Old 12-12-2008, 11:00 AM   #8611
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
what fans are you guys using?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 12-13-2008, 12:40 PM   #8612
Trader Rating: 17 (100%+)
Mike Haynes, I heard you ran the new Thunderpower 5000 Lipo. How did you get it to fit?
seabass2500 is offline   Reply With Quote
Old 12-13-2008, 12:57 PM   #8613
RCSteve93's Avatar
I am using the speed passion ones.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 12-13-2008, 01:51 PM   #8614
schreff's Avatar
Send a message via AIM to schreff
Seabass... the TP5000 40C is pretty darn close to a direct fit in a Type R.
The pack will fit the car just fine with the plastic tray. If you want to use the Steel tray, you'll have to do 2 things...
#1. Grind a little out of the tray itself (widen the pocket) by grinding the inside edges of the tray. Newer generation trays being shipped by Losi may not need this.
#2. Grind a little of the rear bulkheads underneath the layshaft. You probably only need to grind .5mm or so just to get the pack to sit up into the car better.
Other than that, you should be fine.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-13-2008, 02:58 PM   #8615
Thanks Schreff. I just tried to fit a friends in and it seemed the main issue was the pulleys. When I slide it in, it wedges between them so they don't spin. I don't know of any mods for the pulley but I would prefer not to cut on my Lipo ( like I have before ).
Old 12-13-2008, 03:11 PM   #8616
MikeXray's Avatar
Trader Rating: 72 (100%+)
Team Losi JRXS Type-R here is an explination of how to get some clearance on the pulleys.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-13-2008, 03:22 PM   #8617
markf3x's Avatar
Default LiPO fitting question
OK,
I bought a couple of SMC 5000's and I'm grinding away on:
1. LiPO tray.
2. After LiPO tray I'll see how much I need to remove from Bulkhead under layshaft, and remove it.
3. Remove a little less than 1mm from belt pulley on Spur gear side.
Question.... As I test fit the battery, I notice the power leads hit the top deck and won't work as shipped..
I either need to grind on the top deck or open up each battery and try to relocate the leads in the battery.. The lead that is in the corner should be fine, but there is one to the inside of it that maybe I can relocate just behind the other???? Or maybe in the other corner (like on Orion)???
What did you guys do with the power leads?
markf3x is offline   Reply With Quote
Old 12-14-2008, 09:01 AM   #8618
MechMan25's Avatar
For the guys running the Orion 5000
1 Does this battery fit into the steel battery tray without mods.
2 I am looking for a battery that can make a 10 min main with a 4.5 or 5.5 BL motor and stay within the 80% rule for LiPo. Can the 5000 do this.
Thanks in advance
MechMan25 is offline   Reply With Quote
Old 12-14-2008, 11:15 AM   #8619
bighurt98's Avatar
Default Questions about this being the newest Kit?
I have read on the Losi site that this chassis has been around since 2006. My questions are:
1. When was the Type R released? Was the original car released in 2006?
2. Are they looking to put out new chassis in 2009? I have seen prices reduced as if a new chassis might be coming.
3. What is the best place for getting parts?
Serpent 748/Matrix Tires/Novarossi
Serpent America/Desoto Racing
Murnan Modified Motors
Team Gravity
bighurt98 is offline   Reply With Quote
Old 12-14-2008, 01:19 PM   #8620
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
I got mine march of '07, part of the first batch that came to colorado.
You can get parts from horizon directly, losipartshouse, or from your LHS.
I will crap bricks if losi releases another TC, so i doubt it, you never know though.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 12-14-2008, 11:21 PM   #8621
guys that are running rubbertire's on carpet... Are you running the roll center low or high??? from what i have been reading, running high helps put more of the traction on the tires.. but not sure.. what im looking for is an around average what most racers run at there local tracks and why???
thanks
jon
jon Perkins is offline   Reply With Quote
Old 12-15-2008, 06:22 AM   #8622
MikeXray's Avatar
thanks
jon
Front high, rear low, and depending on how the car is handling, we will add .030" shims under the rear to raise it a little bit.
Old 12-15-2008, 07:22 AM   #8623
nitrobeast's Avatar
Trader Rating: 40 (100%+)
me too
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 12-15-2008, 10:25 AM   #8624
markf3x's Avatar
Originally Posted by rcracingkid View Post
I usually use the smc 5000 28c packs, as they seem to work very well. I use the metal tray in my rubber car, and the stock plastic lipo tray in my foam car. It is a very tight fit and needs some dremel work,
Mike, How are you running the power leads on the SMC5000 28c?.. They come up in the front left and are obstructed by the top deck. How are you running these? Opening up LiPO case (not easy) and moving the wires?, grinding on top deck? Not sure what you did....
Please let me know.
MarkF3X
Old 12-15-2008, 10:54 AM   #8625
schreff's Avatar
Please let me know.
MarkF3X
Mark, I think I can help Mike with this one.
I know Mike was running the "older red case" SMC 5000 with the wires coming out the right side. I've run them as well. I also tried fitting the newer case and while it is a tight fit, you can get it to work without modifying the top deck. It's just an odd/tight fit.
I don't worry about that anymore though as I'm running the TP5000 40C.
-Jason Schreffler-
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
