Old 11-16-2008, 05:36 PM   #8446
Mike Haynes's Avatar
Originally Posted by markf3x View Post
This is great to hear..
I've been going back through many, many pages through this thread to find out what LiPO's to buy that have great punch and will fit. What LiPO's is Mike running?? I'm still running Orion 4800 20c, but would like to try some 30 or 35C batteries.
I usually use the smc 5000 28c packs, as they seem to work very well. I use the metal tray in my rubber car, and the stock plastic lipo tray in my foam car. It is a very tight fit and needs some dremel work, i recommend the smc 4000 as a very close 2nd, and it fits in without cutting the bulkheads or pulley. The orion 5000 is a decent pack, but i think the gold trackpower is probably the best bet for straight drop in ease.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-16-2008, 06:24 PM   #8447
Originally Posted by Adim_X View Post
Well I raced my JrxsR today for the first time today. I realized pretty quickly that the throttle profile on GTB was the least of my worries. I managed to rip both front A-arms off the car and chew up 2 spurs while practicing and in my quals. However I did have fun. Sedan racing requires a whole lot more concentration when we are turning 8-9 second lap times (small track). Overall my car felt really good when i got into a brief groove, I just could not keep it off the walls. I need some more practice.
One thing that helps alot is to make sure the axle dosn't stick out past the wheel nut, if it does cut them down and you will have less breakage.
Old 11-16-2008, 08:38 PM   #8448
Originally Posted by rcracingkid View Post
I have had the same 118 on my car for a long time, just need the 108 for the 17.5's
duckman996 is offline   Reply With Quote
Old 11-17-2008, 11:27 AM   #8449
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Need some help on this guys:
when setting my rear ride height, I've noticed this on all my Type R cars:
The rear left corner is always about 1mm lower than the right rear!!
I'm running a novak 10.5 SS PRO on it, and have the speedo on the right side of chassis, and receiver on the left. It's balanced out perfect side to side and fore and aft, but the car seems to always be a bit more "dipped" on the left rear side and than the right rear side, and its anoying to set ride height with this little "bias"...droop is also affected by this of course...so it's something I need to figure out...what is causing this? Anyone notice the same pblm?
Could it be the weight of the BL motor...the motor is not exactly on center of the chassis, and its offset a bit more to the rear left side, which could cause it to dip more on that side? Any things to look for or tips would be helpful
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-17-2008, 11:54 AM   #8450
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
I bought a new brushless system for my type r and i wanted to know where the best place is to mount the seed control?
Iím sure this has been discussed before but i just can't find it
I will be using the losi brushless system
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 11-17-2008, 12:03 PM   #8451
RedRocketRacing's Avatar
Left side of the car. Speedo on its side, with the motor and battery wires faces towards the back. The speedo will sit against the topplate standoff. Doubleback tape the speedo to the standoff and the chassis. I can take of pict of my car if you would like. I had a LRP sitting flat on the chassis, so that it hung off the side, I got T Boned and had it blow up. I think this way is better as less of the speedo is off the car. Only the fan I think.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 11-17-2008, 12:24 PM   #8452
yeah please post or send pic
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 11-17-2008, 02:29 PM   #8453
tim fry's Avatar
I found this too till I started to set the ride height on the outer edges of the chassis rather than just at the rear. What I found was that the rear corners of the chassis wear and so give incorrect readings.
Are you using the metal lipo tray as its best to set the car up with this left a little loose.
tim fry is offline   Reply With Quote
Old 11-17-2008, 03:07 PM   #8454
yyhayyim's Avatar
THanks Ken...Well, the pblm seems to be when setting ride height under the rear arms...the the rear left part of chassis, either under the arm, or the extreme rear left corner of chassis, is 1mm lower each time than the rear right side. no matter what, chassis is just lower on the rear left side than the rear right side. Even when the car is perfectly balanced F/R and L/R.
I'm not using the steel lipo tray...and it could just be that since the BL motors are almost 40g heavier than brushed motors, and motors are offset to the rear left, so more weight is on the left rear side, and that could cause the rear left dip...maybe the Lipo tray would help in this regard in counter balancing the heavier 190g Novak motor, since it would a little more weight across the right front quadrant of the chassis?!?...
So to measure droop, ride height, etc, this could throw things off and cause subtle handling pblms
Old 11-17-2008, 06:26 PM   #8455
Yeti35's Avatar
Are you sure you don't have some sort of tweak in the chassis? how does it sit on a setup board when you have the wheels off of it? I personally have not noticed this on any of my cars.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 11-17-2008, 06:55 PM   #8456
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
+1
The only time i have had something simular to this is when one or more of the standoffs are bent, which happens more often then you would think (for me, anyways)
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 11-17-2008, 07:25 PM   #8457
markf3x's Avatar
Unfortunately the list of things that can cause this is VERY long and the best method would probably be to hand someone else your car to double check all the stupid stuff we all do once in a while:
* Things like shimming roll center on one side but not the other (have done it).
* Having droop screws bottomed out on chassis, often times after changing roll center (we've probably all done this, but did you catch it within the first minute or two?).
* Unequal camber (like when you whack a board, can't figure out why ride height is uneaqual, then realize your crash messed up camber on one wheel (done this one also)..
Some of the lesser stupid things:
bent A-arm pin
Crushed (uneven) spring
the list goes on.... (this could be more fun than the "Uses for Paragon" thread.)
markf3x is offline   Reply With Quote
Old 11-17-2008, 07:29 PM   #8458
yyhayyim's Avatar
wheels off on flat board and chassis is flat I'll check the posts and see if any is bent...
Old 11-17-2008, 07:35 PM   #8459
yyhayyim's Avatar
Any one try the shorter front arms on med-high rubber tires outdoors? Supposedly you get more agressive/reactive steering with the short arms and wonder if anyone runs them and if indeed they've noticed a difference in car's front end steering/responsiveness?
Will running the front diff in the low position generate more front end steering/responsiveness?
Old 11-17-2008, 07:37 PM   #8460
markf3x's Avatar
Check the inside a-arm pins while your at it. They can bend.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
