Old 10-23-2008, 09:29 AM   #8296
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
quick question-
i keep eiter loosing or snapping the pins in the front axles. is there any better way to fix this or just keep rebuilding them and covering them with heat shrink? ive snapped 2 and lost one this week alone and its getting to be a pain in the butt to have to keep rebuilding them.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 10-23-2008, 09:31 AM   #8297
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by jrr102486 View Post
quick question-
Are you shaving the c hub where the axle passes?
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 10-23-2008, 09:33 AM   #8298
jrr102486's Avatar
na im shavin off on the steering nuckle the c hubs are fine and clear everything.
Old 10-23-2008, 09:35 AM   #8299
racingboy14's Avatar
Trader Rating: 25 (96%+)
do you have to shave off very much? I am installing a set set and I havent looked yet for clearence issues.
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 10-23-2008, 10:44 AM   #8300
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
you have to shave the c-hub a little to make room for the lcd coupler
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-23-2008, 11:00 AM   #8301
jrxs-r's Avatar
Originally Posted by RedRocketRacing View Post
I ran my car with the plastic tray and by the time I placed the lead on the opposite side of the ESC to ballance the car I was about 6 grams over weight. With the tray, I was almost 90g over. This was on foam tires with a trakpower 4900 lipo, and the Losi esc.
Weight it all out and get in balanced and than see if you really need it.
RedRocket
Managed to get my hands on a set of scales and balancing pins.... You're right... by the time its properly balanced side-side and front-rear, i'm only 5g over... with rubber tyres and IP3800 LiPo, Losi ESC...
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-23-2008, 11:30 AM   #8302
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
where did you pick the scales up from
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 10-23-2008, 11:38 AM   #8303
jrr102486's Avatar
hmm thats weird. ive run it this way for almost a year now and just within the last few weeks ive had this problem and i rebiuld them all the same. well ill give it a try. thanx
Old 10-23-2008, 01:12 PM   #8304
RedRocketRacing's Avatar
My foam car is the same way, with KO reciever, and the Losi speedo, I have 42g on the reciever side and the car is pretty balenced side to side and is only about 4g over with the plastic tray.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 10-24-2008, 12:43 AM   #8305
Lapcounter's Avatar
Originally Posted by L.Fairtrace View Post
I have been running that battery for a month with no problems.
So, does it fit in the Type-R with no modifications to the car?
Lapcounter is offline   Reply With Quote
Old 10-24-2008, 05:42 AM   #8306
Yes it fits in the car with absolutely no modding of the car........
Old 10-24-2008, 08:18 AM   #8307
jrxs-r's Avatar
metalracer2--> Its just a pair of scales borrowed from a friend that is in the industry. They make precision weighing scales with adjustable heights. Nice to use, but really expensive. I just tried it again tonight with the normal 2kg digital scales and balancing pins, and it works just as well!
Cheers,
Zack
Serpent S411
Old 10-24-2008, 08:49 AM   #8308
jrxs-r's Avatar
just curious to know what you guys run as a front to rear weight bias?
Cheers,
Zack
Serpent S411
Old 10-24-2008, 08:53 AM   #8309
MikeXray's Avatar
Trader Rating: 72 (100%+)
I just realized there were holes for that last week, I checked both my cars, the foam one was forward biased, and the rubber tire was rear biased because I have the sphere mounted mid car, not up front like the LPF. I am curious to see how much weight it takes to affect the car front to back.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-24-2008, 09:40 AM   #8310
fastestcat's Avatar
problem with car breaking the rear loose mid corner... running on loop carpet with jaco green... have taken all the steering i can out of servo... think stiffening up front springs or oil... any thoughts?
fastestcat is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
