Old 12-15-2008, 11:00 AM   #8626
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
How often are you guys replacing the out drives on the type r?
mine seem to have a lot of slop.
Is there a fix so they don’t wear out so fast or do I have to just replace then every now and then?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 12-15-2008, 11:36 AM   #8627
markf3x's Avatar
Originally Posted by schreff View Post
Mark, I think I can help Mike with this one.
I know Mike was running the "older red case" SMC 5000 with the wires coming out the right side. I've run them as well. I also tried fitting the newer case and while it is a tight fit, you can get it to work without modifying the top deck. It's just an odd/tight fit.
I don't worry about that anymore though as I'm running the TP5000 40C.
Thanks.. I very carefully peeled the top of the case upward a few mm's and then routed a hole so I can rotate the power leads so that they are aligned vertically, instead of horizontally. I used extreme caution when I did cutting real close to a cell.. I was outdoors and prepared to through it like a grenade
I'll have to check out the TP5000.
markf3x is offline   Reply With Quote
Old 12-15-2008, 11:37 AM   #8628
MikeXray's Avatar
Trader Rating: 73 (100%+)
Is there a fix so they donít wear out so fast or do I have to just replace then every now and then?
Are you running a spool? if not, mine don't wear out that fast, I find the front axle will get play before the outdrive.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-15-2008, 11:45 AM   #8629
jkirkwood's Avatar
How often are you guys rebuilding the LCDs and RCDs?
jkirkwood is offline   Reply With Quote
Old 12-15-2008, 12:16 PM   #8630
yeah i'm running a spool.
all 4 wheels have about 1/4" play. i looked the axles and they don't look worn.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 12-15-2008, 12:23 PM   #8631
RedRocketRacing's Avatar
time to rebuild. i found that the cylinders in the axle joints get sloppy. They will also make the pins tight and not allow the LVD to work properly. Make sure eveythink moves smoothly when you rebuild.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 12-15-2008, 04:15 PM   #8632
TJames987's Avatar
Trader Rating: 10 (92%+)
Im looking for a front oneway kit for the JRXS type R everywhere in the world is apparently sold out.
I would be willing to pay 45$ shipped via PayPal just for the oneway. Please let me know; its ruining my race season not having it
TJames987 is offline   Reply With Quote
Old 12-15-2008, 04:34 PM   #8633
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
will this work
http://www.amazon.com/dp/B000BP2C0U?...0&linkCode=asn
ALBERTO is offline   Reply With Quote
Old 12-15-2008, 05:05 PM   #8634
I have a complete one way assembly $40 shipped if interested, i don't use it, i use standard diffs as it came with the car when i bought it. its for the jrxs not the type R, but they both look the same to me
Jon
jon Perkins is offline   Reply With Quote
Old 12-15-2008, 06:30 PM   #8635
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
They are not the same, the Jrxs oneway bearing is backwards for use in the type r. It will not work.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-15-2008, 06:33 PM   #8636
TJames987's Avatar
thanks for the offer but unfortunatley the ones for the jrxs do not work on the type R
Old 12-15-2008, 06:42 PM   #8637
thanks for clarifying!!! did not want to sell it to someone when it would not work with there car
Old 12-15-2008, 08:05 PM   #8638
mojoman's Avatar
Tom contact TAJoe5 I know he has one we might be able to lend you for the winter? I have his telephone # I will send it to Brian when I send the setup he wants.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 12-16-2008, 03:48 AM   #8639
jrxs-r's Avatar
I do mine on my stock R about once a season, and the ones on the 10.5 about every 6-8 months. It depends a lot of the power and the driving habits too. I run on carpet, so its pretty clean. On tarmac I'd be more inclined to do them every month or so to clean out te dirt.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 12-16-2008, 04:53 AM   #8640
Send a message via MSN to Adim_X
What is an easy way to set the camber on the front of this car with the JR Link? Maybe I am missing something
Adim_X is online now   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
