removed, PT under front diff, Spectrum mini receiver and all wires shortened to barely reach where they need to go.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 12-18-2008, 08:56 PM   #8681
VenturaDC's Avatar
Thanks for all the ideas guys...never really noticed how much extra wire i had on this thing. im sure taking in the wires along with cutting down the post that the battery tray screws to will be a good little chunk of that 80 extra grams
Old 12-18-2008, 09:04 PM   #8682
I wouldnt cut on those posts too much if at all if you are planning to run open mod. Being a major support for the car you may end up with a tweak you cant fix if you hit too hard. I tend to run my mod cars at full weight because when you hit you tend to hit hard...lol! Now for stock or any other class I'll shave as much as possible without weakening the car. Enjoy!!!
www.OHRCR.com
Old 12-18-2008, 09:16 PM   #8683
VenturaDC's Avatar
Im running asphalt so i dont have them connected. i was gonna chop them all the way down...
Old 12-19-2008, 05:22 AM   #8684
torinogt1971's Avatar
Default Speed control placement......
I am changing from a brushed motor/speedo set-up in favor of a Losi brushless system. Which side should I install the speedo, left or right? I have seen both.
Thanks, Ben
torinogt1971 is offline   Reply With Quote
Old 12-19-2008, 05:36 AM   #8685
Default Setup?
Hi all,
I've just got hold of a 2nd hand Type R (needs an overhaul though, where's Foose!?). I am going to strip the whole thing down and rebuild it, but I was wondering how good the suggested kit setup for tarmac is? Are there any changes/improvements that I need to make before I hit the track.
I will be running on a tight, med bite tarmac track so any advice would be appreciated.
I used to run a JRXS a few years back, loved that car once I got the setup nailed!
Cheers in advance.
J A M I N is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
