Old 12-11-2008, 05:45 PM   #8596
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by nitrobeast View Post
You and Jason sure do know how to keep the excitement going...WOW
Yeah they do. Hats off to Jason fro not just punting Haynes.
+ YouTube Video
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-11-2008, 07:43 PM   #8597
adamge's Avatar
Wow... to have a track so big that the designers only see a need to use 80% of it.
<--- jealous
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-11-2008, 08:27 PM   #8598
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Uncle Cliffy View Post
I just got a spool pulley couple weeks ago and there wasn't anything but the pulley in the bag...
Just curious here... when you got that spool pulley, could you see the holes for the diff balls in it? If you could, the pads were missing. If you couldn't it's because the pads were snapped into the holes. It's easy to think it's all just one piece of plastic with the pads in place... it fooled me when I got my first one.
By the way, if you try to take the pads out, they're likely to break... they're very brittle. Ask me how I found out...
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-11-2008, 08:30 PM   #8599
Dave G's Avatar
+ YouTube Video
Top 3 cars at the Region 1 regionals were all JRXS Type R's. 1st Haynes, 2nd Schreff and Myself in 3rd. All 3 cars were setup quite different as well.
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline   Reply With Quote
Old 12-11-2008, 09:14 PM   #8600
Company Representative
SweepRacingUSA's Avatar
Originally Posted by jkirkwood View Post
Is it better to run a couple of fans on the motor in the stock locations or get a heatsink that has a fan mounted on it like 3racing's fan/heatsink combo? Any opinions?
just run 2 fans on stock holes of rr bulkheads, no need to run extra heatsink, actually I am going to try just 1 fan on right side bulkhead next time i m at 360 and measure diffrence if any
SweepRacingUSA is offline   Reply With Quote
Old 12-11-2008, 09:35 PM   #8601
Trader Rating: 21 (100%+)
Default Fans
John that's all that I run and not unless mike has changes that's all he runs too.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 12-12-2008, 04:29 AM   #8602
jkirkwood's Avatar
Thanks for the feedback!
jkirkwood is offline   Reply With Quote
Old 12-12-2008, 05:28 AM   #8603
MikeXray's Avatar
Trader Rating: 73 (100%+)
<--- jealous
It's more a function of the driver stand, if you bring the cars too close to it, there are blind spots depending on where you stand.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-12-2008, 06:52 AM   #8604
Send a message via MSN to Adim_X
Does anyone have a good 13.5 Rubber tire setup? Also what is the general consensus on electronics location? I have my ESC on the right side, and my rec and motor on left side. Is that ok?
Adim_X is offline   Reply With Quote
Old 12-12-2008, 06:57 AM   #8605
RCGaryK's Avatar
Here's Matt Howard's setup from the Nats this past year where he finished top 5 in 13.5 rubber:
front
20lb spring, 57 pistons, 45 wt oil, middle hole on tower
.05 sway bar
high roll center blocks
regular castor link, used inside upper hole on shock tower and short ballend on castor block
arms spaced in the middle
4 deg castor
inside hole used on the steering link (makes the steering turnbuckles longer)
5 1/2 mm ride height, 1.5mm droop
diff high in front and back
regular link in front, AKA not the JR link
nothing above the shock bladders
rear
12.5lb spring, 55 piston, 35 wt oil, middle hole on tower
arms spaced to the rear
3 deg toe in
low roll center blocks
inside hole on hub for camber link, inside middle on tower
5 1/2mm ride height, 2mm droop
PF Mazda 6 used
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-12-2008, 07:16 AM   #8606
baf1's Avatar
Default carpet.
what carpet...
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 12-12-2008, 07:23 AM   #8607
RCGaryK's Avatar
That was at the HobbyPlex back in March, so I don't think it was the latest generation CRC carpet but maybe Matt or Alex can post something to confirm?
HorizonHobby.Com
Old 12-12-2008, 07:28 AM   #8608
John Tag's Avatar
Trader Rating: 42 (100%+)
Mine is close, with the following changes:
Spool front
40 rear oil
17 rear springs
.50 rear bar
Jaco Blues
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 12-12-2008, 08:39 AM   #8609
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
front
.05 sway bar
4 deg castor
rear
3 deg toe in
PF Mazda 6 used
That setup would push off the track for me and also probably be loose coming out of the corner. Here are changes I would make to what is above.
50 wt 56 pistons front shocks
17.5 rear spring, 56 piston 40 wt. Half rebound
Rear camber link outside hole on hub inside middle on shocktower. With 2.5mm spacer under ballstud on hub. Low rear diff.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-12-2008, 09:39 AM   #8610
ya I thoought fan on left not doing much, also it makes harder to solder wires on the motor. TY
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
