Old 10-14-2008, 09:22 PM   #8281
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by yyhayyim View Post
Losi '009 Type R? Are you being sarcastic or there is something in the works?
Sarcasm at it's finest
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-15-2008, 07:32 AM   #8282
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Uncle Cliffy View Post
Hey guys, I just got my Type R together. I was going to sell it after I bought it since the local indoor track was going to go dirt. Well, that fell through because of cost so it's staying carpet! The car rips! Couldn't be happier.
Anyway, I combed this thread a while ago and remember seeing some of the similaritys between the Type R and the JRXS pro listed... I know a guy who still has a huge parts lot and offered to give me what was in it. He had the pro. I know the shocks are identical plus I've cross referenced some of the small parts as the same; but I'm curious what else carries over? (I used the JRXS layshaft in my build BTW.) I am most curious about outer suspension parts. Thanks...
C-hubs, rear blocks, some of the bearings, body mounts, the arms will fit but i've never seen anyone use them, the rear lcd's i think are also the same or similar. Haven't tried the hinge pin blocks yet but they look similar the type r ones are beefier though, haven't bent one yet and i used to bend them constantly on the pro.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 10-15-2008, 09:46 AM   #8283
Uncle Cliffy's Avatar
Thanks for the reply. I was at the local shop and just happened to look at the steering block/caster block parts for a XXXS and they look pretty similar. I already broke a caster block and so did my friend who recently got the car as well. We both agreed that for us amateurs, this is a weak spot on the car. (I am running a pretty stupid amount of power for how tight our track is though... )
I am wondering if it would be cool to try the 6 degree blocks? Our track is pretty tight on medium grip carpet. I think my car handles pretty damn good even being excessively over-powered, so I'm curious the difference...
Uncle Cliffy is offline   Reply With Quote
Old 10-16-2008, 12:21 PM   #8284
louielou's Avatar
Trader Rating: 16 (100%+)
Default jaco blue setup
was wondering if anyone knows where i can find a full jaco blues setup that works.
thanks
Luis
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 10-16-2008, 12:31 PM   #8285
http://www.rctech.net/forum/4790351-post7904.html
JoelV is offline   Reply With Quote
Old 10-16-2008, 12:32 PM   #8286
MikeXray's Avatar
Trader Rating: 72 (100%+)
thanks
Luis
the Haynes, fairtrace, or schreff rubber tire setups all will with blues. I posted them a little bit back.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-16-2008, 12:42 PM   #8287
louielou's Avatar
Default jaco blues
i meant a setup for jaco blues on asphalt not carpet, sorry.
was also wondering what the difference was between 1 degree hub compared to a 1 degree offset hub? how would the car react, and which ones r used the most for asphalt setups.
thanks
Luis
Luis
Ebay account LOU840
Old 10-16-2008, 01:03 PM   #8288
MikeXray's Avatar
thanks
Luis
The offset hubs are for using the short length in the arms, I personally have never run that, I imagine it will make the car rotate harder, but might be too much.
Here is fairtrace's setup from the reedy race, but honestly I ran virtually the same setup on asphalt this summer as I do now on carpet, except that on asphalt I used narrow hexes all around, and use wider on carpet.
Old 10-18-2008, 02:02 AM   #8289
jrxs-r's Avatar
Anyone know where I can get the LOSA4312 Steel Lipo Tray? Need one for a few competitions coming up.
Thanks all.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-18-2008, 04:34 AM   #8290
RedRocketRacing's Avatar
Thanks all.
I ran my car with the plastic tray and by the time I placed the lead on the opposite side of the ESC to ballance the car I was about 6 grams over weight. With the tray, I was almost 90g over. This was on foam tires with a trakpower 4900 lipo, and the Losi esc.
Weight it all out and get in balanced and than see if you really need it.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 10-18-2008, 04:42 AM   #8291
jrxs-r's Avatar
RedRocket
No worries. Will do that.
Update: Tried going harder in the rear to a 20lb spring, and that helped the car turn in much better with more consistent traction through the turn and coming out under power. Running 20lb upfront as well, and it seems like the go.
Thanks for your help guys!
Cheers,
Zack
Serpent S411
Old 10-22-2008, 08:53 PM   #8292
Lapcounter's Avatar
Does anybody know if Losi's new battery fits in the type R?
http://www.losi.com/Products/Feature...rodId=LOSB9862
Lapcounter is offline   Reply With Quote
Old 10-23-2008, 06:55 AM   #8293
racingboy14's Avatar
Trader Rating: 25 (96%+)
do you know if the measurements are posted anwhere? They are not on that page so it is hard to tell.
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 10-23-2008, 06:56 AM   #8294
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I have been running that battery for a month with no problems.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-23-2008, 07:02 AM   #8295
DO you like it? How does it compare to other batteries you have run?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
