Old 11-15-2008, 02:05 PM   #8431
Trader Rating: 14 (100%+)
Originally Posted by JoelV View Post
Alright, so building my second jrxs-r. First one I bought used.
Building the diffs, it seems the diff spring is too long. I noticed that it didn't seem right for the thrust bearing to be exposed, tightening one for a while figuring it would collapse the spring, but eventually I heard a loud crack and it didn't compress the spring at all.
Finally took apart a diff from the first car. Comparing the diff springs, the correct one is silver in color, 3 turns in the spring and .267in. The ones I got in this kit are black in color, 4 turns in the spring and .429 in.
Suggestions?
JoelV Please respond to your Emails and PM about the RDX Phi I have sent payment for. Thanks, Steve
sfkilo is offline   Reply With Quote
Old 11-15-2008, 02:08 PM   #8432
hanulec's Avatar
Trader Rating: 25 (100%+)
Sfkilo - I don't think JoelV is riding dirty with your newly purchased car. He is a good guy but has the unfortunately tendency to hang out w/ eskimos.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-15-2008, 06:10 PM   #8433
That is a relief as I had a major issue with a hobbytalk user $600 worth of cars & parts decided to not show up and now I get really concerned with non response after payment is sent. I appreciate your vote of confidence it makes me feel allot better, Steve
Old 11-15-2008, 07:32 PM   #8434
Default diff kit
Originally Posted by dgullickson View Post
We now have the solid caged with ceramic balls pressed in for an even smoother diff and the solid brass piece is a little thicker now to hold up even longer.
Ok quick ? which diff kit is best the one for $18.95 or $24.95 I saw on the axiom web site they both have the same parts in the kits. Please help, Need to rebuild my diffs. Thanks for the help.
Detroitlion is offline   Reply With Quote
Old 11-15-2008, 09:27 PM   #8435
hanulec's Avatar
i think you should be sorted out by now Steve. are you cool??
Old 11-16-2008, 06:56 AM   #8436
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Adim_X View Post
I got my Type R all put together. Tomorrow will be the first race. I am a rookie to electric onroad, but am very experienced in 1/8th buggy. I have a question. I am using a novak gtb with 10.5 motor and foam tires. What throttle profile on the speed control should I use? The track is a tight small course with lots of low speed turns.
your best bet is to start with factory settings.then play with the settings to get the feel that you want.tc on foam tire is going to have way more acceleration than the 1/8 scale racing that your used to.so driving a tc will be a little different for ya.as for throttle profile...just play with it a little.try a notch higher then so forth to get the feeling you like the most.i use an lrp sphere tc.i have mine set about 4 i think.i dont know the differences from the esc though.
hope this helps.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 11-16-2008, 08:12 AM   #8437
MikeXray's Avatar
Trader Rating: 73 (100%+)
Gettting gearing right for the track will make a much bigger impact than the throttle profile. I would leave it on the default one for now and turn up the drag brake setting, this will help the car through the tighter sections.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-16-2008, 09:29 AM   #8438
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
The one for 24.95 comes with ceramic balls for the diff and ceramic balls for the thrust
The one for 18.95 comes with ceramic balls for the diff and carbide balls for the thrust.
The 24.95 one is by far smoother
dgullickson is offline   Reply With Quote
Old 11-16-2008, 01:06 PM   #8439
markf3x's Avatar
Default LOSI RACER COMING OUT OF RETIREMENT
OK, I've been on "RC Racing Leave" for about a year. Now the baby is a year old and dad wants to start racing again...
As I last called it quits for a while I was running all Ni-MH, not 'cus I like them, but because my 2 JRXS-R (one carpet foam, one carpet rubber) just ran better. They had a little more punch and the setups that we were running were really based on the higher CG of a 6 cell pack. When I'd put in a Li-PO the car didn't have the roll/bite (especially rubber tire on med bite carpet). So, although I was running a steel plate battery tray, I was putting some lead way up high to try to get the same feel..
Anyhow, I've pulled down Mike Haynes recent setups (as well as others), but any comments on running these on LiPO? Change roll center? or just tinker with lead way up high like I used to to get CG in same location as Ni-MH pack??
Cheers,
Mark Taylor
markf3x is offline   Reply With Quote
Old 11-16-2008, 01:09 PM   #8440
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default motor fans
I was reading the thread and saw guys saying the 25mm motor fans work. I dont see how that can be because the spacing where you mount them is 20mm?
How are you guys doing this?
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 11-16-2008, 01:18 PM   #8441
Trips's Avatar
Trader Rating: 16 (100%+)
Cheers,
Mark Taylor
Mark, I'm fortunate enough to see Mike almost every weekend at 360 R/C Speedway In NY and he runs LiPo in his TypeR's, so any recent setups you see from him will already be based on the low CG of a LiPo and I wouldn't worry about putting any weight up high to simulate a NIMH pack...
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-16-2008, 01:38 PM   #8442
Trader Rating: 66 (100%+)
Send a message via AIM to joey
most people are just using one screw to hold the fan onto the bulkhead when using the 25mm fan... but i never had a problem with the 20mm novak fans.
=Joe Wright=
joey is offline   Reply With Quote
Old 11-16-2008, 01:55 PM   #8443
markf3x's Avatar
This is great to hear..
I've been going back through many, many pages through this thread to find out what LiPO's to buy that have great punch and will fit. What LiPO's is Mike running?? I'm still running Orion 4800 20c, but would like to try some 30 or 35C batteries.
Old 11-16-2008, 02:15 PM   #8444
Trips's Avatar
Mark,
Mike is running the SMC 5300's, they take some grinding on the pulleys to fit in the car from what I understand, also some grinding on the steel LiPO plate if you[re gonna use that.
I'm running the Orion 5000 Platinum II which fits right in with no need for any extra work. I can't say it's the equal of the SMC, but I can't say it isn't either. I'm not feeling any lack of power in any way. I don't know the C rating of the PlatinumII, but make no mistake, internal resistance and average voltage over the duration of the race would be FAR more important in determining the performance of a pack. That being said, the higher C rated packs should tend to have lower internal resistance, but it's not always a certainty. In any event, the SMC packs are great packs if you don't mind the minor work to get the chassis to accept them. If you'd rather go for a direct fit, I don't think the Platinum II will disappoint you.
Losi have some 4400's that drop right in, I think Larry Fairtrace and Jason Schreffler were running them last time they were at 360 and they were blazing quick, so there's another option to consider.
MARSHAL!!
Old 11-16-2008, 04:32 PM   #8445
Send a message via MSN to Adim_X
Well I raced my JrxsR today for the first time today. I realized pretty quickly that the throttle profile on GTB was the least of my worries. I managed to rip both front A-arms off the car and chew up 2 spurs while practicing and in my quals. However I did have fun. Sedan racing requires a whole lot more concentration when we are turning 8-9 second lap times (small track). Overall my car felt really good when i got into a brief groove, I just could not keep it off the walls. I need some more practice.
Adim_X is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
