Old 10-24-2008, 10:19 AM   #8311
RaceAce701's Avatar
Trader Rating: 83 (99%+)
fast cat u runnin at altoon this sat
if so see me
i have the blu and green r9r
i running a modded version of hayne's from vagas
15 and 45 wt in front
12 and 4o wt in back
front arms middle
rear arms forward
hight front blocks
low rear blocks + .30
high diffs front and back
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-24-2008, 11:11 AM   #8312
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by jrxs-r View Post
just curious to know what you guys run as a front to rear weight bias?
Generally I run a 50/50 bias with the car set to balance on pins both left to right and front to rear. From there on a few occasions I have added a 5g weight to either end of the car just past the diff to adjust balance. I am not sure exactly what percentage balance that yields but I would guess its give me no more than a 5% difference between ends. I have tried 10g blocks in place of the 5g I use but when doing so the car seemed to want to swap ends and/or felt like the off-power steering was delayed.
In my experience I would say the Losi is more sensitive to weight distribution than most cars making it an easy & effective tuning option.
If you like I can post some photos of how I balanced my chassis along with the weights I use to shift that balance.
Mark
mtveten is offline   Reply With Quote
Old 10-24-2008, 11:14 AM   #8313
Xpress's Avatar
Mark
Post away...
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 10-24-2008, 11:16 AM   #8314
Xpress's Avatar
Has anybody compared the new Jaco's (green and blue) to Sorex 28's in back to back runs (carpet)? My car is pretty decent on the Sorex tires, but looks like a drifter on the Jaco's.
-Espo
Old 10-24-2008, 12:29 PM   #8315
fastestcat's Avatar
if so see me
front arms middle
rear arms forward
hight front blocks
yeah ill be there sat... my car is pretty good except for the circle at the end of the sweeper... its fast enough to race but looking for alil more..
fastestcat is offline   Reply With Quote
Old 10-24-2008, 12:53 PM   #8316
MikeXray's Avatar
Trader Rating: 72 (100%+)
Did you add extra camber with the Jacos?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-24-2008, 12:56 PM   #8317
Xpress's Avatar
Just under 2 in the back and about 1.25 in the front. Does it seem to be normal to only wear the inside of the f tires? After 5 or 6 runs the outside of the fronts are still glossy. Maybe the Jaco's get better after a bunch of runs and the Paragon starts to soften them up and eat at the insert. I did notice they have much less air gap than what I am used to.
-Espo
Old 10-24-2008, 01:05 PM   #8318
fastestcat's Avatar
the more runs i get on my car the worse it gets... im gonna get with alex on sat and see what happens... thanks for info.. i may even throw on a new set of shoes to see..
Old 10-24-2008, 01:28 PM   #8319
J@UNE's Avatar
I saw that too, my car in undriveable compare to Sorex28. I tryed some old Greens (from last year) and the car wasn't that bad. I'll try with softer spring tomorrow, Im now 17.5f 15r
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 10-24-2008, 01:34 PM   #8320
Xpress's Avatar
The only reason I am contemplating trying to make them work for me is I just have a hunch they will be the handout at the Snowbirds. Otherwise I would just stick with Sorex.
-Espo
Old 10-24-2008, 02:05 PM   #8321
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Last weekend i bolted up some blues (used, mind you...) that where left over from the asphalt season and headed indoors for some 10.5 rubber. All i did was clean the crap outta them (scrubed them down with motor spray) and added jack the gripper.
The tires look new after every run (no buildup) and i had way more traction than i expected all day. Dunno about the 28's though.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 10-25-2008, 12:05 AM   #8322
RedRocketRacing's Avatar
So, does anybody have a rubber tire carpet with a spool, with a13.5 or faster motor, setup that they want to share? I am going to make a 2 hour drive on the 1st and would like a setup to work on. Thanks
Tires that you run don't matter to me. But I have to run the Speedmind 28, they are a Spec tire for out series.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 10-27-2008, 01:01 PM   #8323
Default Spool assembly - ESC placement
I've recently built a new Type-R, and am going to be racing Jaco Blue rubber tires on carpet (local events only). I wanted to try the spool instead of the diff, so I purchased a spool pulley with the plastic plates. I was wondering about the best way to assemble the spool. Do you leave the copper washer in place? Also, does anyone use grease behind the copper washer or on the spool plates? Any other building tips?
Additionally, I wanted to place the receiver and the Brushless ESC (LRP Sphere) on top of the battery plate to keep all the weight centered. Does anyone have positive experiences or issues with placing this weight up high, even though it's centered?
Thanks for the thoughts.
rcoldman is offline   Reply With Quote
Old 10-27-2008, 01:35 PM   #8324
MikeXray's Avatar
I mounted the ESC up there once and it felt weird, this car rolls alot to begin with, your better suited keeping the weight low. If you are running lipo you will need to add weight anyway, so you can put a good amount on the opposite side of the chassis to keep the L/R balance.
Old 10-27-2008, 04:02 PM   #8325
Mike Haynes's Avatar
When you build up a spool keep the rings dry and clean, just use some motor spray and then your set.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
